I see what is happening, but not why. I just pushed a version with a --debug
flag. Please send me the output of that, PM is fine.
That works well for me, and now shows up the remotes again:
Itās really interesting to see how some of my nodes move around.
This latest push worked for me. Did you make any changes around Python 3.5? It may have been the --ssl option not working in the last version that caused the error. Because this time, i got the same error without --ssl, but worked fine with it.
I must have messed up something during install last night. I pulled the latest version and it is working great. Thanks again.
Hello guys,
Iām having a small issue when trying to setup this graph in my HA.
Running this command from prompt in virtual env :
(homeassistant) homeassistant@raspberrypi:~ $ python ~/bin/z-wave-graph.py --ssl --port 443
is okay (I get the json). When running the same thing in shell_command.yaml I get:
2018-01-28 18:20:01 ERROR (MainThread) [homeassistant.components.shell_command] Error running command:
python ~/bin/z-wave-graph.py --port 443 --ssl
, return code: 1 NoneType: None
Any idea?
Maybe try putting the full path to python in the shell_command. /usr/bin/python
maybe, or try /usr/bin/env python
and then the rest.
I tried both but still get:
2018-01-28 23:00:00 ERROR (MainThread) [homeassistant.components.shell_command] Error running command:
/usr/bin/python ~/bin/z-wave-graph.py --port 443 --ssl
, return code: 1
NoneType: None
or
, return code: 1
23:00 /srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/shell_command.py (ERROR)
Your top and bottom messages are the same. Iām not sure if that was a copy/paste error during testing, or during posting.
I guess the first question is: where is your Python: which python
Also, what version: python -V
And just to be sure: which env
Make sure you run all those logged in as the homeassistant user and with the virtual environment activated.
Well, everything works fine in cmd line:
pi@raspberrypi:~ $ sudo su -s /bin/bash homeassistant
homeassistant@raspberrypi:/home/pi $ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@raspberrypi:~ $ which python
/srv/homeassistant/bin/python
(homeassistant) homeassistant@raspberrypi:~ $ python -V
Python 3.5.3
(homeassistant) homeassistant@raspberrypi:~ $ which env
/usr/bin/env
(homeassistant) homeassistant@raspberrypi:~ $ /usr/bin/env python ~/bin/z-wave-graph.py --ssl --port 443
as soon as I try any of the cmd in HA, they fail.
2018-01-29 18:30:00 ERROR (MainThread) [homeassistant.components.shell_command] Error running command: `/usr/bin/python ~/bin/z-wave-graph.py --port 443 --ssl`, return code: 1
NoneType: None
2018-01-29 18:40:00 ERROR (MainThread) [homeassistant.components.shell_command] Error running command: `/usr/bin/env python ~/bin/z-wave-graph.py --port 443 --ssl`, return code: 1
NoneType: None
It makes no sens to me but Iām far from being python fluent.
I just got my usb module installed and working great. I wanted to try this out, and i am running into a strange issue that i am unable to figure out.
line 23 and 24 import homeassistant.config/remote. The script is failing here. Where should these be located? Did i miss something?
Home Assistant: 0.62.0
Custom UI: 20180126
Running in a docker container.
Python: 3.6.4
ENV: /usr/bin/env
using --ssl
the script itself is located in /config/bin as there is no access to any lower directories via samba. i can move if necessary.
The exact error: ModuleNotFoundError: No module named āhomeassistantā
The installed modules:
It just occurred to me to try the full path instead of ~/bin/z-wave-graph.py
, something like /srv/homeassistant/bin/z-wave-graph.py
Is HA running under a virtual environment? Are you running the script from the same virtual environment? Sorry, I donāt use docker so I canāt comment on any specifics.
Yes, its a docker container. I am running the script in the container. The docker install doesnt seem to have the homeassistant module, even though it is running correctly. I am really curious what the differences are. Iām scouring the new to see how to get it to work.
Just opened a support ticket.
I tried all the variations I could think of around your adviceā¦no luck. However, running the command manually is okay and i get the graph in HA so itās okay in the end. I can do an update once in a while (my z-wave network doesnāt move that much)
FYI - This breaks when the base_url
is a full URL. Example: https://home.myurl.com
- when trying to split out or remove the port.
I just pushed a new version that uses base_url for both the port and SSL, so it should work with your case. Just be sure to remove --ssl
or --port
if you used them.
BREAKING: The --ssl
and --port
flags have been removed. Set your base_url
appropriately:
- http://localhost
- localhost:80
- http://localhost:8123
- https://localhost:8123
- https://host.example.com:443
@e_jp: Itās possible this will fix your issue. @Bigrob8181: same for you, plus I added a check to make sure the API connection happened and error out if it didnāt. If you get that error there may be a message which helps diagnose the issue.
does this support
https://home.url.com
and use default 443?
I tried different URLs but none did work.
However, I found that even if I defined an IP like
https://192.168.1.12:8123/local/z-wave-graph.html
the script will try to use the base URL in configuration.yaml.
requests.exceptions.ConnectionError: HTTPConnectionPool(host='my.domain.com', port=8123): Max retries exceeded with url: /api/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x758612f0>: Failed to establish a new connection: [Errno 111] Connection refused',))
Error, unable to connect to the API: cannot_connect
If I set
z_wave_graph_url: https://my.domain.com/local/z-wave-graph.html
I still get
requests.exceptions.ConnectionError: HTTPConnectionPool(host=āmy.domain.comā, port=8123): Max retries exceeded with url: /api/ (Caused by NewConnectionError(ā<urllib3.connection.HTTPConnection object at 0x75913250>: Failed to establish a new connection: [Errno 111] Connection refusedā,))
