GUITION 4" 480x480 ESP32-S3-4848S040 Smart Display with LVGL
Both codes I copy and paste from ESPHome pages.
Climate control from LVGL: Tips and Tricks — ESPHome
  - platform: homeassistant
    entity_id: climate.room_thermostat
    attribute: temperature
    on_value:
      - lvgl.spinbox.update:
          value: !lambda return x;
lvgl:
    pages:
      - id: thermostat_control
        widgets:
          - obj:
              align: BOTTOM_MID
              y: -50
              layout:
                type: FLEX
                flex_flow: ROW
                flex_align_cross: CENTER
              width: SIZE_CONTENT
              height: SIZE_CONTENT
              widgets:
                - btn:
                    on_click:
                      - lvgl.spinbox.decrement: spinbox_id
                    widgets:
                      - label:
                           text: "-"
                - spinbox:
                    align: CENTER
                    text_align: CENTER
                    width: 50
                    range_from: 15
                    range_to: 35
                    step: 0.5
                    rollover: false
                    digits: 3
                    decimal_places: 1
                    on_value:
                      then:
                        - homeassistant.service:
                            service: climate.set_temperature
                              temperature: !lambda return x;
                - btn:
                    on_click:
                      - lvgl.spinbox.increment: spinbox_id
                    widgets:
                      - label:
                          text: "+"
AntiBurn from same page
time:
  - platform: ...
    on_time:
      - hours: 2,3,4,5
        minutes: 5
        seconds: 0
        then:
          - switch.turn_on: switch_antiburn
      - hours: 2,3,4,5
        minutes: 35
        seconds: 0
        then:
          - switch.turn_off: switch_antiburn
switch:
    icon: mdi:television-shimmer
    optimistic: true
    entity_category: "config"
    turn_on_action:
      - logger.log: "Starting Antiburn"
      - if:
          condition: lvgl.is_paused
          then:
            - lvgl.resume:
            - lvgl.widget.redraw:
            - delay: 1s
      - lvgl.pause:
          show_snow: true
    turn_off_action:
      - logger.log: "Stopping Antiburn"
      - if:
          then:
            - lvgl.resume:
            - delay: 1s
            - lvgl.pause:
touchscreen:
  - platform: ...
    on_release:
      then:
        - if:
            then:
              - lvgl.resume:
Got to say I am having problems searching through the code here on my tablet. It’ll be easier on my laptop later.
Re spinbox
In post 31, you gave the code I thought you were wrking with, and it only contained the term spinbox in two places, at lines 165 and 166. With some surrounding context those lines are
################HVAC####################
  #- platform: homeassistant
   #id: room_thermostat
    #entity_id: climate.room_thermostat
    #attribute: temperature
    #on_value:
      #- lvgl.spinbox.update:
          #id: spinbox_id
          #value: !lambda return x;
So no wonder it didn’t work because you hadn’t defined spinbox_id.
So perhaps correct your code and try compiling again.
Re antiburn
No logs, no issue.
Will try again( not good with code, still learning), but Antiburn , don’t even let me recompile my code( will try again too)
Thank you for your respond and try these codes
So, I tried and have the same error:
nickrout, please , if you don’t mind to check my code. Climate control is on the second page:
substitutions:
  friendly_name: "Touch Panel"
  device_description: "Guition ESP32-S3-4848S040 480*480 Smart Screen"
  project_name: "Guition.ESP32_S3_4848S040"
  project_version: "1.0.0"
  lightbulb: "\U000F0335"
  ceiling_light: "\U000F0769"
  lamp: "\U000F06B5"
  floor_lamp: "\U000F08DD"
  string_lights: "\U000F12BA"
  clock: "\U000F0150"
  ceiling_fan: "\U000F1797"
  light_recessed: "\U000F179B"
  blinds_horizontal: "\U000F1A2B"
  blinds_horizontal_closed: "\U000F1A2C"
  curtains_closed: "\U000F1847"
  curtains: "\U000F1846"
  wallsconce: "\U000F091C"
  bed: "\U000F02E3"
  bed_empty: "\U000F08A0"
  thermometer_high: "\U000F10C2"
  humidity: "\U000F058E"
  wallsconce_variant: "\U000F091E"
  kiss: "\U000F0C73"
  hvac: "\U000F0D43"
esphome:
  friendly_name: "${friendly_name}"
  #name_add_mac_suffix: true
  project:
    version: "${project_version}"
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  flash_size: 16MB
  framework:
    type: esp-idf
    sdkconfig_options:
      COMPILER_OPTIMIZATION_SIZE: y
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
psram:
  mode: octal
  speed: 80MHz
logger:
api:
  encryption:
    key: "  "
ota:
  password: "  "
  platform: esphome
wifi:
  ssid: !secret wifi_ssid
web_server:
  port: 80
external_components:
 - source: github://clydebarrow/esphome@lvgl_original
   refresh: 10min
   components: [ lvgl ]
time:
  - platform: sntp
    timezone: America/New_York
    servers:
     - 0.pool.ntp.org
     - 1.pool.ntp.org
     - 2.pool.ntp.org
    on_time_sync:
      - script.execute: time_update
    on_time:
      - minutes: '*'
        seconds: 0
        then:
############ AntiBurn ################
script:
  - id: time_update
    then:
      - lvgl.label.update:
          text: !lambda |-
            static char time_buf[17];
            auto now = id(sntp_time).now();
            bool is_pm = now.hour >= 12;
            int hour_12 = now.hour % 12;
            if (hour_12 == 0) {
                hour_12 = 12; // 12 AM/PM should be displayed as 12, not 0
            snprintf(time_buf, sizeof(time_buf), "%2d:%02d%s", hour_12, now.minute, is_pm ? "pm" : "am");
            return time_buf;
###################Temp and Humidity ################
    entity_id: sensor.atc_7997_temperature
    on_value:
          text:
            format: "\U000F10C3 %.1f \U000F0504"
            args: [ 'x' ]
    entity_id: sensor.atc_7997_humidity
    on_value:
          text:
            format: "\U000F058E %.1f \U000F03F0"
            args: [ 'x' ]
#Fan#
    entity_id: fan.master_fan
    attribute: set_percentage
    on_value:
      - lvgl.slider.update:
    on_value:
############Cover##############
    entity_id: cover.shades_curtain
    attribute: current_position
    on_value:
      - if:
            lambda: |-
              return x == 100;
          then:
            - lvgl.widget.update:
                text_opa: 60%
          else:
                text_opa: 100%
      - if:
            lambda: |-
              return x == 0;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
text_sensor:
    on_value:
      - if:
            lambda: |-
              return ((0 == x.compare(std::string{"opening"})) or (0 == x.compare(std::string{"closing"})));
          then:
                text: "STOP"
          else:
                text:
                  format: "%.0f%%"
                  args: [ 'id(cover_myroom_pos).get_state()' ]
################### Red Lights #######################
switch:
  - platform: lvgl
    widget: lv_button_8
    on_turn_on:
      then:
            text_color: 0xFFFF00
    on_turn_off:
      then:
            text_color: 0xB6B6B6
################binary_sensors###############
# Lights#
binary_sensor:
    entity_id: light.over_the_bed_lights
    publish_initial_state: true
    on_state:
      then:
        lvgl.widget.update:
          state:
            checked: !lambda return x;
    entity_id: light.mirror_lighs
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.tv_lights
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.irina_s_wall_light
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.bed_occupancy_sensor_yevgeniy_lights
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.my_wall_light
    on_state:
      then:
        lvgl.widget.update:
          state:
#Fan#
    on_state:
      then:
        lvgl.widget.update:
          state:
#Covers#
    entity_id: cover.master_bedroom_all_covers
    on_state:
      then:
        lvgl.widget.update:
          state:
################lvgl Buttons################
lvgl:
  displays:
    - display_id: my_display
  touchscreens:
    - touchscreen_id: my_touchscreen
  on_idle:
    timeout: 90s
    then:
      - logger.log: "LVGL is idle"
      - light.turn_off: backlight
      - lvgl.pause:
##########Pages####################
  top_layer:
    widgets:
      - label:
          text_font: roboto24
          text: "00:00 am"
          align: bottom_mid
          #x: -2
          y: -10
          text_align: right
          text_color: 0xFFFFFF
      - label:
          text_font: roboto24
          text: "-.- %"
          align: bottom_right
          x: -20
          y: -10
          text_align: right
          on_press:
            then:
              - lvgl.page.show: second_page
      - label:
          text_font: roboto24
          text: "-.-°C"
          align: bottom_left
          x: 12
          y: -10
          #text_align: right
          on_press:
            then:
              - lvgl.page.show: main_page
  style_definitions:
    - id: style_line
      line_color: 0x0000FF
      line_width: 8
      line_rounded: true
    - id: date_style
      text_font: roboto24
      align: center
      text_color: 0x333333
      bg_opa: cover
      radius: 4
      pad_all: 2
####Header_Footer##########
    - id: header_footer
      bg_color: 0x0C7B5F
      bg_grad_color: 0x03291F
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 0
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      border_color: 0x0077b3
      width: 100%
      height: 40
  theme:
    btn:
      text_font: roboto24
      scroll_on_focus: true
      group: general
      radius: 25
      width: 150
      height: 97
      pad_left: 10px
      pad_top: 10px
      pad_bottom: 10px
      pad_right: 10px
      shadow_width: 0
      bg_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
    obj:
      text_font: roboto24
      group: general
      radius: 25
      width: 150
      height: 97
      pad_left: 10px
      pad_top: 10px
      pad_bottom: 10px
      pad_right: 10px
      shadow_width: 0
      bg_color: 0x0C7B5F
      border_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
  page_wrap: true
  pages:
    - id: main_page
      skip: true
      layout: flex
      flex_flow: row_WRAP
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      pad_all: 5
      widgets:
        - obj:
            #height: 207
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $light_recessed
              - label:
                  align: bottom_mid
                  text: "Bed Lights"
                  long_mode: dot
            on_short_click:
                  service: light.toggle
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_mid
              - label:
                  align: bottom_mid
                  text: "Mirror Lights"
                  long_mode: dot
            on_short_click:
        - obj:
           # width: 207
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
              - label:
                  align: bottom_mid
                  text: "TV Lights"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $wallsconce_variant
              - label:
                  align: bottom_mid
                  text: "Irina Light"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_mid
                  text: $bed
              - label:
                  align: bottom_mid
                  text: "Under Bed"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
              - label:
                  align: bottom_mid
                  text: "My Light"
                  long_mode: dot
            on_short_click:
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $hvac
              - label:
                  align: bottom_left
                  text: "Hvac"
                  long_mode: dot
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
                  text: $kiss
              - label:
                  align: bottom_right
                  text: "Intim"
                  long_mode: dot
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $ceiling_fan
              - label:
                  align: bottom_left
                  text: "Fan"
                  long_mode: dot
              - slider:
                  x: 90
                  y: 25
                  width: 130
                  height: 10
                  indicator:
                    bg_color: 0x0C7B5F
                  knob:
                    bg_color: 0x0C7B5F
                  #pad_all: 8
                  value: 75
                  min_value: 0
                  max_value: 100
                  adv_hittest: true
                  on_release:
                        service: fan.turn_on
                          percentage: !lambda return int(x);
            on_short_click:
                  service: fan.toggle
            on_press:
                  service: fan.set_percentage
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
                  text: $curtains
              - label:
                  align: bottom_right
                  text: "Curtains"
                  long_mode: dot
            on_short_click:
                  service: cover.toggle
    - id: second_page
      skip: true
      layout: flex
      flex_flow: row_WRAP
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      pad_all: 5
      widgets:
############## Covers###################
          - btn:
              x: 10
              y: 30
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text:  "\U000F0143"
              on_press:
                then:
                      service: cover.open
          - btn:
              x: 10
              y: 103
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text: STOP
              on_press:
                then:
                      service: cover.stop
          - btn:
              x: 10
              y: 178
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text: "\U000F0140"
              on_press:
                then:
                      service: cover.close
          - obj:
              align: BOTTOM_MID
              y: -50
              layout:
                type: FLEX
                flex_flow: ROW
              width: SIZE_CONTENT
              widgets:
                - btn:
                    on_click:
                      - lvgl.spinbox.decrement: spin_box
                    widgets:
                      - label:
                           text: "-"
                - spinbox:
                    align: CENTER
                    text_align: CENTER
                    width: 50
                    range_from: 15
                    range_to: 35
                    step: 0.5
                    rollover: false
                    digits: 3
                    decimal_places: 1
                    on_value:
                      then:
                - btn:
                    on_click:
                      - lvgl.spinbox.increment: spin_box
                    widgets:
                      - label:
                          text: "+"
# Internal outputs
output:
    # Backlight LED
  - platform: ledc
    pin: GPIO38
    frequency: 100Hz
    # Built in 120v relay
  - id: internal_relay_1
    platform: gpio
    pin: 40
# LIGHTS
light:
  - platform: monochromatic
    output: GPIO38
    restore_mode: ALWAYS_ON
# Graphicsd and Fonts
image:
  - file: https://esphome.io/_images/logo.png
    resize: 200x200
    type: RGB565
  - file: "fonts/wall-sconce-180.svg"
    resize: 20x20
font:
  - file: "gfonts://Roboto"
    bpp: 4
    extras:
      - file: 'fonts/materialdesignicons-webfont.ttf' # http://materialdesignicons.com/cdn/7.4.47/
        glyphs: [
          "\U000F004B",
          "\U0000f0ed",
          "\U000F006E",
          "\U000F012C",
          "\U000F179B",
          "\U000F0748",
          "\U000F1A1B",
          "\U000F02DC",
          "\U000F0A02",
          "\U000F035F",
          "\U000F0156",
          "\U000F0C5F",
          "\U000f0084",
          "\U000f0091",
          "\U000F058E",
          "\U000F10C3",
          "\U000F03F0", # mdi-percent
          "\U000F0504", # mdi- celcius
          "\U000F091E",
          "\U000F0143", # mdi-arrow_up
          "\U000F0140", # mdi-arrow_down
    bpp: 4
    glyphs: &mdi-weather-glyphs
      - "\U000F0590" # mdi-weather-cloudy
      - "\U000F0F2F" # mdi-weather-cloudy-alert
      - "\U000F0E6E" # mdi-weather-cloudy-arrow-right
      - "\U000F0591" # mdi-weather-fog
      - "\U000F0592" # mdi-weather-hail
      - "\U000F0F30" # mdi-weather-hazy
      - "\U000F0898" # mdi-weather-hurricane
      - "\U000F0593" # mdi-weather-lightning
      - "\U000F067E" # mdi-weather-lightning-rainy
      - "\U000F0594" # mdi-weather-clear-night
      - "\U000F0F31" # mdi-weather-night-partly-cloudy
      - "\U000F0595" # mdi-weather-partly-cloudy
      - "\U000F0F32" # mdi-weather-partly-lightning
      - "\U000F0F33" # mdi-weather-partly-rainy
      - "\U000F0F34" # mdi-weather-partly-snowy
      - "\U000F0F35" # mdi-weather-partly-snowy-rainy
      - "\U000F0596" # mdi-weather-pouring
      - "\U000F0597" # mdi-weather-rainy
      - "\U000F0598" # mdi-weather-snowy
      - "\U000F0F36" # mdi-weather-snowy-heavy
      - "\U000F067F" # mdi-weather-snowy-rainy
      - "\U000F0599" # mdi-weather-sunny
      - "\U000F0F37" # mdi-weather-sunny-alert
      - "\U000F14E4" # mdi-weather-sunny-off
      - "\U000F059A" # mdi-weather-sunset
      - "\U000F059B" # mdi-weather-sunset-down
      - "\U000F059C" # mdi-weather-sunset-up
      - "\U000F0F38" # mdi-weather-tornado
      - "\U000F059D" # mdi-weather-windy
      - "\U000F059E" # mdi-weather-windy-variant
    bpp: 4
    glyphs: [
      "\U000F0335", # mdi-lightbulb
      "\U000F0769", # mdi-ceiling-light
      "\U000F08DD", # mdi-floor-lamp
      "\U000F12BA", # mdi-string-lights
      "\U000F0150", # mdi-clock
      "\U000F1797", # mdi-ceiling_fan
      "\U000F179B", # mdi-light_recessed
      "\U000F1A2B", # mdi-blinds_horizontal
      "\U000F1A2C", # mdi-blinds_horizontal_closed
      "\U000F1847", # mdi-curtains_closed
      "\U000F1846", # mdi-curtains
      "\U000F091C", # mdi-wallsconce
      "\U000F02E3", # mdi-bed
      "\U000F08A0", # mdi-bed_empty
      "\U000F10C2", # mdi-thermometer_high
      "\U000F058E", # mdi-humidity
      "\U000F091E", # mdi-wallsconce_variant
      "\U000F0C73", # mdi-kiss
      "\U000F0D43", # mdi- hvac
    bpp: 4
# Touchscreen gt911 i2c
i2c:
  - id: bus_a
    sda: GPIO19
    scl: GPIO45
    #frequency: 100kHz
touchscreen:
  platform: gt911
  transform:
    mirror_x: false
    mirror_y: false
  display: my_display
  on_touch:
    - logger.log:
          format: Touch at (%d, %d)
          args: [touch.x, touch.y]
    - lambda: |-
          ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
  on_release:
    - if:
        then:
          - logger.log: "LVGL resuming"
          - lvgl.resume:
          - light.turn_on: backlight
# Display st7701s spi
spi:
  - id: lcd_spi
    clk_pin: GPIO48
    mosi_pin: GPIO47
display:
  - platform: st7701s
    update_interval: never
    auto_clear_enabled: True
    data_rate: 2MHz
    spi_mode: MODE3
    color_order: RGB
    invert_colors: false
    dimensions:
      width: 480
      height: 480
    transform:
      mirror_x: false
      mirror_y: false
    cs_pin: 39
      # reset not defined
    de_pin: 18
    hsync_pin: 16
    vsync_pin: 17
    pclk_pin: 21
    init_sequence:
      - 1
      - [0xFF, 0x77, 0x01, 0x00, 0x00, 0x10] # CMD2_BKSEL_BK0
      - [0xCD, 0x00] # disable MDT flag
    pclk_frequency: 12MHz
    pclk_inverted: false
    data_pins:
      red:
        - 11         # R1
        - 12         # R2
        - 13         # R3
        - 14         # R4
        - 0          # R5
      green:
        - 8          # G0
        - 20         # G1
        - 3          # G2
        - 46         # G3
        - 9          # G4
        - 10         # G5
      blue:
        - 4          # B1
        - 5          # B2
        - 6          # B3
        - 7          # B4
        - 15         # B5
Thank you
I am playing around with a round touch capacitive display
HA Forum related thread
The example in the above thread works perfectly.
I woul like however to use the much more evoluted LVGL libs.
I tried adding the external component but so far I had little success.
What are the prerequisite to use a touch display witht the newly developed lvgl lib?
Still no luck with spinbox
I know this 1
I think that this piece of code
    on_value:
Should be
    on_value:
      then:
See the documentation here Sensor Component — ESPHome
Thank you for your help, but still nothing
substitutions:
  lamp: "\U000F06B5"
  clock: "\U000F0150"
  bed: "\U000F02E3"
  kiss: "\U000F0C73"
  hvac: "\U000F0D43"
esphome:
  project:
  platformio_options:
esp32:
  variant: esp32s3
  flash_size: 16MB
  framework:
    type: esp-idf
    sdkconfig_options:
psram:
  mode: octal
  speed: 80MHz
logger:
api:
  encryption:
    key: "api key"
ota:
  password: "ota password"
  platform: esphome
wifi:
web_server:
  port: 80
   refresh: 10min
time:
  - platform: sntp
    servers:
     - 0.pool.ntp.org
     - 1.pool.ntp.org
     - 2.pool.ntp.org
    on_time_sync:
    on_time:
      - minutes: '*'
        seconds: 0
        then:
      #- hours: 2,3,4,5
       # minutes: 5
        #seconds: 0
        #then:
         # - switch.turn_on: switch_antiburn
      #- hours: 2,3,4,5
       # minutes: 35
       # seconds: 0
        #then:
         # - switch.turn_off: switch_antiburn
script:
  - id: time_update
    then:
          text: !lambda |-
            if (hour_12 == 0) {
            return time_buf;
    on_value:
          text:
            args: [ 'x' ]
    on_value:
          text:
            args: [ 'x' ]
#Fan#
    on_value:
    entity_id: climate.upstairs
    on_value:
      then:
    on_value:
      - if:
            lambda: |-
              return x == 100;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
      - if:
            lambda: |-
              return x == 0;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
text_sensor:
    on_value:
      - if:
            lambda: |-
          then:
                text: "STOP"
          else:
                text:
                  format: "%.0f%%"
switch:
  - platform: lvgl
    widget: lv_button_8
    on_turn_on:
      then:
    on_turn_off:
      then:
###################### AntiBurn#####################
  #- platform: template
   # id: switch_antiburn
   # icon: mdi:television-shimmer
    #optimistic: true
   # entity_category: "config"
    #turn_on_action:
      #- logger.log: "Starting Antiburn"
     # - if:
          #condition: lvgl.is_paused
          #then:
            #- lvgl.resume:
           # - lvgl.widget.redraw:
            #- delay: 1s
      #- lvgl.pause:
         # show_snow: true
    #turn_off_action:
      #- logger.log: "Stopping Antiburn"
      #- if:
          #then:
           # - lvgl.resume:
            #- lvgl.widget.redraw:
            #- delay: 1s
            #- lvgl.pause:
# Lights#
binary_sensor:
    on_state:
      then:
        lvgl.widget.update:
          state:
    on_state:
      then:
        lvgl.widget.update:
          state:
    on_state:
      then:
        lvgl.widget.update:
          state:
    on_state:
      then:
        lvgl.widget.update:
          state:
    on_state:
      then:
        lvgl.widget.update:
          state:
    on_state:
      then:
        lvgl.widget.update:
          state:
#Fan#
    on_state:
      then:
        lvgl.widget.update:
          state:
#Covers#
    on_state:
      then:
        lvgl.widget.update:
          state:
#number:
  # __________________________________________________ backlight timeout
    #name: Backlight Timeout
    #optimistic: true
    #id: backlight_timeout
    #unit_of_measurement: "s"
    #initial_value: 30
    #restore_value: true
    #min_value: 10
    #max_value: 90
    #step: 10
    #mode: auto # auto / box / slider
lvgl:
  displays:
  touchscreens:
  on_idle:
    timeout: 90s ###!lambda "return (id(backlight_timeout).state * 1000);" ##fiture use##
    then:
      - lvgl.pause:
  top_layer:
    widgets:
      - label:
          text_font: roboto24
          text: "00:00 am"
          align: bottom_mid
          #x: -2
          y: -10
          text_align: right
      - label:
          text_font: roboto24
          text: "-.- %"
          align: bottom_right
          x: -20
          y: -10
          text_align: right
          on_press:
            then:
      - label:
          text_font: roboto24
          text: "-.-°C"
          align: bottom_left
          x: 12
          y: -10
          #text_align: right
          on_press:
            then:
  style_definitions:
    - id: style_line
      line_width: 8
      line_rounded: true
    - id: date_style
      text_font: roboto24
      align: center
      bg_opa: cover
      radius: 4
      pad_all: 2
    - id: header_footer
      bg_color: 0x0C7B5F
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 0
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      width: 100%
      height: 40
  theme:
    btn:
      text_font: roboto24
      group: general
      radius: 25
      width: 150
      height: 97
      pad_left: 10px
      pad_top: 10px
      pad_bottom: 10px
      pad_right: 10px
      shadow_width: 0
      bg_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
    obj:
      text_font: roboto24
      group: general
      radius: 25
      width: 150
      height: 97
      pad_left: 10px
      pad_top: 10px
      pad_bottom: 10px
      pad_right: 10px
      shadow_width: 0
      bg_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
  page_wrap: true
  pages:
    - id: main_page
      skip: true
      layout: flex
      flex_flow: row_WRAP
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      pad_all: 5
      widgets:
        - obj:
            #height: 207
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
              - label:
                  align: bottom_mid
                  text: "Bed Lights"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_mid
              - label:
                  align: bottom_mid
                  long_mode: dot
            on_short_click:
        - obj:
           # width: 207
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
              - label:
                  align: bottom_mid
                  text: "TV Lights"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
              - label:
                  align: bottom_mid
                  text: "Irina Light"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_mid
                  text: $bed
              - label:
                  align: bottom_mid
                  text: "Under Bed"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
              - label:
                  align: bottom_mid
                  text: "My Light"
                  long_mode: dot
            on_short_click:
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $hvac
              - label:
                  align: bottom_left
                  text: "Hvac"
                  long_mode: dot
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
                  text: $kiss
              - label:
                  align: bottom_right
                  text: "Intim"
                  long_mode: dot
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $ceiling_fan
              - label:
                  align: bottom_left
                  text: "Fan"
                  long_mode: dot
              - slider:
                  x: 90
                  y: 25
                  width: 130
                  height: 10
                  indicator:
                    bg_color: 0x0C7B5F
                  knob:
                    bg_color: 0x0C7B5F
                  #pad_all: 8
                  value: 75
                  min_value: 0
                  max_value: 100
                  adv_hittest: true
                  on_release:
            on_short_click:
                  service: fan.toggle
            on_press:
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
                  text: $curtains
              - label:
                  align: bottom_right
                  text: "Curtains"
                  long_mode: dot
            on_short_click:
    - id: second_page
      skip: true
      layout: flex
      flex_flow: row_WRAP
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      pad_all: 5
      widgets:
          - btn:
              x: 10
              y: 30
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text:  "\U000F0143"
              on_press:
                then:
                      service: cover.open
          - btn:
              x: 10
              y: 103
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text: STOP
              on_press:
                then:
                      service: cover.stop
          - btn:
              x: 10
              y: 178
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text: "\U000F0140"
              on_press:
                then:
####################HVAC##############################
          - obj:
              align: BOTTOM_MID
              y: -50
              layout:
                type: FLEX
                flex_flow: ROW
              width: SIZE_CONTENT
              widgets:
                - btn:
                    on_click:
                    widgets:
                      - label:
                           text: "-"
                - spinbox:
                    align: CENTER
                    text_align: CENTER
                    width: 50
                    range_from: 15
                    range_to: 35
                    step: 0.5
                    rollover: false
                    digits: 3
                    decimal_places: 1
                    on_value:
                      then:
                - btn:
                    on_click:
                    widgets:
                      - label:
                          text: "+"
# Internal outputs
output:
    # Backlight LED
  - platform: ledc
    pin: GPIO38
    frequency: 100Hz
    platform: gpio
    pin: 40
# LIGHTS
light:
    output: GPIO38
image:
    resize: 200x200
    type: RGB565
    resize: 20x20
font:
    bpp: 4
    extras:
        glyphs: [
          "\U000F004B",
          "\U0000f0ed",
          "\U000F006E",
          "\U000F012C",
          "\U000F179B",
          "\U000F0748",
          "\U000F1A1B",
          "\U000F02DC",
          "\U000F0A02",
          "\U000F035F",
          "\U000F0156",
          "\U000F0C5F",
          "\U000f0084",
          "\U000f0091",
          "\U000F058E",
          "\U000F10C3",
          "\U000F091E",
    bpp: 4
    bpp: 4
    glyphs: [
    bpp: 4
i2c:
  - id: bus_a
    sda: GPIO19
    scl: GPIO45
    #frequency: 100kHz
touchscreen:
  platform: gt911
  transform:
    mirror_x: false
    mirror_y: false
  display: my_display
  on_touch:
    - logger.log:
    - lambda: |-
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
  on_release:
    then:
      - if:
          then:
            - lvgl.resume:
spi:
  - id: lcd_spi
    clk_pin: GPIO48
    mosi_pin: GPIO47
display:
  - platform: st7701s
    data_rate: 2MHz
    spi_mode: MODE3
    color_order: RGB
    dimensions:
      width: 480
      height: 480
    transform:
      mirror_x: false
      mirror_y: false
    cs_pin: 39
      # reset not defined
    de_pin: 18
    hsync_pin: 16
    vsync_pin: 17
    pclk_pin: 21
    init_sequence:
      - 1
    data_pins:
      red:
        - 11         # R1
        - 12         # R2
        - 13         # R3
        - 14         # R4
        - 0          # R5
      green:
        - 8          # G0
        - 20         # G1
        - 3          # G2
        - 46         # G3
        - 9          # G4
        - 10         # G5
      blue:
        - 4          # B1
        - 5          # B2
        - 6          # B3
        - 7          # B4
        - 15         # B5
I hate to say it, but are you absolutely sure that the version of lvgl you are pulling has lvgl.spinbox.update? Perhaps put an issue on the author’s GitHub?
No,I am not sure about that but it’s the same what is in original code from first post here. Will do
Thank you
spinbox is only in the latest code. Use this include and it will work.
  - source:
      type: git
      url: https://github.com/clydebarrow/esphome
      ref: 82264dc2440981873b8400d613e0cc32d229daa3 #previous commit - wont be needed in the future
Will try tonight. TY
Your yaml is not the same as the yaml in the first post here. There is no mention of spinbox at all in the first post.
So, it’s mean I can’t use spinbox in my yaml code?
Or it’s some work around to make it work in my code.
Change an external component to one which Andrew refer to, and now bunch of errors pop up
No logs = no issue.
working on it :grinning:
2)
3)
Please do not put images of code, insert it as code
f6be36681e0da431418ec7781fb6c62712941803
