I use the following automation setup for managing my UPS in my rack that handles all the primary gear that is connected to it. The actions at 10% charge left are actioned through hass.agent’s MQTT commands to the client installed on the main PC and NAS is set to safe shutoff on its own once the press action is activated and everything to power on when power is restored.
I have a seperate automation setup to notify me when my HA instance has restarted and use a switchbot bot to turn on and off the usb port that my skyconnect is plugged into on my mbeat 7 port hub which I also got rid of the battery from and swapped in a cr2 battery eliminator cable so I don’t have to worry about new batteries when I am not home should I need to control it.
I have smart plugs as well set to on state on power restore as well as backup for core devices to act as a auto power switch for the restore on power loss setting to work more consistently as a failsafe.
alias: UPS Automations
description: ""
- type: battery_level
platform: device
device_id:
entity_id:
domain: sensor
below: 99
for:
hours: 0
minutes: 0
seconds: 30
id: UPS Discharging
platform: device
device_id:
entity_id:
domain: sensor
below: 50
for:
hours: 0
minutes: 0
seconds: 30
id: "UPS Discharging: 50%"
platform: device
device_id:
entity_id:
domain: sensor
below: 10
for:
hours: 0
minutes: 0
seconds: 30
id: "UPS Discharging: 10%"
- platform: state
entity_id:
- sensor.main_ups_status
to: Online Battery Charging
for:
hours: 0
minutes: 0
seconds: 5
condition: []
- choose:
- conditions:
- condition: trigger
id:
- UPS Discharging
- service: notify.mobile_app
metadata: {}
title: UPS
message: Main UPS is Discharging
notification_icon: mdi:battery-arrow-down
color: yellow
- conditions:
id:
- "UPS Discharging: 50%"
metadata: {}
title: UPS
message: Main UPS is at 50%
notification_icon: mdi:battery-50
color: yellow
- conditions:
id:
- "UPS Discharging: 10%"
metadata: {}
title: UPS
message: Main UPS is at 10%
notification_icon: mdi:battery-10
color: red
- device_id: NAS power button
domain: button
entity_id:
type: press
- device_id: main pc hass.agent mqtt press
domain: button
entity_id:
type: press
- type: turn_off
device_id: main pc monitors smart plug
entity_id:
domain: switch
- conditions:
id:
- UPS Charging
metadata: {}
title: UPS
message: Main UPS is Charging
notification_icon: mdi:battery-charging
color: green
