AndyD
(Andy Dann)
September 5, 2024, 8:03am
204
For a string try…
- lvgl.label.update:
text:
format: "%s"
args: [ 'id(sensor_offset).state.c_str()' ]
For numbers…
text:
format: "%.0f%%"
args: id(crowpanel_wifi).state
domain_int
(domain int)
September 5, 2024, 8:52am
205
Thanks @AndyD . Works a treat.
Need to figure out how to get it to update on a reboot. Unfortunately it only updates on a state change despite
number:
restore_value: True
Ive tried
on_boot:
then:
which would be the obvious choice, but Im assuming that the lvgl stuff isnt up and running at on_boot
Any ideas???
pepe59
(Pepe59)
September 5, 2024, 8:53am
206
I noticed that you have a build on git
Suntion ESP32-8048S070C.
I have ESP32-8048S050C. Is it possible to use your build for this display? I assume the GPIO layout will be the same, but I’m not sure.
Qbhatti
September 5, 2024, 9:29am
207
Thats worked wonders.I now have the single button.
I have had a little play around and managed to draw another button on it.
Thank you for your help -it is much appreciated.
now I need to work out how to get it to do somethign in HA.
AndyD
(Andy Dann)
September 5, 2024, 12:19pm
208
I had a similar problem with some temp readings after a restart and the following worked for me.
Ignore the conditional bit, that’s just to change the text colour. I believe using the lvgl.widget_update rather than the label update may do the trick.
- platform: homeassistant
entity_id: sensor.lounge_temp_temperature
on_value:
- if:
condition:
sensor.in_range:
below: 5.0
then:
- lvgl.widget.update:
text_color: 0x4285F4
domain_int
(domain int)
September 5, 2024, 11:59pm
209
Unfortunaely, doesnt work.
Even tried this:
on_value:
then:
text:
format: "%.1f"
args: id(sensor_offset).state
and still no joy
Try this:
- label:
text_font: barlow120
text_color: 0xFFFFFF
x: 140
y: 110
text:
format: "%.1f"
args: [ 'id(sensor_offset).state' ]
number:
optimistic: true
min_value: -2.0
max_value: 2.0
restore_value: True
step: 0.1
unit_of_measurement: "°C"
on_value:
text:
format: "%.1f"
args: [ 'x' ]
domain_int
(domain int)
September 6, 2024, 7:54am
211
@walberjunior TQ TQ Tq - Legend-waitforit-dary
TQ so much for this - amazing how [ ]
can change everything.
Proper syntax is a learning stategy for me.
domain_int
(domain int)
September 6, 2024, 1:14pm
212
Sorry but Im going to be annoying in the next few weeks.
Apologies in advance to everyone.
Can I ask…is a page a widget???
Can someone give me a hint as to how to go about changing the background bg_image_src:
of a page dynamically based on the status of a sensor??? Or is it not possible???
Essentially I have a background image on a page that is based on the status of a temp sensor and want to change the background based on the temp of the sensor.
eg:
pages:
- id: page1
skip: true
bg_image_src: template1_image # <- How do i change this based on the state of a sensor?????
bg_opa: cover
pad_all: 2
widgets:
BTW, this group/chat is amazing… learned so much and everyone is discovering something new.
reliable
(Bob MRPL Reliable)
September 6, 2024, 1:56pm
213
Hello everyone!
So, I’m messing around with LVGL…
I need to change the icons for the label depending on the state of the button. The icons can be different. And what’s interesting…
If I do it like this:
- file: "gfonts://Inter"
bpp: 4
glyphs: |-
!"%()+=,-_.:$\°0123456789АБВГДЕЁЖЗИЙКЛМНОПРСТУФХЦЧШЩЬЫЪЭЮЯABCDEFGHIJKLMNOPQRSTUVWXYZ абвгдеёжзийклмнопрстуфхцчшщьыъэюяabcdefghijklmnopqrstuvwxyz'
extras:
- file: 'fonts/materialdesignicons-webfont.ttf' # http://materialdesignicons.com/cdn/7.4.47/
glyphs: [
"\U000F0238",
"\U000F1722"
text: !lambda 'return "\\U000F0238" ;'
then the icon is drawn, but if I do it through a global variable:
text: !lambda 'return id(switch1_icon_on);'
then instead of the icon, just the text is displayed: \U000F0238
Is there a way to overcome this situation?
I don’t know about bg_image_src, but it is possible if you are using the image component.
on_value:
- if:
condition:
text_sensor.state:
state: "clear_night"
then:
- lvgl.image.update:
src: clear_night
- if:
condition:
text_sensor.state:
state: "cloudy"
then:
- if:
condition:
- sun.is_above_horizon:
then:
src: cloudy
- if:
condition:
- sun.is_below_horizon :
then:
src: night_cloudy
- if:
condition:
text_sensor.state:
state: "fog"
then:
src: fog
- if:
condition:
text_sensor.state:
state: "hail"
then:
src: hail
- if:
condition:
text_sensor.state:
state: "lightning"
then:
src: lightning
- if:
condition:
text_sensor.state:
state: "lightning_rainy"
then:
src: lightning_rainy
- if:
condition:
text_sensor.state:
state: "partlycloudy"
then:
- if:
condition:
then:
src: partlycloudy
- if:
condition:
then:
src: nightpartlycloudy
- if:
condition:
text_sensor.state:
state: "pouring"
then:
src: pouring
- if:
condition:
text_sensor.state:
state: "rainy"
then:
src: rainy
- if:
condition:
text_sensor.state:
state: "snowy"
then:
src: snowy
- if:
condition:
text_sensor.state:
state: "snowy_rainy"
then:
src: snowy_rainy
- if:
condition:
text_sensor.state:
state: "sunny"
then:
src: sunny
- if:
condition:
text_sensor.state:
state: "windy"
then:
src: windy
- if:
condition:
text_sensor.state:
state: "windy_variant"
then:
src: windy
- if:
condition:
text_sensor.state:
state: "exceptional"
then:
src: exceptional
And I couldn’t do it using lambdas, so the code got big.
If I understand what you want to do, I think the best way would be to use substitutions.
substitutions:
lightbulb_off: "\U000F0335"
lightbulb_on: "\U000F06E8"
font:
bpp: 4
glyphs: [
$lightbulb_off,
$lightbulb_on
on_state:
text: !lambda |-
static char buf[10];
std::string icon;
if (id(internal_light_1).current_values.is_on()) {
icon = "$lightbulb_on";
} else {
icon = "$lightbulb_off";
snprintf(buf, sizeof(buf), "%s", icon.c_str());
return buf;
There is probably a better way, but after I got things working I didn’t clean up the code.
domain_int
(domain int)
September 7, 2024, 3:47am
216
@walberjunior yeah figured that. Also tried lambdas and Im not so good at creating them, so am reverting to what you have suggested.
BTW, where is the solution button in this thread???
nickrout
(Nick Rout)
September 7, 2024, 4:33am
217
Only the thread starter gets the solution button.
domain_int
(domain int)
September 8, 2024, 4:47am
219
I do know Im postinbg a lot in here and Im no expert, but I promise to post my finished code once Im done. The people here have been amazing and Im learning a lot.
I need to display the current target_temperature of a thermostat controller (not a HA controller) but settemp_label_settingspage
just shows nan
I dont want to use a spinbox because I want the UI to look “non-LVGL-esphome”
The climate controller actually updates the set temp without issue (I can see the update of the climate entity via the esphome web interface)
Obviously I referred to this: The way I understand it is that these atrributes are read-only
https://esphome.io/components/climate/index.html#lambda-calls
Any guidance with the syntax/args of settemp_label_settings_page
- as usual is appreciated.
- label:
x: 140
y: 110
text:
format: "%.1f"
args: [ 'id(controller).target_temperature' ] #ive tried a heap of permutations here
using these:
- button:
x: 332
y: 35
widgets:
- label:
text: "+"
align: center
on_release:
then:
- climate.control:
target_temperature: !lambda "return id(controller).target_temperature + 0.1;"
- button:
x: 332
y: 109
bg_color: 0x1E1E1E
widgets:
- label:
text: "-"
align: center
on_release:
then:
- climate.control:
target_temperature: !lambda "return id(controller).target_temperature - 0.1;"
climate:
- platform: thermostat
sensor: sim_temp1
on_boot_restore_from: memory
nickrout
(Nick Rout)
September 8, 2024, 6:23am
220
The docs show the attributes that are available for climate components in esphome Climate Component — ESPHome
domain_int
(domain int)
September 8, 2024, 7:38am
221
Hey Nick,
Thats what Im eluding to - I tried args: [ 'id(controller).target_temperature' ]
as well as a half dozen different ways (I thought) it worked and unfortunately it doesnt seem to work the way I thought it does.
nickrout
(Nick Rout)
September 8, 2024, 7:55am
222
Sorry you did point to that page. I’ll look harder!
domain_int
(domain int)
September 8, 2024, 8:01am
223
Im just not a lambda guru and need ppl smarter than me to offer guidance.
