GUITION 4" 480x480 ESP32-S3-4848S040 Smart Display with LVGL
Hi @kroonen ,
I made such a solution based on waiting a certain trime after the last touch (on_Touch) and after that show home page, if the screen is toucehd while waiting it restarts waiting
Something like this:
touchscreen:
    on_touch:
      - light.turn_on:
          brightness: 100%
      - delay: 30s
      - display.page.show: !lambda return id(home_page);
Hope it works for you :slight_smile:
Thx for your reply.
I have it like this in script, but I got errors on the display.page.show:
error: cannot convert ‘esphome::lvgl::LvPageType*’ to ‘esphome::display::DisplayPage*’ in return
touchscreen:
  platform: gt911
  transform:
    mirror_x: false
    mirror_y: false
  display: my_display
  on_touch:
    - logger.log:
          format: Touch at (%d, %d)
          args: [touch.x, touch.y]
    - lambda: |-
          ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
    - script.stop: screen_light
    - script.execute: screen_light
interval:
  - interval: 30s
    then:
      - lambda: |-
          auto now = id(ha_date).now();
          if ((now.hour >= 22 && now.minute >= 45) || (now.hour < 7)) {
            id(night_mode) = true;
          } else {
            id(night_mode) = false;
script:
  - id: screen_light
    mode: restart
    then:
      # Zet de backlight aan bij aanraking
      - lvgl.resume:
      - light.turn_on:
          brightness: 75%
          transition_length: 2s
      # Controleer of het 'night mode' is
      - if:
          condition:
            lambda: 'return id(night_mode);'
          then:
            - delay: 30s
            - light.turn_off: backlight
      - delay: 30s
      - display.page.show: !lambda 'return id(clock_page);'
Have you tried without ‘ as I do like this:
!lambda return id(clock_page);
Yes also, same error
Can anyone help with this:
I want the keycaps black or transparent (preferrably) with white letters
        - keyboard:
            textarea: ha_input_text_34
            mode: TEXT_UPPER
            bg_color: 0x000000
            text_color: 0xFFFFFF
What I get is a keyboard that has a black background surround, with white keycaps and black lettering.
Not what I was expecting
ok, with lvgl try using this instead:
    - lvgl.page.show:
          id:  !lambda 'return id(clock_page);
thnx for the direction, that was not the solution, but like this it worked
script:
  - id: screen_light
    mode: restart
    then:
      - lvgl.resume:
      - light.turn_on:
          brightness: 75%
      - if:
          condition:
          then:
            - delay: 30s
      - delay: 30s
      - lvgl.page.show:
Any ideas how we can set this screen to be ‘off’ until you tap it.
this is what happens on ‘night-mode’ - but how do we enable that full-time?
Has anyone seen how to mount this to a light switch? im a lil lost.
You need to read the list from the beginiing, because post three has an answer
https://community.home-assistant.io/t/guition-4-480x480-esp32-s3-4848s040-smart-display-with-lvgl/729271/3?u=nickrout
I did, but the vague explanation does not explain how it comes apart or where to get the wall mount.
I’m printing a model now that works in a single switch box. My own design. Thanks for the assistance
I must say it is hard to say, not knowing where you come from, and knowing what size “light switch” you want to fit it in. There is a direct link to the wall box in that post (the one I pointed you to).
it comes apart - if you look at the bottom of the unit there are 2 small rectangular holes (not the side of the usbc) - pop a small screwdriver in that and itll pop out the little tab holding it in - repeat on the other side then pull up.
easy peasy.
Hello everyone. I got a problem with my code, which is prevent my device to be updated to the last esphome version:
Everything is working fine , and it was not an issue before but now it is a problem and I don’t understand where it’s came from.
Here is my full code:
substitutions:
  friendly_name: "Touch Panel"
  device_description: "Guition ESP32-S3-4848S040 480*480 Smart Screen"
  project_name: "Guition.ESP32_S3_4848S040"
  project_version: "1.0.0"
  lightbulb: "\U000F0335"
  ceiling_light: "\U000F0769"
  lamp: "\U000F06B5"
  floor_lamp: "\U000F08DD"
  string_lights: "\U000F12BA"
  clock: "\U000F0150"
  ceiling_fan: "\U000F1797"
  light_recessed: "\U000F179B"
  blinds_horizontal: "\U000F1A2B"
  blinds_horizontal_closed: "\U000F1A2C"
  curtains_closed: "\U000F1847"
  curtains: "\U000F1846"
  wallsconce: "\U000F091C"
  bed: "\U000F02E3"
  bed_empty: "\U000F08A0"
  thermometer_high: "\U000F10C2"
  humidity: "\U000F058E"
  wallsconce_variant: "\U000F091E"
  kiss: "\U000F0C73"
  hvac: "\U000F0D43"
esphome:
  friendly_name: "${friendly_name}"
  #name_add_mac_suffix: true
  project:
    version: "${project_version}"
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  flash_size: 16MB
  framework:
    type: esp-idf
    sdkconfig_options:
      COMPILER_OPTIMIZATION_SIZE: y
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
psram:
  mode: octal
  speed: 80MHz
logger:
api:
  encryption:
    key: "t6v3XcZv09tWcNbty6MqaemoADnflen/Tf7tsngFYAA="
ota:
  password: "75fb0465d4f21e3c40812285f627d29d"
  platform: esphome
wifi:
  ssid: !secret wifi_ssid
web_server:
  port: 80
external_components:
 - source: github://clydebarrow/esphome@lvgl
   refresh: 10min
   components: [ lvgl ]
time:
  - platform: sntp
    timezone: America/New_York
    servers:
     - 0.pool.ntp.org
     - 1.pool.ntp.org
     - 2.pool.ntp.org
    on_time_sync:
      - script.execute: time_update
    on_time:
      - minutes: '*'
        seconds: 0
        then:
############ AntiBurn ################
script:
  - id: time_update
    then:
      - lvgl.label.update:
          text: !lambda |-
            static char time_buf[17];
            auto now = id(sntp_time).now();
            bool is_pm = now.hour >= 12;
            int hour_12 = now.hour % 12;
            if (hour_12 == 0) {
                hour_12 = 12; // 12 AM/PM should be displayed as 12, not 0
            snprintf(time_buf, sizeof(time_buf), "%2d:%02d%s", hour_12, now.minute, is_pm ? "pm" : "am");
            return time_buf;
###################Temp and Humidity ################
  - platform: homeassistant
    entity_id: sensor.atc_7997_temperature
    on_value:
          text:
            format: "\U000F10C3 %.1f \U000F0504"
            args: [ 'x' ]
    entity_id: sensor.atc_7997_humidity
    on_value:
          text:
            format: "\U000F058E %.1f \U000F03F0"
            args: [ 'x' ]
###############Fan######################
    entity_id: fan.master_fan
    attribute: percentage
    on_value:
      - lvgl.spinbox.update:
          value: !lambda return x;
################HVAC####################
    entity_id: climate.upstairs
    attribute: temperature
    on_value:
############Cover##############
    entity_id: cover.shades_curtain
    attribute: current_position
    on_value:
      - if:
          condition:
            lambda: |-
              return x == 100;
          then:
            - lvgl.widget.update:
                text_opa: 60%
          else:
                text_opa: 100%
      - if:
          condition:
            lambda: |-
              return x == 0;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
###############Backlight Dimmer##################
####Text Sensor####################
text_sensor:
    on_value:
      - if:
          condition:
            lambda: |-
              return ((0 == x.compare(std::string{"opening"})) or (0 == x.compare(std::string{"closing"})));
          then:
                text: "STOP"
          else:
                text:
                  format: "%.0f%%"
                  args: [ 'id(cover_myroom_pos).get_state()' ]
################### Red Lights #######################
switch:
  - platform: lvgl
    widget: lv_button_8
    #on_turn_on:
      #then:
        #- lvgl.widget.update:
           # id: lv_button_8_icon
            #text_color: 0xFFFF00
    #on_turn_off:
     # then:
            #id: lv_button_8_icon
           # text_color: 0xB6B6B6
###################### AntiBurn#####################
################binary_sensors###############
# Lights#
binary_sensor:
    entity_id: light.over_the_bed_lights
    publish_initial_state: true
    on_state:
      then:
        lvgl.widget.update:
          state:
            checked: !lambda return x;
    entity_id: light.mirror_lighs
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.tv_lights
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.irina_s_wall_light
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.bed_occupancy_sensor_yevgeniy_lights
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.my_wall_light
    on_state:
      then:
        lvgl.widget.update:
          state:
##################INTIM LIGHTS##################
    entity_id: light.intim_lights
    on_state:
      then:
        lvgl.widget.update:
          state:
#Fan#
    on_state:
      then:
        lvgl.widget.update:
          state:
#Covers#
    entity_id: cover.master_bedroom_all_covers
    on_state:
      then:
        lvgl.widget.update:
          state:
#number:
  # __________________________________________________ backlight timeout
  #- platform: template
    #name: Backlight Timeout
    #optimistic: true
    #id: backlight_timeout
    #unit_of_measurement: "s"
    #initial_value: 30
    #restore_value: true
    #min_value: 10
    #max_value: 90
    #step: 10
    #mode: auto # auto / box / slider
################lvgl Buttons################
lvgl:
  displays:
    - display_id: my_display
  touchscreens:
    - touchscreen_id: my_touchscreen
  on_idle:
    timeout: 120s ###!lambda "return (id(backlight_timeout).state * 1000);" ##fiture use##
    then:
      - logger.log: "LVGL is idle"
      - lvgl.pause:
##########Pages####################
  top_layer:
    widgets:
      - label:
          text_font: roboto24
          text: "00:00 am"
          align: bottom_mid
          #x: -2
          y: -10
          text_align: right
      - label:
          text_font: roboto24
          text: "-.- %"
          align: bottom_right
          x: -20
          y: -10
          text_align: right
          on_press:
            then:
              - lvgl.page.show: second_page
      - label:
          text_font: roboto24
          text: "-.-°C"
          align: bottom_left
          x: 12
          y: -10
          #text_align: right
          on_press:
            then:
              - lvgl.page.show: main_page
  style_definitions:
    - id: style_line
      line_color: 0x0000FF
      line_width: 8
      line_rounded: true
    - id: date_style
      text_font: roboto24
      align: center
      text_color: 0x333333
      bg_opa: cover
      radius: 4
      pad_all: 2
####Header_Footer##########
    - id: header_footer
      bg_color: 0x0C7B5F
      bg_grad_color: 0x03291F
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 0
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      border_color: 0x0077b3
      width: 100%
      height: 30
  theme:
    button:
      text_font: roboto24
      scroll_on_focus: true
      group: general
      radius: 20
      width: 150
      height: 96
      pad_all: 0
      pad_top: 0
      pad_bottom: 0
      #pad_left: 5px
      #pad_top: 5px
      #pad_bottom: 5px
      #pad_right: 5px
      shadow_width: 0
      bg_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
    obj:
      text_font: roboto24
      group: general
      radius: 20
      width: 150
      height: 100
      pad_left: 5px
      pad_top: 5px
      pad_bottom: 5px
      pad_right: 5px
      shadow_width: 0
      bg_color: 0x0C7B5F
      border_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
  page_wrap: true
  pages:
    - id: main_page
      skip: true
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      pad_all: 5
      layout: # enable the FLEX layout for the children widgets
        type: FLEX
        flex_flow: ROW_WRAP # the order of the widgets starts top left
        flex_align_cross: CENTER
      widgets:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $light_recessed
              - label:
                  align: bottom_mid
                  text: "Bed Lights"
                  long_mode: dot
            on_short_click:
              - homeassistant.service:
                  service: light.toggle
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_mid
              - label:
                  align: bottom_mid
                  text: "Mirror Lights"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
              - label:
                  align: bottom_mid
                  text: "TV Lights"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $wallsconce_variant
              - label:
                  align: bottom_mid
                  text: "Irina Light"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_mid
                  text: $bed
              - label:
                  align: bottom_mid
                  text: "Under Bed"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
              - label:
                  align: bottom_mid
                  text: "My Light"
                  long_mode: dot
            on_short_click:
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $hvac
              - label:
                  align: bottom_left
                  text_align: center
                  text: "Hvac"
              - obj:
                  width: 160
                  height: 80
                  bg_opa: transp
                  border_opa: transp
                  text_font: light32
                  align: right_mid
                  widgets:
                    - button:
                        align: left_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                          - lvgl.spinbox.decrement: spinbox_id
                        widgets:
                          - label:
                                align: left_mid
                                text_align: left
                                text_font: montserrat_36
                                text: "-"
                    - spinbox:
                        align: CENTER
                        text_align: CENTER
                        bg_opa: transp
                        border_opa: transp
                        width: 90
                        #height: 60
                        range_from: 18
                        range_to: 28
                        step: 0.5
                        rollover: false
                        digits: 3
                        decimal_places: 1
                        on_value:
                          then:
                                service: climate.set_temperature
                                  temperature: !lambda return x;
                    - button:
                        align: right_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                          - lvgl.spinbox.increment: spinbox_id
                        widgets:
                          - label:
                                align: right_mid
                                text_align: right
                                text: "+"
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
                  text: $kiss
              - label:
                  align: bottom_right
                  text: "Intim"
                  long_mode: dot
            on_short_click:
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $ceiling_fan
              - label:
                  align: bottom_left
                  text: "Fan"
                 # long_mode: dot
              - obj:
                  width: 160
                  height: 80
                  bg_opa: transp
                  border_opa: transp
                  text_font: light32
                  align: right_mid
                  widgets:
                    - button:
                        align: left_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                          - lvgl.spinbox.decrement: fan_speed
                        widgets:
                          - label:
                                align: left_mid
                                text_align: left
                                text: "-"
                        on_press:
                          then:
                                service: fan.decrease_speed
                    - spinbox:
                        align: CENTER
                        text_align: CENTER
                        bg_opa: transp
                        border_opa: transp
                        width: 90
                        #height: 60
                        range_from: 0
                        range_to: 100
                        step: 33.3
                        rollover: false
                        digits: 3
                        #decimal_places: 1
                        on_value:
                          then:
                                service: fan.set_percentage
                                  percentage: !lambda return x;
                    - button:
                        align: right_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                          - lvgl.spinbox.increment: fan_speed
                        widgets:
                          - label:
                                align: right_mid
                                text_align: right
                                text: "+"
                        on_press:
                          then:
                                service: fan.increase_speed
            on_short_click:
                  service: fan.toggle
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
                  text: $curtains
              - label:
                  align: bottom_right
                  text: "Curtains"
                  #long_mode: dot
            on_short_click:
                  service: cover.toggle
############## Second Page#######################
    - id: second_page
      skip: true
      #layout: flex
      #flex_flow: row_WRAP
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      pad_all: 5
        type: FLEX
      widgets:
############## Covers###################
          - button:
              x: 10
              y: 30
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text:  "\U000F0143"
              on_press:
                then:
                      service: cover.open
          - button:
              x: 10
              y: 103
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text: STOP
              on_press:
                then:
                      service: cover.stop
          - button:
              x: 10
              y: 178
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text: "\U000F0140"
              on_press:
                then:
                      service: cover.close
######################Backlight Dimmer####################
          - slider:
              align: bottom_mid
              height: 20
              width: 260
              min_value: 30 #anything below is too dark for me
              max_value: 100
              on_release:
                then:
                  - light.turn_on:
                      brightness: !lambda return int(x)/ 100.0;
                  #- lvgl.widget.hide: slider_pop
####################HVAC##############################
# Internal outputs
output:
    # Backlight LED
  - platform: ledc
    pin: GPIO38
    frequency: 100Hz
    # Built in 120v relay
  - id: internal_relay_1
    platform: gpio
    pin: 40
# LIGHTS
light:
  - platform: monochromatic
    output: GPIO38
    restore_mode: ALWAYS_ON
# Graphics and Fonts
image:
  - file: https://esphome.io/_images/logo.png
    resize: 200x200
    type: RGB565
  - file: "fonts/wall-sconce-180.svg"
    resize: 20x20
font:
  - file: "gfonts://Roboto"
    bpp: 4
    extras:
      - file: 'fonts/materialdesignicons-webfont.ttf' # http://materialdesignicons.com/cdn/7.4.47/
        glyphs: [
          "\U000F004B",
          "\U0000f0ed",
          "\U000F006E",
          "\U000F012C",
          "\U000F179B",
          "\U000F0748",
          "\U000F1A1B",
          "\U000F02DC",
          "\U000F0A02",
          "\U000F035F",
          "\U000F0156",
          "\U000F0C5F",
          "\U000f0084",
          "\U000f0091",
          "\U000F058E",
          "\U000F10C3",
          "\U000F03F0", # mdi-percent
          "\U000F0504", # mdi- celcius
          "\U000F091E",
          "\U000F0143", # mdi-arrow_up
          "\U000F0140", # mdi-arrow_down
    bpp: 4
    glyphs: &mdi-weather-glyphs
      - "\U000F0590" # mdi-weather-cloudy
      - "\U000F0F2F" # mdi-weather-cloudy-alert
      - "\U000F0E6E" # mdi-weather-cloudy-arrow-right
      - "\U000F0591" # mdi-weather-fog
      - "\U000F0592" # mdi-weather-hail
      - "\U000F0F30" # mdi-weather-hazy
      - "\U000F0898" # mdi-weather-hurricane
      - "\U000F0593" # mdi-weather-lightning
      - "\U000F067E" # mdi-weather-lightning-rainy
      - "\U000F0594" # mdi-weather-clear-night
      - "\U000F0F31" # mdi-weather-night-partly-cloudy
      - "\U000F0595" # mdi-weather-partly-cloudy
      - "\U000F0F32" # mdi-weather-partly-lightning
      - "\U000F0F33" # mdi-weather-partly-rainy
      - "\U000F0F34" # mdi-weather-partly-snowy
      - "\U000F0F35" # mdi-weather-partly-snowy-rainy
      - "\U000F0596" # mdi-weather-pouring
      - "\U000F0597" # mdi-weather-rainy
      - "\U000F0598" # mdi-weather-snowy
      - "\U000F0F36" # mdi-weather-snowy-heavy
      - "\U000F067F" # mdi-weather-snowy-rainy
      - "\U000F0599" # mdi-weather-sunny
      - "\U000F0F37" # mdi-weather-sunny-alert
      - "\U000F14E4" # mdi-weather-sunny-off
      - "\U000F059A" # mdi-weather-sunset
      - "\U000F059B" # mdi-weather-sunset-down
      - "\U000F059C" # mdi-weather-sunset-up
      - "\U000F0F38" # mdi-weather-tornado
      - "\U000F059D" # mdi-weather-windy
      - "\U000F059E" # mdi-weather-windy-variant
    bpp: 4
    glyphs: [
      "\U000F0335", # mdi-lightbulb
      "\U000F0769", # mdi-ceiling-light
      "\U000F08DD", # mdi-floor-lamp
      "\U000F12BA", # mdi-string-lights
      "\U000F0150", # mdi-clock
      "\U000F1797", # mdi-ceiling_fan
      "\U000F179B", # mdi-light_recessed
      "\U000F1A2B", # mdi-blinds_horizontal
      "\U000F1A2C", # mdi-blinds_horizontal_closed
      "\U000F1847", # mdi-curtains_closed
      "\U000F1846", # mdi-curtains
      "\U000F091C", # mdi-wallsconce
      "\U000F02E3", # mdi-bed
      "\U000F08A0", # mdi-bed_empty
      "\U000F10C2", # mdi-thermometer_high
      "\U000F058E", # mdi-humidity
      "\U000F091E", # mdi-wallsconce_variant
      "\U000F0C73", # mdi-kiss
      "\U000F0D43", # mdi- hvac
    bpp: 4
# Touchscreen gt911 i2c
i2c:
  - id: bus_a
    sda: GPIO19
    scl: GPIO45
    #frequency: 100kHz
touchscreen:
  platform: gt911
  transform:
    mirror_x: false
    mirror_y: false
  display: my_display
  on_touch:
    - logger.log:
    - lambda: |-
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
  on_release:
    then:
      - if:
          condition: lvgl.is_paused
          then:
            - logger.log: "LVGL resuming"
            - lvgl.resume:
            - lvgl.widget.redraw:
            - light.turn_on: backlight
# Display st7701s spi
spi:
  - id: lcd_spi
    clk_pin: GPIO48
    mosi_pin: GPIO47
Thank you
continue
display:
  - platform: st7701s
    update_interval: never
    auto_clear_enabled: True
    data_rate: 2MHz
    spi_mode: MODE3
    color_order: RGB
    invert_colors: false
    dimensions:
      width: 480
      height: 480
    transform:
      mirror_x: false
      mirror_y: false
    cs_pin: 39
      # reset not defined
    de_pin: 18
    hsync_pin: 16
    vsync_pin: 17
    pclk_pin: 21
    init_sequence:
      - 1
      - [0xFF, 0x77, 0x01, 0x00, 0x00, 0x10] # CMD2_BKSEL_BK0
      - [0xCD, 0x00] # disable MDT flag
    pclk_frequency: 12MHz
    pclk_inverted: false
    data_pins:
      red:
        - 11         # R1
        - 12         # R2
        - 13         # R3
        - 14         # R4
        - 0          # R5
      green:
        - 8          # G0
        - 20         # G1
        - 3          # G2
        - 46         # G3
        - 9          # G4
        - 10         # G5
      blue:
        - 4          # B1
        - 5          # B2
        - 6          # B3
        - 7          # B4
        - 15         # B5
Try:
lvgl:
  displays:
  touchscreens:
  on_idle:
    - timeout: 120s ###!lambda "return (id(backlight_timeout).state * 1000);" ##fiture use##
      then:
        - lvgl.pause:
Nope, doesn’t work, but thank you anyway for your response :smiley:
Things aren’t looking good here.
My panel has the firmware 2024.9.1 and my addon 2024.9.2, when I try to compile again I get several errors even though the validation is OK.
Looking at the list of break changes I didn’t find anything.
Updating to version 2024.10.0 removed some errors, but I still can’t compile.
Don’t use this is your files anymore. This is very old BETA code and not compatible with the current ESPHome.
I have made a lot of small changes to guition-esp32-s3-4848s040-display_basic.yaml and guition-esp32-s3-4848s040-display_modular.yaml and tested them with 2024.10.0
Check one of these out and build it for your screen. Then edit accordingly to add your own buttons.
