- After making Kodi to autostart got an error in HA ( Unsupported system - Network Manager issues )
sudo systemctl enable NetworkManager.service
sudo reboot
sudo reboot
I seem to have a problem with 5.4 Configure PuTTY with Private key:.
After typing login as: pi PuTTY immediately replies with a fatal error, saying:
No supported authentication methods available (server sent: publickey)
Edit:
Probably modifying the file permissions in .ssh went wrong. I assume I cannot get access to my Raspi anymore and will start again from scratch
I’ve just started the installation and ran into the problem that the package systemd-resolved is no longer available, but the file /lib/systemd/systemd-resolved exists and is part of the systemd package, so I started the installation with:
sudo dpkg -i --ignore-depends=systemd-resolved homeassistant-supervised.deb
For some reason, the ethernet (or at least ssh) connection of my pi isn’t too stable, but after a reboot I continued with:
sudo dpkg --ignore-depends=systemd-resolved --configure -a
Then the installation succeeded and I got the “Preparing Home Assistant” screen and am now at the “onboarding” stage.
Edit:
After onboarding I added systemd.unified_cgroup_hierarchy=0
to /boot/cmdline.txt
to get rid of the cgroup warning.
Also got the Network Manager issue, which was fixed by
sudo reboot
Haven’t tried the Kodi installation yet.
Oh, also didn’t get the bluetooth stuff working, but didn’t care about that.
Edit next day:
Installing additional packages, such as kodi, did not work anymore because of the missing dependency on systemd-resolved for homeassistant-supervised. I resolved that issue by creating a dummy debian package, which I installed with dkpg and made available for download at:
http://tuks.nl/software/systemd-resolved.deb
For a new installation, it would be best to download and install this package if installing homeassistant-supervised fails because of the missing dependency and then re-try, so the --ignore-depends switch is not needed. I haven’t tested this, though, so YMMV.
Apparently this way is not supported anymore and installing suprevised is failing Installing Home Assistant Supervised on a Raspberry Pi using Debian 12
You can try this
sudo BYPASS_OS_CHECK=true dpkg -i homeassistant-supervised.deb
Hi there, is this method and integration still valid? I’m looking to do this on rpi 5 with ssd.
If possible to add systemd-resolved in apt install recquire.
I think it would be possible to install pimox (proxmox port) and kodi, but I haven’t been able to do it yet… if anyone knows how…
Thanks for this manual. I am running into a problem when reconfiguring the wlan0 interface:
wpa_cli -i wlan0 reconfigure
I get a “FAIL” response with no additional answer and I wasn’t able to find anything on it. Any ideas?
