Govee integration
I have the same issue here:
This error originated from a custom integration.
Logger: homeassistant.config_entries
Source: custom_components/govee/__init__.py:67
Integration: Govee (documentation, issues)
First occurred: 9:40:10 AM (2 occurrences)
Last logged: 9:41:21 AM
Error setting up entry govee for govee
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 383, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/config/custom_components/govee/__init__.py", line 67, in async_setup_entry
    await hub.rate_limit_delay()
AttributeError: 'Govee' object has no attribute 'rate_limit_delay'
I also found that the brightness value was missing and I added it manually but i still have the same error :frowning:
Hey! I had the integration up and working then I had to redo my home assistant install and now when I try to put in the API Key (a new one I requested) it doesnā€™t work and says it canā€™t connect. any ideas?
Well, I deleted the Govee integration and reinstalled it and for now itā€™s working fine.
Looks like the integration is down with Goveeā€™s API.
Govee 0.2.2 stopped working on HA 2023.3.6
It stopped controlling devices, so I uninstalled restarted, tried older version; no luck.
Reinstalled latest version of the HACS Govee integration.
Getting an error about an invalid API key. Tried my old API key, and requested a new API key from Govee. Both API keys do not work.
Anyone else getting this today?
Idem here, not working anymore
First occurred: 10:02:00 PM (1 occurrences)
Last logged: 10:02:00 PM
Iā€™m seeing:
Logger: custom_components.govee.config_flow
Source: custom_components/govee/config_flow.py:34
First occurred: 4:09:22 PM (8 occurrences)
Last logged: 9:29:13 PM
Cannot connect: API: API-Error 500: {"message":"service is busy please try again later","status":500}
Cannot connect: API: API-Error 401: {"message":"Invalid API Key","status":401}
  File "/config/custom_components/govee/config_flow.py", line 68, in async_step_user
    user_input = await validate_api_key(self.hass, user_input)
  File "/config/custom_components/govee/config_flow.py", line 34, in validate_api_key
    raise CannotConnect(error)
custom_components.govee.config_flow.CannotConnect: API: API-Error 500: {"message":"service is busy please try again later","status":500}
Iā€™m seeing a pretty similar error to the rest of you:
First occurred: April 3, 2023 at 9:20:20 PM (1 occurrences)
Last logged: April 3, 2023 at 9:20:20 PM
This seems like Govee themselves made a change that broke things.
It goes down daily and comes back up after a little while with me all the time.
Any update on BLE support? Hoping to control my H6199 LED Strip, but lost the camera with the WiFi adapter built-in.
Same problem! If anyone has news, shout. thanks
a restart helped me
I am doing a restart of the integration every day.
I am as well :frowning:
Just install the Google SDK integration and issue commands to Govee via Google, much more reliable.
new hereā€¦ where can i find the latest file to download?
Hi! can you explain how you did this? can you still use buttons on the dashboard to control lights?
@ctml Thanks for the suggestion but Iā€™m not able to get past Video Mode even with the Google SDK, it doesnā€™t recognize the commands. If you managed to do it, can you tell us how?
What file are you referring to?
Same Problem here:
Dieser Fehler wurde von einer benutzerdefinierten Integration verursacht
First occurred: 13:41:23 (2 occurrences)
Last logged: 14:01:35
Testcase:
curl --location 'https://developer-api.govee.com/v1/devices' \
--header 'Govee-API-Key: {{govee_api_key}}'
{"message":"service is busy please try again later","status":500}#
Same Message with Postmanā€¦
If it helps anyone, raising my polling interval in the GoVee integration from 10 to 60 helped me with the random disconnects and there has been no loss of function.
