I think i’ve got everything installed correctly but I’m confused about setting the URL’s.
I’m getting the following errors in HA when it tries to run the script with the automation:
2018-05-27 03:15:08 ERROR (MainThread) [homeassistant.components.shell_command] Error running command: `/srv/homeassistant/bin/python3 /home/homeassistant/.homeassistant/bin/z-wave-graph.py`, return code: 1
NoneType: None
When I run it from the command line in the venv using the following command:
I get:
Error connecting to server
File "/srv/homeassistant/lib/python3.6/site-packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/srv/homeassistant/lib/python3.6/site-packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/srv/homeassistant/lib/python3.6/site-packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/srv/homeassistant/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/srv/homeassistant/lib/python3.6/site-packages/urllib3/connectionpool.py", line 357, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.6/http/client.py", line 1239, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1285, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1234, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.6/http/client.py", line 1026, in _send_output
self.send(msg)
File "/usr/local/lib/python3.6/http/client.py", line 964, in send
self.connect()
File "/srv/homeassistant/lib/python3.6/site-packages/urllib3/connection.py", line 166, in connect
conn = self._new_conn()
File "/srv/homeassistant/lib/python3.6/site-packages/urllib3/connection.py", line 150, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x754335b0>: Failed to establish a new connection: [Errno 111] Connection refused
File "/srv/homeassistant/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/srv/homeassistant/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/srv/homeassistant/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='XXXX.duckdns.org', port=8123): Max retries exceeded with url: /api/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x754335b0>: Failed to establish a new connection: [Errno 111] Connection refused',))
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/remote.py", line 89, in __call__
url, params=data, timeout=timeout, headers=self._headers)
File "/srv/homeassistant/lib/python3.6/site-packages/requests/api.py", line 72, in get
return request('get', url, params=params, **kwargs)
File "/srv/homeassistant/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/srv/homeassistant/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/srv/homeassistant/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/srv/homeassistant/lib/python3.6/site-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='XXXX.duckdns.org', port=8123): Max retries exceeded with url: /api/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x754335b0>: Failed to establish a new connection: [Errno 111] Connection refused',))
raise err
sock.connect(sa)
chunked=chunked)
self.send(msg)
self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x75433d70>: Failed to establish a new connection: [Errno 111] Connection refused
timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='bussnet.duckdns.org', port=8123): Max retries exceeded with url: /api/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x75433d70>: Failed to establish a new connection: [Errno 111] Connection refused',))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='bussnet.duckdns.org', port=8123): Max retries exceeded with url: /api/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x75433d70>: Failed to establish a new connection: [Errno 111] Connection refused',))
Error, unable to connect to the API: cannot_connect
I can only assume that it’s because of the URL in the config yaml but i’m not sure I know how it needs to be setup. Right now it’s:
http:
api_password: !secret http_password
base_url: xxxx.duckdns.org:8123
ssl_certificate: /etc/letsencrypt/live/xxxx.duckdns.org/fullchain.pem
ssl_key: /etc/letsencrypt/live/xxxx.duckdns.org/privkey.pem
ip_ban_enabled: True
login_attempts_threshold: 5
do I need to set the base_url above to xxxx.duckdns.org:443?
how will that affect the certs and access from the outside of my lan? I thought we need to have the base_url set that way to enable proper port access.
