The template sensor to track a device around the house works great!
I can already see automations to only have a kids wifi working in the living room and not in the bedroom.
Ok last update for today 0.0.5 is up and has services on the switch platform to allow you to prioritize a device on the network (and a second to clear prioritizations). In the attributes of the switches you will find a prioritized and prioritized_end tag which gives you the details of any prioritization.
Hi Tim , i installed the latest google wifi integration 0.05 but i got this :Unexpected error fetching GoogleWifi data: âstationPoliciesâ
File â/usr/src/homeassistant/homeassistant/helpers/update_coordinator.pyâ, line 144, in async_refresh
self.data = await self._async_update_data()
File â/config/custom_components/googlewifi/init.pyâ, line 121, in _async_update_data
system_data = await self.api.get_systems()
File â/usr/local/lib/python3.8/site-packages/googlewifi/init.pyâ, line 142, in get_systems
return await self.structure_systems(response)
File â/usr/local/lib/python3.8/site-packages/googlewifi/init.pyâ, line 191, in structure_systems
for blocking_policy in this_system[âgroupSettingsâ][âfamilyHubSettingsâ][âstationPoliciesâ]:
KeyError: âstationPoliciesâ
I think this is algo affecting the chromecast plug-in that I am using to have my access points as media players. May be related to something like API throughout control?
Media player go to unavailable and then come back online:
Logger: pychromecast.socket_client
Source: /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py:657
First occurred: 4:20:14 (2 occurrences)
Last logged: 4:22:00
[Bedroom Wifi(192.168.86.31):8009] Error communicating with socket, resetting connection
[Hall Wifi(192.168.86.58):8009] Error communicating with socket, resetting connection
At the same time, this addon also suffers for connection issues:
Logger: custom_components.googlewifi
Source: custom_components/googlewifi/__init__.py:126
Integration: Google WiFi (documentation)
First occurred: 3 November 2020, 21:52:42 (28 occurrences)
Last logged: 7:18:56
File "/config/custom_components/googlewifi/__init__.py", line 121, in _async_update_data
File "/usr/local/lib/python3.8/site-packages/googlewifi/__init__.py", line 144, in get_systems
raise GoogleWifiException("Failed to retreive Google Wifi Data.")
googlewifi.GoogleWifiException: Failed to retreive Google Wifi Data.
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 144, in async_refresh
File "/config/custom_components/googlewifi/__init__.py", line 126, in _async_update_data
raise PlatformNotReady from error
homeassistant.exceptions.PlatformNotReady
Thatâs an interesting one. Why are you running a separate component for the Chromecast feature? My Google Home/Minis and Access Points all were discovered automatically with nothing added as media players. I am not seeing this through the standard Chromecast integration. It is possible that there is a collision between these two API session accesses based on the errors in the logs. What is the plug-in you are using - I can try in my Dev environment to see if I can replicate.
Ok same here. Only one of my Wifi hotspots is the new Nest ones with built in Mini so I will watch for collisions on that. The rest of my Chromcast devices (17 of them lol) are TVs, speakers, and Chromecast Audio devices. I didnât see any issues yesterday but will monitor that one today.
Reset is just a soft reboot of the access point or the network. So if you are having problems with devices connecting or need to do a router reboot for whatever reason you can reset either a single access point or the whole network. (Not a factory reset, just a soft reset).
@ramibouaoun I have updated to version 0.0.6 which includes a fix for this issue. Please let me know the results of your testing since I donât have a configuration that will throw this error.
I have updated to version 0.0.7 which fixes an issue I noticed where the lights entitites were not being correctly assigned to the devices they belong to.
I am seeing an issue where some the switches associated with the device_tracker entities show unavailable and I see this in the logs:
2020-11-04 08:41:51 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 119, in _handle_refresh_interval
await self.async_refresh()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 193, in async_refresh
update_callback()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 223, in _handle_coordinator_update
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 296, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 320, in _async_write_ha_state
sstate = self.state
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 676, in state
return STATE_ON if self.is_on else STATE_OFF
File "/config/custom_components/googlewifi/switch.py", line 78, in is_on
if self.coordinator.data[self._system_id]["groupSettings"]["lanSettings"]["prioritizedStation"]["stationId"] == self._item_id:
KeyError: 'stationId'
So it turns out that my teenagers internet wasnât turning off as designed in the Google Home/Wifi apps as it was supposed to⌠and the new integration flagged it for me. So now Home Assistant has control of their Wifi and they are SO happy about it. Lol.
I just pushed 0.0.9 which I hope solves the issue of entities going unavailable. I also added the ip_address of the device to the device_tracker entities as an attribute.
Scratch that - the initial fix didnât work on the unavailable issue. I took another stab at it in version 0.1.0 which seems to be working on my system correctly. Please report any testing issues here or on the github issue log.
Working flawlessly all night! Thank you very much!
Regarding âduplicateâ entities, it does seem that google is storing old versions of device for a long time with no way to remove them. Just need to wait
