Btw, if you want to run a custom domain like assistant.mydomain.com (instead of YOURNAME.duckdns.org) you can do this by setting a CNAME DNS record at your custom domain. Note, that in this case you should use this domain with certbot.
Following the instructions but the SSH is Pi@hassbian. Tried sudo and switching to SU as root and HASS but continue to get error creating the log file and no OK or KO
On hassbian 0.49 the path is /srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/frontend/templates/index.html
I got stuck here, doesen’t verifies. I’ve rebooted, reopened the file and the changes are made, but they don’t apear in the page nor google verifies. What should I do?
It finally did. The port was the problem. It only verified when I DID NOT put the port:
https://MYHASSNAME.duckdns.org/
I got duck dns working but it will only work when I am off my network. How do I get it to work on my local network as well?
Does the HTML5 notification works for IOS ? Sorry for the newbie question lol i have running on android but it does not show in IOS chrome
Thank you
Perhaps a better method of a google site verification, that is upgrade safe and doesn’t require altering of homeassistant’s index.html is to include these lines in your nginx configuration (if you’re using nginx that is!)
location /google<snipped google code>.html {
rewrite ^/(.*) $1;
return 200 "google-site-verification: $uri";
See https://ersocon.net/blog/2016/11/17/how-to-verify-google-webmaster-tools-with-nginx for a better description.
I tried to install a certificate for my custom domain with certbot.
However when i treid the run the command:
./certbot-auto certonly --standalone --standalone-supported-challenges http-01 --email [email protected] -d YOURSUBDOMAIN.duckdns.org
with my own parameters i got the error:
Sorry, I don’t know how to bootstrap Certbot on your operating system!
You will need to install OS dependencies, configure virtualenv, and run pip install manually.
Please see https://letsencrypt.readthedocs.org/en/latest/contributing.html#prerequisites
for more info.
and i cant quite figure out why or how to fix this. can someone push me in the right direction?
try this
./certbot-auto certonly --standalone --preferred-challenges http-01 --email [email protected] -d YourDomain.duckdns.org
Still the same error
suggest you try this tutorial.
https://diyautomate.me/2017/04/21/securing-home-assistant-with-lets-encrypt-ssl-complex-passwords-and-ip-banning/
I try verity include port or not include port but all of them not success
I use Raspbian os and i set meta tag to index file in locaion /srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/frontend/templates/index.html
Did i do something wrong ?
error when trying to install letsencrypt
core-ssh:~/certbot# wget https://dl.eff.org/certbot-auto
Connecting to dl.eff.org (151.101.0.201:443)
wget: error getting response: Connection reset by peer
core-ssh:~/certbot#
Is this because letsencrypt has disabled new certificates?
Any thoughts…
Is this method obsolete or still valid, considering we now have this ?
Tried that also. Could not get it to work. tried several times with same errors nobody could provide any help so had to abandoned that method.
@Darklyte Thank you for this post. I was previously attempting the BRUH method via YT and was not successful. Using his method and your method I was able to get to the point in the DuckDNS setup where I begin typing in ‘crontab -e’ and then I get a completely different screen. When I paste the required text ‘*/5 * * * * ~/duckdns/duck.sh >/dev/null 2>&1’ it is not recognized and gives me a “Pattern not found” error. Could you please help me in what my next should be? Am I missing a step somewhere? I have included a screenshot for reference of the screen I get when I hit ‘enter’ after the ‘crontab -e’ command. Thanks
Hello . I have a problem with the crontab. when I try to modify it with an indication of Duck DNS( * / 5 * * * * ~ / duckdns / duck.sh> / dev / null 2> & 1). He tells me Path not found. I do not understand the reason. If I try to save by doing ctrl + x as you indicate in the guide it does not work. How can I do?
I am running into the same problem. See my post above. I am hoping to get some help with this too. I know it is probably something simple. I am still researching. If I find the solution, I will let you know.
Ok. Thank you! you would do me a great favor!
