Thats a huge step … thankts for posting here.
I havn’t seen information on music mode and scenes, great work.
I’m still fiddling on the dev container, just building with --network-mode=host, which sounds logically right. It just takes a looooong time on the RPi if you are used to an high end dev machine otherwise
Heh. Well it’s a fork of a fork. Just standing on other people’s shoulders. Most of that information is from BeauJBurroughs. I just updated it to be H6199 relevant.
Hi there
I added the repo via hacs but I can’t find the integration when looking for it
Steps I did :
Add the repo via hacs
Install repo
restart hassio
configuration-integration-add integration
I didn’t find Govee Led Strip
It may take some while until it shows up in integrations, just install it and wait a bit.
If it still fails consider turning on debug logs (see first post) reinstall, maybe reboot and get the log lines mentioning Govee for each stage. Then post here.
I’ve tried the “Govee Ambi-Light” - is there a possibility just turn it on and off in the configured mode?
If i use on/off it always goes to color mode instead of video mode.
I have successfully installed this integration, thanks it works great.
Just one issue - I have 2 strips (both H6159) but just one is working and I cannot find any reason or difference that stands out. Both work in the Govee app.
The 2nd won, I’ve called it “Counter”, just shows “Unavailable”.
Any help will be appreciated.
Is it configured to your WiFi? The app uses BLE too, maybe that’s why it is working.
You could also enable debug log as described in first post and post here for further diagnostics.
@LaggAt
I just verified that someone as a PR that fixes the version requirement that takes effect in June.
Just letting you know here in case you missed it in GitHub.
