With the recent upgrade, I am experiencing a visible group on the front end when its not in the view.
I have group A in another Group B. When I put Group B on the front end default view or other tab/view, Group A appears in Group B as expected but also Group A appear by itself which is unexpected and new.
I just tried setting up something similar with the same result. I was hoping to come here for an answer.
I put group A and B into C. Both appear in C but also appear as their own cards.
I tried hiding groups A and B in cuztomize.yaml but that just seems to break all three cards.
The following is my group setup for my Den. Apparently when I include a sensor (possibly other entities too) in a view:yes group, it makes the sensor visible in any view:no groups in exists in and causes them to display on the screen as well. In the groups below, everything is expected, except for the entity_den_sensor group in the upper left corner of the screen shot below. That group should not be visible. Running 44.1
It’s the same as what’s happening to me. As soon as you make a group containing an object visible, any other groups containing that object appear to become visible at least for that one object. You added switches, which has kitchen lights in it, so the kitchen light alert window showed up too.
You must to verify because “hide timer automation” action just when it triggered. When you want to reactivate, after trigger, you must to “reload core” , not just refresh page browser.
