Nice does it seem to work well for you?
Can you still tap to turn the light on and off?
I created a new button with a slider on it. It you press the button any other other place other than the slider it will toggle the light. The slider will set the brightness. Also if the brightness is set by something else the screen will update to show the correct state.
This is the buttonâ
- button:
height: $button_height_double
checkable: true
widgets:
- label:
text_font: $icon_font
align: top_left
text: $button_1_icon
- label:
align: bottom_left
text: $button_1_name
- slider:
align: top_right
x: -5
width: 40
height: 170
pad_all: 0
min_value: 0
max_value: 255
radius: 5px
knob:
bg_color: White
radius: 2px
pad_left: -3px
pad_right: -3px
pad_top: -18px
pad_bottom: -18px
indicator:
radius: 0px
bg_color: Gray
on_release:
- homeassistant.action:
action: light.turn_on
entity_id: $button_1_device
brightness: !lambda return int(x);
on_click:
- homeassistant.service:
service: light.toggle
And this is the code that controls the state.
platform: homeassistant
entity_id: $button_${id}_device
attribute: brightness
on_value:
- lvgl.slider.update:
value: !lambda return x;
I added it to my guition-esp32-s3-4848s040-display_modular.yaml file if you want to see it working.
Tell me how to draw filled triangle in LVGL?
Yours looks much better ! will try it out tonight.
Any idea how we can get LVGL to display a sensor reading - eg âsensor.solarproductionâ
i dont get it -
do you have to do something in âsensor:â bit ,
sensor: -platform: ha - entity ID:
then how do i get it to update on lvgl?
Try this:
- platform: homeassistant
entity_id: your_entity_name_in_ha # Change the entity from your Home Assistant
#attribute: last_period # If you have a specific attribute in the sensor, make sure to uncomment and set it corresponding to yours
on_value:
then:
- lvgl.label.update:
id: solar_label # The label where u want to show
text:
format: "%s kWh"
args: ["id(my_solar_sensor).state.c_str()"] # Make sure to match with properly id like my_solar_sensor
Hi thanks for this
do iput this in âsensor:â or âtext_sensorâ as i keep getting an error when i put it in sensor?
text_sensor
thanks!#
so in your example - is solar_label the thing i need to put into the bit that says : label:
so its like this:
label: solar_label ?
or label: my_solar_sensor
or do i need to put a $ in front of it or something?
i really appreciate the help
this is looking really good.
ive looked at what you have done with proper eyes today and it seems so much more elegant a solution - i couldnt understand how to set individual settings per button but i get it now - i will try this next week (once the trouble+strife is at work)
Hi everyone - I hope you might be able to help me. I canât get my display to show anything. Iâve tried something simple like just getting it to write âHello worldâ but nothing appears on the display. I can compile the code in esphome and upload it to the display, but no luck. I greatly appreciate any help
esphome:
friendly_name: stordisp2
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
flash_size: 16MB
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
psram:
mode: octal
speed: 80MHz
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: XXXXXXXXX
ota:
- platform: esphome
password: XXXXXXXXXXX
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Stordisp2 Fallback Hotspot"
captive_portal:
# Internal outputs
output:
# Backlight LED
- platform: ledc
pin: GPIO38
frequency: 100Hz
# Built in 120v relay
- id: internal_relay_1
platform: gpio
pin: 40
# LIGHTS
light:
- platform: monochromatic
output: GPIO38
restore_mode: ALWAYS_ON
lvgl:
displays:
- my_display
touchscreens:
- my_touchscreen
log_level: INFO
color_depth: 16
bg_color: 0
text_font: unscii_8
align: center
pages:
- id: page_boot
widgets:
- obj:
widgets:
- label:
align: CENTER
text_align: CENTER
y: 190
width: 100%
text_color: 0x63b2f2
text: "HELLO WORLD"
# Touchscreen gt911 i2c
i2c:
- id: bus_a
sda: GPIO19
scl: GPIO45
#frequency: 100kHz
touchscreen:
platform: gt911
transform:
mirror_x: false
mirror_y: false
display: my_display
on_touch:
- logger.log:
format: Touch at (%d, %d)
args: [touch.x, touch.y]
- lambda: |-
ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
touch.x,
touch.y,
touch.x_raw,
touch.y_raw
on_release:
then:
- if:
condition: lvgl.is_paused
then:
- logger.log: "LVGL resuming"
- lvgl.resume:
- lvgl.widget.redraw:
- light.turn_on: backlight
# Display st7701s spi
spi:
- id: lcd_spi
clk_pin: GPIO48
mosi_pin: GPIO47
display:
- platform: st7701s
update_interval: never
auto_clear_enabled: false
data_rate: 2MHz
spi_mode: MODE3
color_order: RGB
invert_colors: false
dimensions:
width: 480
height: 480
transform:
mirror_x: false
mirror_y: false
cs_pin: 39
# reset not defined
de_pin: 18
hsync_pin: 16
vsync_pin: 17
pclk_pin: 21
init_sequence:
- 1
- [0xFF, 0x77, 0x01, 0x00, 0x00, 0x10] # CMD2_BKSEL_BK0
- [0xCD, 0x00] # disable MDT flag
pclk_frequency: 12MHz
pclk_inverted: false
data_pins:
red:
- 11 # R1
- 12 # R2
- 13 # R3
- 14 # R4
- 0 # R5
green:
- 8 # G0
- 20 # G1
- 3 # G2
- 46 # G3
- 9 # G4
- 10 # G5
blue:
- 4 # B1
- 5 # B2
- 6 # B3
- 7 # B4
- 15 # B5
When I see the log i esphome this is showing over and over again.
esphome:
on_boot:
Start with my basic file for the GUITION 4â 480x480 ESP32-S3-4848S040 Smart Display. That will get your display working and you can move on from there.
Wow, Thatâs some nice code!!
ThanksâŚ
I found the problem, my device was stuck in a boot loop so I added this to my code and now it is working.
esphome:
platformio_options:
board_build.flash_mode: dio
I also just tried your code and that is working fine
You did a greate job on github
Hello everyone!
I also use this screen and EspHome without Home assistant and I want to talk about some troubles that arose in the processâŚ
After all, this screen is an independent device that can work without WiFi⌠And it seems very convenient to do the following things:
Hi
I tried Andrew code but I obtain an error
Why the common/color.yaml file cannot be find?
I got an issue. I can swtich my lightbulb on my display. The problem is that it wonât update the state on the display when setting it on in homeassistant. I got in the logging that it gets the state. Any an idea what I do wrong
- button:
x: 250
y: 260
width: 60
height: 58
checkable: true
widgets:
- label:
text_font: light32
text: "\U000F0335"
align: center
on_click:
service: switch.toggle
data_template:
entity_id: switch.zolderverlichting
binary_sensor:
publish_initial_state: true
on_state:
then:
- lvgl.widget.update:
state:
checked: !lambda return x;
[19:56:24][D][homeassistant.binary_sensor:026]: 'switch.zolderverlichting': Got state ON
[19:56:24][D][binary_sensor:036]: 'zolderlamp': Sending state ON
I donât know. I donât have any links in my code to the file anymore⌠Make sure to get the latest from my GIT repo and if you are still have issue tell me exactly what YAML file you are trying to use.
Look like you are missing some code. Try my guition-esp32-s3-4848s040-display_modular.yaml example. That will get it working.
