[Guide]Template Fan and Broadlink
If anyone is still struggling with the fan speed script - I found when I did the trace, the choose didn’t function because the number passed is ‘33.0’ not ‘33’. So add decimals to your script and voila!
Thanks for this! New to HA and was pulling my hair trying to get a simple fan added.
I recently got a Bestcon RM4C Mini Universal IR Blaster to control my Dyson floor fan. Realized it might also ease control to see the power level so I got a Shelly Plus Plug. With those two devices and the below fan template I was able to get it completely automated as a fan. I also bridged the fan template over to homekit along with a separate template switch for the oscillation since calls to toggle the oscillation with siri do not work as expected, seems to be a known issue if you search the web for that.
Edit: added in an input_boolean to assist with tracking the oscillation state of the fan. The script just toggles it whenever the oscillation call happens and then the fan is set to track the state of the input_boolean.
fan:
  fans:
    bedroom_fan:
      unique_id: bedroom_fan
      friendly_name: "Bedroom fan"
      value_template: "{{ states('sensor.bedroom_fan_power') | float > 0 }}"
      percentage_template: >
        {% if state_attr('fan.bedroom_fan', 'oscillating') %}
          {%   if states('sensor.bedroom_fan_power') | float >= 55.0 %}
            100
          {% elif states('sensor.bedroom_fan_power') | float >= 41.3 %}
            90
          {% elif states('sensor.bedroom_fan_power') | float >= 29.8 %}
            80
          {% elif states('sensor.bedroom_fan_power') | float >= 20.1 %}
            70
          {% elif states('sensor.bedroom_fan_power') | float >= 16.3 %}
            60
          {% elif states('sensor.bedroom_fan_power') | float >= 10.1 %}
            50
          {% elif states('sensor.bedroom_fan_power') | float >= 7.7 %}
            40
          {% elif states('sensor.bedroom_fan_power') | float >= 5.9 %}
            30
          {% elif states('sensor.bedroom_fan_power') | float >= 4.8 %}
            20
          {% elif states('sensor.bedroom_fan_power') | float >= 3.3 %}
            10
          {% else %}
            0
          {% endif %}
        {% else %}
          {%   if states('sensor.bedroom_fan_power') | float >= 52.0 %}
            100
          {% elif states('sensor.bedroom_fan_power') | float >= 39.0 %}
            90
          {% elif states('sensor.bedroom_fan_power') | float >= 28.0 %}
            80
          {% elif states('sensor.bedroom_fan_power') | float >= 18.0 %}
            70
          {% elif states('sensor.bedroom_fan_power') | float >= 14.0 %}
            60
          {% elif states('sensor.bedroom_fan_power') | float >= 7.5 %}
            50
          {% elif states('sensor.bedroom_fan_power') | float >= 5.0 %}
            40
          {% elif states('sensor.bedroom_fan_power') | float >= 3.2 %}
            30
          {% elif states('sensor.bedroom_fan_power') | float >= 2.2 %}
            20
          {% elif states('sensor.bedroom_fan_power') | float >= 1.0 %}
            10
          {% else %}
            0
          {% endif %}
        {% endif %}
      oscillating_template: "{{ states('input_boolean.bedroom_fan_oscillation_state') == 'on' }}"
      turn_on:
        service: script.bedroom_fan_power
      turn_off:
      set_percentage:
        service: >
          {% if percentage | float > state_attr('fan.bedroom_fan', 'percentage') | float %}
            script.bedroom_fan_increase
          {% elif percentage | float < state_attr('fan.bedroom_fan', 'percentage') | float %}
            script.bedroom_fan_decrease
          {% else %}
            script.do_nothing
          {% endif %}
      set_oscillating:
        service: script.bedroom_fan_oscillate
      speed_count: 10
script:
bedroom_fan_power:
  alias: Bedroom Fan Power On
  sequence:
  - service: remote.send_command
      entity_id: remote.bedroom_fan
      command: b64:JgBIAEcbGTEZMhoYGRoZGRkZGRgZGxoZGRoZGRkZGRkZGBoZGQAM2EgaGDMYMxcbFxsYGxcaGBsWHRYdFxsXHBYbFxwXGhccFgANBQ==
  - delay: 1
  - service: fan.oscillate
      entity_id: fan.bedroom_fan
      oscillating: "{{ states('fan.bedroom_fan') == 'on' }}"
bedroom_fan_increase:
  alias: Bedroom Fan Increase
  sequence:
  - repeat:
      count: 2
      sequence:
          command: b64:JgBIAEYcFjQYMxgaGRoYGhgaGBkYHBg0FxsYMxgaFzQXGhgaGAAMikcbFzQYMxgbFxoYGxcaGBsXHBc0GBoZMhgbGDIYGhgaFwANBQ==
bedroom_fan_decrease:
  alias: Bedroom Fan Decrease
  sequence:
  - repeat:
      count: 2
      sequence:
          command: b64:JgBIAEcbFzQYMxccFxoYGxcaGBsXNBc0GDQXMxkyGDMXMxgaFwAMsEYbGTIYNBcbFxsYGhgaGBoXNRg0FzMYMxgzGDIYMxcaGQANBQ==
bedroom_fan_oscillate:
  alias: Bedroom Fan Oscillate
  sequence:
  - service: input_boolean.toggle
      entity_id: input_boolean.bedroom_fan_oscillation_state
    data: {}
      command: b64:JgBIAEcbGDQXMxkaFxsYGhgaGBoXNRgaGDQXGxY1FxsYGhY0GAAMeEYcFzMZMxccFxoYGxgZGBsXNBkaGDMYGhgzGBoYGhgyGQANBQ==
do_nothing:
  alias: "Placeholder service that does absolutely nothing (pass)"
  sequence:
    delay:
      milliseconds: 1
switch:
bedroom_fan_oscillation:
  friendly_name: "Bedroom Fan Oscillation"
  unique_id: bedroom_fan_oscillation
  value_template: "{{ state_attr('fan.bedroom_fan', 'oscillating') }}"
  availability_template: "{{ states('fan.bedroom_fan') }}"
  turn_on:
      oscillating: true
  turn_off:
      oscillating: false
input_boolean:
bedroom_fan_oscillation_state:
  name: "Bedroom Fan Oscillation State"
With this and bridging it all to homekit I can say any of the following:
Hey Siri, Turn on the Bedroom Fan
Hey Siri, Turn off the Bedroom Fan
Hey Siri, Turn on Bedroom Fan Oscillation
Hey Siri, Turn off Bedroom Fan Oscillation
Hey Siri, Increase the Bedroom Fan
Hey Siri, Decrease the Bedroom Fan
It also shows up in Homekit as a proper fan entity.
Just figured I would share here in case it helps anyone else.
I added in an input_boolean helper to track fan oscillation state. Updated my prior code to reflect all of that, every part of fan control for this previously dumb-fan works beautifully now.
Dears, I tried to follow the guide but when I switch on de the fan say me fan.set_percentage not found.
Some one can help me?
Here you have my files
alias: ventilador_habitacion_3_on
sequence:
  • service: remote.send_command
    device: ventilador habitación 3
    command: speed1
    entity_id: remote.habitacion_3_2
  • service: input_boolean.turn_on
    entity_id: input_boolean.ventilador_techo_habitacion_3_state
    data: {}
  • service: input_number.set_value
    entity_id: input_number.ventilador_habitacion_3
    value: 20
    mode: single
alias: ventilador_habitacion_3_off
sequence:
    command: “off”
  • service: input_boolean.turn_off
    data: {}
    value: 0
    mode: single
sequence:
    device: ventilador_habitacion_3
    command: speed1
  • delay:
    hours: 0
    minutes: 0
    seconds: 0
    milliseconds: 500
    command: speed2
  • delay:
    hours: 0
    minutes: 0
    seconds: 0
    milliseconds: 500
    command: speed3
  • delay:
    hours: 0
    minutes: 0
    seconds: 0
    milliseconds: 500
    command: speed4
  • delay:
    hours: 0
    minutes: 0
    seconds: 0
    milliseconds: 500
    command: speed5
    mode: single
    alias: ventilador_habitacion_3_inc
alias: ventilador_habitacion_3_set_speed
sequence:
    value: “{{ percentage }}”
  • delay:
    hours: 0
    minutes: 0
    seconds: 0
    milliseconds: 500
  • choose:
    • conditions:
      • condition: state
        state: “20.0”
        sequence:
      • service: script.ventilador_habitacion_3_inc
    • conditions:
      • condition: state
        state: “40.0”
        sequence:
    • conditions:
      • condition: state
        state: “60.0”
        sequence:
    • conditions:
      • condition: state
        state: “80.0”
        sequence:
    • conditions:
      • condition: state
        state: “100.0”
        sequence:
      • service:
  • platform: template
    fans:
    ventilador_habitacion_3:
    friendly_name: “ventilador habitación 3”
    unique_id: ventilador_habitacion_3
    value_template: “{{ states(‘input_boolean.ventilador_habitacion_3_state’) }}”
    percentage_template: “{{ states(‘input_number.ventilador_habitacion_3’) }}”
    turn_on:
    service: script.ventilador_habitacion_3_power_on
    turn_off:
    service: script.ventilador_habitacion_3_power_off
    set_percentage:
    service: script.ventilador_habitacion_3_set_speed
    percentage: ‘{{ percentage }}’
    speed_count: 5
This is so Cool~ Everything works perfect , Thanks for sharing
When I was using Scene to turn off all my living room’s devices, I found that when the fan was off, it would be turn on again by Automations or Scenes. but after add ‘‘Conditions’’, everything became normal. I would suggest to add ‘‘Conditions’’ in turn_on and turn_off
turn_on:
- condition: state
state: ‘off’
- service: script.bedroom_fan_power
turn_off:
- condition: state
state: ‘on’
Hi, did you find any solution for that?
I ended up buying a fan that had wifi
Hi! Thanks a lot for this guide. I have my fan working on HA but when using it on HomeKit the slider doesn’t work properly. When I move the percentage on HomeKit it doesn’t change on HA until the next change of percentage. Can you help me?
I got On and Off working but the others do not.
This is my FAN config:
  fans:
    work_room_fan:
      friendly_name: "Work Room Fan"
      unique_id: e244c3b5-0db9-4737-8656-4bffg5404287
      value_template: "{{ states('input_boolean.work_room_fan_state') }}"
      turn_on:
        - action: script.work_room_fan_1
            entity_id: input_number.work_room_fan_percentage
            value: 20
      turn_off:
        - action: script.work_room_fan_off
            value: 0
        {{ states('input_number.work_room_fan_percentage') if is_state('input_boolean.work_room_fan_state', 'on') else 0 }}
      speed_count: 5
      set_percentage:
        - action: input_boolean.turn_{{ 'on' if percentage > 0 else 'off' }}
            entity_id: input_boolean.work_room_fan_state
        - action: input_number.set_value
            value: "{{ percentage }}"
        - action: script.work_room_fan_set_speed
shelly (eg_luefter_01 & eg_luefter_02)
→ hardware & cabeling works, control/imitate both hw switches by webinterface or HA work as expected.
eg_luefter_01 eg_luefter_02 fan
OFF OFF OFF
ON OFF LOW
OFF ON MEDIUM
ON ON HIGH
configuration.yaml:
    fans:
      eg_luefter:
        friendly_name: "EG Lüfter"
        unique_id: "eg_luefter"
        preset_modes:
          - "off"
          - "low"
          - "medium"
          - "high"
        preset_mode_template: >-
          {% set s1 = is_state('switch.eg_luefter_01', 'on') %}
          {% set s2 = is_state('switch.eg_luefter_02', 'on') %}
          {% if not s1 and not s2 %}
            off
          {% elif s1 and not s2 %}
            low
          {% elif not s1 and s2 %}
            medium
          {% elif s1 and s2 %}
            high
          {% else %}
            off
          {% endif %}
        turn_on:
          service: script.set_luefter_mode
            mode: low
        turn_off:
            mode: off
        set_preset_mode:
          data_template:
            mode: "{{ mode }}"
script:
set_luefter_mode:
    alias: "Lüfter Mode"
    fields:
      mode:
        description: "fan mode"
        example: "off"
    sequence:
      - choose:
          - conditions:
              - condition: template
                value_template: "{{ mode == 'off' }}"
            sequence:
              - service: switch.turn_off
                  entity_id:
                    - switch.eg_luefter_01
                    - switch.eg_luefter_02
          - conditions:
                value_template: "{{ mode == 'low' }}"
            sequence:
              - service: switch.turn_on
                  entity_id: switch.eg_luefter_01
                  entity_id: switch.eg_luefter_02
          - conditions:
                value_template: "{{ mode == 'medium' }}"
            sequence:
          - conditions:
                value_template: "{{ mode == 'high' }}"
            sequence:
                  entity_id:
what am I doing wrong here?
thanks for help
Thank you so much Chris for sharing your guide as it was very helpful when I was doing the same exact thing to control my ceiling fan via broadlink rm4 pro ir/rf controller.
I made some updates using your guide as a baseline to share with everyone if you guys want to do something similar. My goal was to emulate the fan template just like an actual fan template entity so I added the added ability to turn on the fan to the last speed it was set to instead of a default speed of 1.
# Keep track of the fan state
input_boolean:
  bedroom_fan_state:
# Keep track of fan speed
input_number:
  bedroom_fan_speed:
    name: Bedroom Fan Percentage
    min: 0
    max: 100
# Keep track of the fan last speed
iinput_number:
  bedroom_fan_last_speed:
    min: 0
    max: 100
Fan ON/OFF Script
bedroom_fan_on_off:
  sequence:
  - alias: Fan ON/OFF
    choose:
    - conditions:
      - condition: state
        entity_id: input_boolean.bedroom_fan_state
        state:
        - 'off'
      sequence:
      - alias: Copy value from Fan Speed Helper to Last Fan Speed Helper
        metadata: {}
          value: '{{ states(''input_number.bedroom_fan_speed'') }}'
          entity_id:
          - input_number.bedroom_fan_last_speed
      - alias: Set Fan Speed Helper to 0
        metadata: {}
          entity_id:
          - input_number.bedroom_fan_speed
          value: 0
      - action: script.bedroom_fan_send_command
        metadata: {}
        data: {}
      alias: Fan OFF
    - conditions:
      - condition: state
        state:
        - 'on'
      sequence:
      - alias: Copy value from Last Speed Helper to Fan Speed Helper
        metadata: {}
          entity_id:
          value: '{{ states(''input_number.bedroom_fan_last_speed'') }}'
        metadata: {}
        data: {}
      alias: Fan ON
  alias: Bedroom_Fan_ON/OFF
  description: ''
Set Fan Speed Script
bedroom_fan_set_speed:
  sequence:
    - if:
          value_template: "{{ percentage == 0 }}"
          alias: If returned percentage == 0 from Fan Template
      then:
        - if:
            - condition: state
              entity_id: input_number.bedroom_fan_speed
              state:
                - "0.0"
          then: []
          else:
            - action: input_boolean.turn_off
              metadata: {}
              data: {}
              enabled: true
            - action: script.bedroom_fan_on_off
              metadata: {}
              data: {}
              enabled: true
      else:
        - alias: >-
            Copy returned Percentage from Fan Template to Bedroom_Fan_Speed Input
            Number
          metadata: {}
            entity_id:
        - action: input_boolean.turn_on
          metadata: {}
          data: {}
          metadata: {}
          data: {}
  alias: Bedroom_Fan_Set_Speed
  description: ""
Bedroom Fan Send Command Script
bedroom_fan_send_command:
  sequence:
    - choose:
        - conditions:
            - condition: state
              state:
                - "0.0"
          sequence:
            - alias: Send Fan OFF Command to Bedroom Fan
              action: remote.send_command
                entity_id: remote.broadlink_rm4_pro
                device: Bedroom fan
                command: fan off
              enabled: false
        - conditions:
            - condition: state
              state:
                - "33.0"
          sequence:
            - action: remote.send_command
                device: Bedroom fan
                command: low speed
              enabled: false
              alias: Send Low Speed Command to Bedroom Fan
          alias: >-
            If Bedroom_Fan_Speed is 33, send Low Speed Command to Bedroom
            Fan
        - conditions:
            - condition: state
              state:
                - "66.0"
          sequence:
                device: Bedroom fan
                command: medium speed
              enabled: false
              alias: Send Medium Speed Command to Bedroom Fan
          alias: >-
            If Bedroom_Fan_Speed is 66, send Medium Speed Command to
            Bedroom Fan
        - conditions:
            - condition: state
              state:
                - "100.0"
          sequence:
                device: Bedroom room fan
                command: high speed
              enabled: false
              alias: Send High Speed Command to Bedroom Fan
          alias: >-
            If Bedroom_Fan_Speed is 100, send High Speed Command to Bedroom
            Fan
  alias: Bedroom_Fan_Send_Command
  description: >-
    Sends RF Commands to Fan to set Fan speed based on bedroom_fan_speed helper
Fan Template Created through GUI
Create new helper → template → fan
State Field:
{{ states('input_boolean.bedroom_fan_state') }}
Actions to Turn on:
data: {}
metadata: {}
data: {}
metadata: {}
response_variable: bedroom_fan_template_state
Actions to Turn off:
data: {}
metadata: {}
data: {}
metadata: {}
Percentage Field:
{{ states('input_number.bedroom_fan_speed') }}
Actions to set percentage:
action: script.bedroom_fan_set_speed
  percentage: "{{ percentage }}"
metadata: {}
Speed Count: 3
