Thanks for the advice… now how do I remove all of the sensors created? do I just delete the whole energy_cost.yaml file?
To remove any sensor you’d need to delete the yaml or integration that creates it, then either restarting HA or searching for the entity and deleting it should make them go away.
Looks like I hit a big roadblock once I deleted the whole energy_cost.yaml file.
I deleted the whole file did a full reboot, then created the 2 sensors, (sensor.electricity_imported_energy_kwh &
sensor.electricity_exported_energy_kwh), recreated the energy_cost.yaml file, added the contents of the file like below. Saved restarted yaml made sure there were no errors, did a full reboot.
This is the result.
Entity: input_number.electricity_demand_max (issue showing power W)
Entity: sensor.days_remaining_in_month (no sensor created)
Entity: sensor.electricity_export_rate (no sensor created)
Entity: sensor.electricity_exported_power_daily (issue showing power W)
Entity: sensor.electricity_import_rate_low_demand (no sensor created))
Entity: sensor.electricity_import_rate_off_peak (no sensor created)
Entity: sensor.electricity_import_rate_peak (no sensor created)
Entity: sensor.electricity_import_rate_shoulder (no sensor created)
Entity: sensor.electricity_imported_power_daily_off_peak (issue showing power W)
Entity: sensor.electricity_imported_power_daily_peak (issue showing power W)
Entity: sensor.electricity_imported_power_daily_shoulder (issue showing power W)
I’m totally stuck…
### This package assumes you have an import sensor "sensor.electricty_imported_power_kwh"
### which provides cumulative electricity imported in kWh
### and an export sensor sensor.electricty_exported_power_kwh
### which provides cumulative electricity exported in kWh.
### If you use other sensor names, adjust everything below as required to match.
- platform: time_date
display_options:
- "date"
template:
- sensor:
- name: Electricity Import Rate Peak
unique_id: electricity_import_rate_peak
icon: mdi:cash-minus
unit_of_measurement: $/kWh
state: "0.40920" ### edit to your peak import rate
- name: Electricity Import Rate Shoulder
unique_id: electricity_import_rate_shoulder
state: "0.000" ### edit to your shoulder import rate
- name: Electricity Import Rate Off Peak
unique_id: electricity_import_rate_off_peak
state: "0.20950" ### edit to your off peak import rate
- name: Electricity Export Rate
unique_id: electricity_export_rate
state: "0.10400" ### edit to your solar feed-in-tariff /export rate
- name: Electricity Supply Charge
unique_id: electricity_supply_charge
unit_of_measurement: $/day
state: "1.210" ### edit to your daily supply charge
- name: "Electricity Demand Max"
unique_id: electricity_demand_max_sensor
unit_of_measurement: kWh
state: >
{{ states('input_number.electricity_demand_max') |float(0) }}
- name: Total Daily Import Cost
icon: mdi:currency-usd
state_class: total_increasing
device_class: monetary
state: >
{% set supply = states('sensor.electricity_supply_charge') | float(0) %}
{% set offpeak = states('sensor.electricity_imported_power_daily_off_peak') | float(0) * states('sensor.electricity_import_rate_off_peak') | float(0) %}
{% set shoulder = states('sensor.electricity_imported_power_daily_shoulder') | float(0) * states('sensor.electricity_import_rate_shoulder') | float(0) %}
{% set peak = states('sensor.electricity_imported_power_daily_peak') | float(0) * states('sensor.electricity_import_rate_peak') | float(0) %}
{{ (supply + offpeak + shoulder + peak) | round(2) }}
- name: "Electricity Demand Monthly Cost"
unique_id: electricity_demand_monthly_cost
state_class: total
state: >
{% set t = now() %}
{% if t.month in [4,5,9,10] %}
{% set demandrate = states('sensor.electricity_import_rate_low_demand') | float(0) %}
{% else %}
{% set demandrate = states('sensor.electricity_import_rate_high_demand') | float(0) %}
{% endif %}
{{states('input_number.electricity_demand_max') | float (0) * 2 * demandrate * ( now().day + states('sensor.days_remaining_in_month') | int(0) ) }}
- name: "Electricity Total Cost Daily"
unique_id: electricity_total_cost_daily
state_class: total
state: >
{% set feedintariff = states('sensor.electricity_exported_power_daily') | float(0) * states('sensor.electricity_export_rate') | float(0) %}
{% set t = now() %}
{% else %}
{% endif %}
{% set demand = states('input_number.electricity_demand_max') | float (0) * 2 * demandrate %}
{{ (supply + offpeak + shoulder + peak - feedintariff) | round(2) }}
input_number:
electricity_demand_max:
name: Electricity Demand Max Value
# initial: 0 # don't use initial as it will reset upon restart
min: 0
max: 20
step: 0.001
utility_meter:
electricity_imported_power_daily:
source: sensor.electricity_imported_energy_kwh
name: Electricity Imported Power Daily
cycle: daily
tariffs:
- peak
- shoulder
- off-peak
electricity_exported_power_daily:
source: sensor.electricity_exported_energy_kwh
name: Electricity Exported Power Daily
cycle: daily
electricity_demand_max_monthly:
name: Electricity Demand Max Monthly
cycle: yearly
tariffs:
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
automation:
### adjust the time triggers below to match when your standard electricity tariff changes (peak, shoulder, offpeak). Adjust the template in the action block as required to match your plan.
- alias: Set Electricity Tariff
description: ''
- platform: time
at: '15:00:00'
- platform: time
at: '21:00:00'
- platform: homeassistant
event: start
condition: []
- service: select.select_option
option: >-
{% set t = now() %} {%- if t.hour >=15 and t.hour <21 and
is_state('binary_sensor.workday_sensor', 'on') %}
peak
{%- else -%}
off-peak
{%- endif -%}
entity_id:
- select.electricity_imported_power_daily
mode: single
You are missing the template sensor in the package.
For all these, check the statistics page in developer tools and fix the error I assume is there about the unit
For these rate ones, delete the comments on the same line as the rate. I’m not sure if you can have them.
Hi SgtBattten,
Thank you for your prompt reply, sorry for all the dumb questions and long posts. I was up till 2;30am but only been able to resolve this so far this morning from your reply. Not been lucky with the others so far.
I added the template to the energy_cost.yaml file
- sensor:
- name: Days Remaining in Month
unique_id: days_remaining_in_month
state: >
{% set this = now().replace(hour=0).replace(minute=0).replace(second=0).replace(microsecond=0) %}
{% set next = this.month + 1 if this.month + 1 <= 12 else 1 %}
{% set last = this.replace(year=this.year + 1, month=1, day=1) if now().month == 12 else this.replace(month=next, day=1) %}
{{ (last.date() - this.date()).days - 1 }}
I looked in the developer tools >statistic page and it displays W but there is no option to change it to kWh like it should be.
I have done this but not much success at all.
What is so interesting is that when I created it originally all the sensors, rates were there except that the displayed in W and not kWh.
Since making the changes you recommended and deleting the file and replacing it, everything went pear shape.
What is interesting though is that it created the sensor.electricity_supply_charge, this is the only one that got created the second time.
Do you think I should delete the file (energy_cost_yaml)once again totally and add the file again?
Appreciate your advice.
If you like we could use something like anydesk and I can have a look directly at what is going on?
Sure if you can that would be great…
I deleted the file and recreated a new one called energy_cost1.yaml
Just rebooting to see how it goes.
Having a play with this - I’m in NSW
and…first issue ’ The Workday YAML configuration is being removed’
lol…more playing needed
Hi Mate,
Hope you had a great weekend?
Is it possible for you to please help me with a yaml file, so I can just put it in the packages folder and not mess with any part of the existing energy_cost.yaml file that you created for me?
I am trying to get to the bottom of this inconsistent readings I am getting. So I want to compare what I have displayed in powerpal and ausgrid to see where this is going pear shape.
So what I am after is a file called hourly_energy_consumed.yaml
This will take the 4 sensor’s you have already created. If its appropriate, if not…
sensor.electricity_imported_energy_daily_off_peak
sensor.electricity_imported_energy_daily_shoulder
sensor.electricity_imported_energy_daily_peak
Create 4 sensor’s as follows
sensor.electricity_imported_energy_hourly_off_peak
sensor.electricity_imported_energy_hourly_shoulder
sensor.electricity_imported_energy_hourly_peak
sensor.electricity_supply_charge_hourly
I would greatly appreciate if you can help me with a script.
All you really need is this one. Just make it have the same source as your daily one.
And you need to update the automation to include this utility meter also so that the tarrifs change at the right time.
I don’t see the point of tracking the supply charge hourly, it’s a fixed rate per day.
utility_meter:
electricity_imported_power_hourly:
cycle: hourly
tariffs:
- peak
- shoulder
- off-peak
Thanks so much for your prompt help…
So this is what I have currently.
utility_meter:
electricity_imported_energy_daily:
source: sensor.shelly_em_channel_1_energy
name: Electricity Imported Energy Daily
cycle: daily
tariffs:
- peak
- shoulder
- off-peak
electricity_exported_energy_daily:
source: sensor.shelly_em_channel_2_energy_returned
name: Electricity Exported Energy Daily
cycle: daily
automation:
description: ""
- platform: time
at: "15:00:00"
- platform: time
at: "21:00:00"
event: start
condition: []
option: >-
{% set t = now() %}
{%- if t.hour >=15 and t.hour <21 %}
peak
{%- else -%}
off-peak
{%- endif -%}
entity_id:
- select.electricity_imported_energy_daily
mode: single
I have changed to this, is it correct?
utility_meter:
cycle: daily
tariffs:
- peak
- shoulder
- off-peak
electricity_imported_energy_hourly:
cycle: hourly
tariffs:
- peak
- shoulder
- off-peak
cycle: daily
automation:
description: ""
- platform: time
at: "15:00:00"
- platform: time
at: "21:00:00"
event: start
condition: []
option: >-
{% set t = now() %}
peak
{%- else -%}
off-peak
{%- endif -%}
entity_id:
- select.electricity_imported_energy_hourly
mode: single
Yep just change this on the hourly one. My mistake
Thanks so much mate, made the changes below.
utility_meter:
cycle: daily
tariffs:
- peak
- shoulder
- off-peak
name: Electricity Imported Energy Hourly
cycle: hourly
tariffs:
- peak
- shoulder
- off-peak
cycle: daily
automation:
description: ""
- platform: time
at: "15:00:00"
- platform: time
at: "21:00:00"
event: start
condition: []
option: >-
{% set t = now() %}
peak
{%- else -%}
off-peak
{%- endif -%}
entity_id:
mode: single
Thanks so much for the information.
Would this work to get the Energy Exported Hourly?
electricity_exported_energy_hourly:
name: Electricity Exported Energy Hourly
cycle: hourly
Automation
automation:
description: ""
- platform: time
at: "15:00:00"
- platform: time
at: "21:00:00"
event: start
condition: []
option: >-
{% set t = now() %}
peak
{%- else -%}
off-peak
{%- endif -%}
entity_id:
- select.electricity_exported_energy_hourly
mode: single
First bit yes, but don’t add it to the automation. There are no export tariffs so nothing to change with that automation…
Thanks mate for the prompt reply.
The readings I am getting so far is quite close to powerpal, but I have noticed the following.
- I am running on batteries, but can see the offpeak is giving me some stray readings like…
7pm 0.017kWh
8pm 0.023kWh - But what is really strange and I just cannot put my fingure on this is that instead of displaying offpeak its showing it as peak usage.
Would you know why its dislaying reading as peak usage and not offpeak usage ?
Isn’t 3pm to 9pm peak according to your automation?
Good morning mate, Thanks for your prompt reply
Yes that is the peak time, but I was charging the batteries after 9pm. Even now its show as I am using peak energy. This has got me totally stumped.
