Grouping sensors that report non-numeric data
Thank you for your input:
That is more elegant as one can simply add or remove entities to the label group.
This would still not work. What is missing is a template behind condition: :slight_smile:
            - condition:  template
              value_template: "{{ label_entities('Bad/WC') | select('is_state', ['open','on']) | list | count > 0}}"
With this addition the actions ffinally execute.
Many thanks for your help! I believe I mostly got it now
Good catch! Sorry I missed that.
You might consider removing the last condition of your choose block and moving the actions to a default block. If neither of the first two conditions had a match then this should be the only alternative. Additionally, adding or removing entities from the label group would break your current logic because the count would no longer == 6.
I had already realized that the check is not necessary and removed it.
