GUITION 4" 480x480 ESP32-S3-4848S040 Smart Display with LVGL
Read again all documentation about LVGL , can’t find any information about error, which prevent UPDATE to last esphome firmware. My display is working fine with code, which I posted in my post # 333. Any suggestion what to do or what to check. Thank you
Looking at the link, I don’t think thats the correct part.
It looks to be a " Common Mode Inductor / choke" at what value is unknown.
Right…my bad… i was too quick. I ended up ordering THESE
inductors.
looking at the wire turn count on the proof photo the Inductor has 12 turns, So it think theses in the correct range.
5MH 10MH 15MH 4A Annular Common Mode Filter Inductor 0.6 Wire Choke Ring Inductance 1495mm 2MH 5A 0.7 Wire - AliExpress 13
It’s impossible to know the number of turns from picture on aliepxress, since pic is only a reference (all sellers have pretty much the same pic). Beside, inductance is highly dependant on core type.
But, as said, any will be better than nothing.
Some sellers are better at the actual item photo then others.
25x15x13 1mh 1.5mh 3mh 10mh 20mH magnetic ring common mode inductor ring choke/filter - AliExpress 13
Wach out the diameter! Appr. 12-14mm is maximum you can squeeze in…
Good catch.
Also, I was concerned about the turn placement parallel Vs. separate. After brushing up on inductors and reading this post: Common Mode Choke winding differences - Page 1
It matters. The links I posted seem to be for mains voltages and the parallel turn inductors are for low voltages. Like you have posted.
Hullo, I got it to compile… I’m not a programmer…
Hopefully will be help…
type or paste code here
```# testing for zenia 19oct24
substitutions:
  friendly_name: "Touch Panel"
  device_description: "Guition ESP32-S3-4848S040 480*480 Smart Screen"
  project_name: "Guition.ESP32_S3_4848S040"
  project_version: "1.0.0"
  lightbulb: "\U000F0335"
  ceiling_light: "\U000F0769"
  lamp: "\U000F06B5"
  floor_lamp: "\U000F08DD"
  string_lights: "\U000F12BA"
  clock: "\U000F0150"
  ceiling_fan: "\U000F1797"
  light_recessed: "\U000F179B"
  blinds_horizontal: "\U000F1A2B"
  blinds_horizontal_closed: "\U000F1A2C"
  curtains_closed: "\U000F1847"
  curtains: "\U000F1846"
  wallsconce: "\U000F091C"
  bed: "\U000F02E3"
  bed_empty: "\U000F08A0"
  thermometer_high: "\U000F10C2"
  humidity: "\U000F058E"
  wallsconce_variant: "\U000F091E"
  kiss: "\U000F0C73"
  hvac: "\U000F0D43"
esphome:
  friendly_name: "${friendly_name}"
  #name_add_mac_suffix: true
  project:
    version: "${project_version}"
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  flash_size: 16MB
  framework:
    type: esp-idf
    sdkconfig_options:
      COMPILER_OPTIMIZATION_SIZE: y
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
psram:
  mode: octal
  speed: 80MHz
logger:
api:
  encryption:
    key: "t6v3XcZv09tWcNbty6MqaemoADnflen/Tf7tsngFYAA="
ota:
  password: "75fb0465d4f21e3c40812285f627d29d"
  platform: esphome
wifi:
  ssid: !secret wifi_ssid
web_server:
  port: 80
time:
  - platform: sntp
    timezone: America/New_York
    servers:
     - 0.pool.ntp.org
     - 1.pool.ntp.org
     - 2.pool.ntp.org
    on_time_sync:
      - script.execute: time_update
    on_time:
      - minutes: '*'
        seconds: 0
        then:
############ AntiBurn ################
script:
  - id: time_update
    then:
      - lvgl.label.update:
          text: !lambda |-
            static char time_buf[17];
            auto now = id(sntp_time).now();
            bool is_pm = now.hour >= 12;
            int hour_12 = now.hour % 12;
            if (hour_12 == 0) {
                hour_12 = 12; // 12 AM/PM should be displayed as 12, not 0
            snprintf(time_buf, sizeof(time_buf), "%2d:%02d%s", hour_12, now.minute, is_pm ? "pm" : "am");
            return time_buf;
###################Temp and Humidity ################
  - platform: homeassistant
    entity_id: sensor.atc_7997_temperature
    on_value:
          text:
            format: "\U000F10C3 %.1f \U000F0504"
            args: [ 'x' ]
    entity_id: sensor.atc_7997_humidity
    on_value:
          text:
            format: "\U000F058E %.1f \U000F03F0"
            args: [ 'x' ]
###############Fan######################
    entity_id: fan.master_fan
    attribute: percentage
    on_value:
      - lvgl.spinbox.update:
          value: !lambda return x;
################HVAC####################
    entity_id: climate.upstairs
    attribute: temperature
    on_value:
############Cover##############
    entity_id: cover.shades_curtain
    attribute: current_position
    on_value:
      - if:
          condition:
            lambda: |-
              return x == 100;
          then:
            - lvgl.widget.update:
                text_opa: 60%
          else:
                text_opa: 100%
      - if:
          condition:
            lambda: |-
              return x == 0;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
###############Backlight Dimmer##################
####Text Sensor####################
text_sensor:
    on_value:
      - if:
          condition:
            lambda: |-
              return ((0 == x.compare(std::string{"opening"})) or (0 == x.compare(std::string{"closing"})));
          then:
                text: "STOP"
          else:
                text:
                  format: "%.0f%%"
                  args: [ 'id(cover_myroom_pos).get_state()' ]
################### Red Lights #######################
switch:
  - platform: lvgl
    widget: lv_button_8
    #on_turn_on:
      #then:
        #- lvgl.widget.update:
           # id: lv_button_8_icon
            #text_color: 0xFFFF00
    #on_turn_off:
     # then:
            #id: lv_button_8_icon
           # text_color: 0xB6B6B6
###################### AntiBurn#####################
################binary_sensors###############
# Lights#
binary_sensor:
    entity_id: light.over_the_bed_lights
    publish_initial_state: true
    on_state:
      then:
        lvgl.widget.update:
          state:
            checked: !lambda return x;
    entity_id: light.mirror_lighs
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.tv_lights
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.irina_s_wall_light
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.bed_occupancy_sensor_yevgeniy_lights
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.my_wall_light
    on_state:
      then:
        lvgl.widget.update:
          state:
##################INTIM LIGHTS##################
    entity_id: light.intim_lights
    on_state:
      then:
        lvgl.widget.update:
          state:
#Fan#
    on_state:
      then:
        lvgl.widget.update:
          state:
#Covers#
    entity_id: cover.master_bedroom_all_covers
    on_state:
      then:
        lvgl.widget.update:
          state:
#number:
  # __________________________________________________ backlight timeout
  #- platform: template
    #name: Backlight Timeout
    #optimistic: true
    #id: backlight_timeout
    #unit_of_measurement: "s"
    #initial_value: 30
    #restore_value: true
    #min_value: 10
    #max_value: 90
    #step: 10
    #mode: auto # auto / box / slider
################lvgl Buttons################
lvgl:
  displays:
    - my_display
  touchscreens:
    - my_touchscreen
  on_idle:
    timeout: 120s ###!lambda "return (id(backlight_timeout).state * 1000);" ##fiture use##
    then:
      - logger.log: "LVGL is idle"
      - light.turn_off: backlight
      - lvgl.pause:
##########Pages####################
  top_layer:
    widgets:
      - label:
          text_font: roboto24
          text: "00:00 am"
          align: bottom_mid
          #x: -2
          y: -10
          text_align: right
          text_color: 0xFFFFFF
      - label:
          text_font: roboto24
          text: "-.- %"
          align: bottom_right
          x: -20
          y: -10
          text_align: right
          on_press:
            then:
              - lvgl.page.show: second_page
      - label:
          text_font: roboto24
          text: "-.-°C"
          align: bottom_left
          x: 12
          y: -10
          #text_align: right
          on_press:
            then:
              - lvgl.page.show: main_page
  style_definitions:
    - id: style_line
      line_color: 0x0000FF
      line_width: 8
      line_rounded: true
    - id: date_style
      text_font: roboto24
      align: center
      text_color: 0x333333
      bg_opa: cover
      radius: 4
      pad_all: 2
####Header_Footer##########
    - id: header_footer
      bg_color: 0x0C7B5F
      bg_grad_color: 0x03291F
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 0
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      border_color: 0x0077b3
      width: 100%
      height: 30
  theme:
    button:
      text_font: roboto24
      scroll_on_focus: true
#      group: general
      radius: 20
      width: 150
      height: 96
      pad_all: 0
      pad_top: 0
      pad_bottom: 0
      #pad_left: 5px
      #pad_top: 5px
      #pad_bottom: 5px
      #pad_right: 5px
      shadow_width: 0
      bg_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
    obj:
      text_font: roboto24
#      group: general
      radius: 20
      width: 150
      height: 100
      pad_left: 5px
      pad_top: 5px
      pad_bottom: 5px
      pad_right: 5px
      shadow_width: 0
      bg_color: 0x0C7B5F
      border_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
  page_wrap: true
  pages:
    - id: main_page
      skip: false
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      pad_all: 5
      layout: # enable the FLEX layout for the children widgets
        type: FLEX
        flex_flow: ROW_WRAP # the order of the widgets starts top left
        flex_align_cross: CENTER
      widgets:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $light_recessed
              - label:
                  align: bottom_mid
                  text: "Bed Lights"
                  long_mode: dot
            on_short_click:
              - homeassistant.service:
                  service: light.toggle
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_mid
              - label:
                  align: bottom_mid
                  text: "Mirror Lights"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
              - label:
                  align: bottom_mid
                  text: "TV Lights"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $wallsconce_variant
              - label:
                  align: bottom_mid
                  text: "Irina Light"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_mid
                  text: $bed
              - label:
                  align: bottom_mid
                  text: "Under Bed"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
              - label:
                  align: bottom_mid
                  text: "My Light"
                  long_mode: dot
            on_short_click:
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $hvac
              - label:
                  align: bottom_left
                  text_align: center
                  text: "Hvac"
              - obj:
                  width: 160
                  height: 80
                  bg_opa: transp
                  border_opa: transp
                  text_font: light32
                  align: right_mid
                  widgets:
                    - button:
                        align: left_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                          - lvgl.spinbox.decrement: spinbox_id
                        widgets:
                          - label:
                                align: left_mid
                                text_align: left
                                text_font: montserrat_36
                                text: "-"
                    - spinbox:
                        align: CENTER
                        text_align: CENTER
                        bg_opa: transp
                        border_opa: transp
                        width: 90
                        #height: 60
                        range_from: 18
                        range_to: 28
                        step: 0.5
                        rollover: false
                        digits: 3
                        decimal_places: 1
                        on_value:
                          then:
                                service: climate.set_temperature
                                  temperature: !lambda return x;
                    - button:
                        align: right_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                          - lvgl.spinbox.increment: spinbox_id
                        widgets:
                          - label:
                                align: right_mid
                                text_align: right
                                text: "+"
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
                  text: $kiss
              - label:
                  align: bottom_right
                  text: "Intim"
                  long_mode: dot
            on_short_click:
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $ceiling_fan
              - label:
                  align: bottom_left
                  text: "Fan"
                 # long_mode: dot
              - obj:
                  width: 160
                  height: 80
                  bg_opa: transp
                  border_opa: transp
                  text_font: light32
                  align: right_mid
                  widgets:
                    - button:
                        align: left_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                          - lvgl.spinbox.decrement: fan_speed
                        widgets:
                          - label:
                                align: left_mid
                                text_align: left
                                text: "-"
                        on_press:
                          then:
                                service: fan.decrease_speed
                    - spinbox:
                        align: CENTER
                        text_align: CENTER
                        bg_opa: transp
                        border_opa: transp
                        width: 90
                        #height: 60
                        range_from: 0
                        range_to: 100
                        step: 33.3
                        rollover: false
                        digits: 3
                        #decimal_places: 1
                        on_value:
                          then:
                                service: fan.set_percentage
                                  percentage: !lambda return x;
                    - button:
                        align: right_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                          - lvgl.spinbox.increment: fan_speed
                        widgets:
                          - label:
                                align: right_mid
                                text_align: right
                                text: "+"
                        on_press:
                          then:
                                service: fan.increase_speed
            on_short_click:
                  service: fan.toggle
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
                  text: $curtains
              - label:
                  align: bottom_right
                  text: "Curtains"
                  #long_mode: dot
            on_short_click:
                  service: cover.toggle
############## Second Page#######################
    - id: second_page
      skip: true
      #layout: flex
      #flex_flow: row_WRAP
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      pad_all: 5
        type: FLEX
      widgets:
############## Covers###################
          - button:
              x: 10
              y: 30
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text:  "\U000F0143"
              on_press:
                then:
                      service: cover.open
          - button:
              x: 10
              y: 103
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text: STOP
              on_press:
                then:
                      service: cover.stop
          - button:
              x: 10
              y: 178
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text: "\U000F0140"
              on_press:
                then:
                      service: cover.close
######################Backlight Dimmer####################
          - slider:
              align: bottom_mid
              height: 20
              width: 260
              min_value: 30 #anything below is too dark for me
              max_value: 100
              on_release:
                then:
                  - light.turn_on:
                      brightness: !lambda return int(x)/ 100.0;
                  #- lvgl.widget.hide: slider_pop
####################HVAC##############################
# Internal outputs
output:
    # Backlight LED
  - platform: ledc
    pin: GPIO38
    frequency: 100Hz
    # Built in 120v relay
  - id: internal_relay_1
    platform: gpio
    pin: 40
# LIGHTS
light:
  - platform: monochromatic
    output: GPIO38
    restore_mode: ALWAYS_ON
# Graphics and Fonts
image:
  - file: https://esphome.io/_images/logo.png
    resize: 200x200
    type: RGB565
  - file: "fonts/wall-sconce-180.svg"
    resize: 20x20
font:
  - file: "gfonts://Roboto"
    bpp: 4
    extras:
      - file: 'fonts/materialdesignicons-webfont.ttf' # http://materialdesignicons.com/cdn/7.4.47/
        glyphs: [
          "\U000F004B",
          "\U0000f0ed",
          "\U000F006E",
          "\U000F012C",
          "\U000F179B",
          "\U000F0748",
          "\U000F1A1B",
          "\U000F02DC",
          "\U000F0A02",
          "\U000F035F",
          "\U000F0156",
          "\U000F0C5F",
          "\U000f0084",
          "\U000f0091",
          "\U000F058E",
          "\U000F10C3",
          "\U000F03F0", # mdi-percent
          "\U000F0504", # mdi- celcius
          "\U000F091E",
          "\U000F0143", # mdi-arrow_up
          "\U000F0140", # mdi-arrow_down
    bpp: 4
    glyphs: &mdi-weather-glyphs
      - "\U000F0590" # mdi-weather-cloudy
      - "\U000F0F2F" # mdi-weather-cloudy-alert
      - "\U000F0E6E" # mdi-weather-cloudy-arrow-right
      - "\U000F0591" # mdi-weather-fog
      - "\U000F0592" # mdi-weather-hail
      - "\U000F0F30" # mdi-weather-hazy
      - "\U000F0898" # mdi-weather-hurricane
      - "\U000F0593" # mdi-weather-lightning
      - "\U000F067E" # mdi-weather-lightning-rainy
      - "\U000F0594" # mdi-weather-clear-night
      - "\U000F0F31" # mdi-weather-night-partly-cloudy
      - "\U000F0595" # mdi-weather-partly-cloudy
      - "\U000F0F32" # mdi-weather-partly-lightning
      - "\U000F0F33" # mdi-weather-partly-rainy
      - "\U000F0F34" # mdi-weather-partly-snowy
      - "\U000F0F35" # mdi-weather-partly-snowy-rainy
      - "\U000F0596" # mdi-weather-pouring
      - "\U000F0597" # mdi-weather-rainy
      - "\U000F0598" # mdi-weather-snowy
      - "\U000F0F36" # mdi-weather-snowy-heavy
      - "\U000F067F" # mdi-weather-snowy-rainy
      - "\U000F0599" # mdi-weather-sunny
      - "\U000F0F37" # mdi-weather-sunny-alert
      - "\U000F14E4" # mdi-weather-sunny-off
      - "\U000F059A" # mdi-weather-sunset
      - "\U000F059B" # mdi-weather-sunset-down
      - "\U000F059C" # mdi-weather-sunset-up
      - "\U000F0F38" # mdi-weather-tornado
      - "\U000F059D" # mdi-weather-windy
      - "\U000F059E" # mdi-weather-windy-variant
    bpp: 4
    glyphs: [
      "\U000F0335", # mdi-lightbulb
      "\U000F0769", # mdi-ceiling-light
      "\U000F08DD", # mdi-floor-lamp
      "\U000F12BA", # mdi-string-lights
      "\U000F0150", # mdi-clock
      "\U000F1797", # mdi-ceiling_fan
      "\U000F179B", # mdi-light_recessed
      "\U000F1A2B", # mdi-blinds_horizontal
      "\U000F1A2C", # mdi-blinds_horizontal_closed
      "\U000F1847", # mdi-curtains_closed
      "\U000F1846", # mdi-curtains
      "\U000F091C", # mdi-wallsconce
      "\U000F02E3", # mdi-bed
      "\U000F08A0", # mdi-bed_empty
      "\U000F10C2", # mdi-thermometer_high
      "\U000F058E", # mdi-humidity
      "\U000F091E", # mdi-wallsconce_variant
      "\U000F0C73", # mdi-kiss
      "\U000F0D43", # mdi- hvac
    bpp: 4
# Touchscreen gt911 i2c
i2c:
  - id: bus_a
    sda: GPIO19
    scl: GPIO45
    #frequency: 100kHz
touchscreen:
  platform: gt911
  transform:
    mirror_x: false
    mirror_y: false
  display: my_display
  on_touch:
    - logger.log:
          format: Touch at (%d, %d)
          args: [touch.x, touch.y]
    - lambda: |-
          ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
  on_release:
    then:
      - if:
          condition: lvgl.is_paused
          then:
            - logger.log: "LVGL resuming"
            - lvgl.resume:
            - lvgl.widget.redraw:
            - light.turn_on: backlight
# Display st7701s spi
spi:
  - id: lcd_spi
    clk_pin: GPIO48
    mosi_pin: GPIO47
display:
  - platform: st7701s
    update_interval: never
    auto_clear_enabled: false
    data_rate: 2MHz
    spi_mode: MODE3
    color_order: RGB
    invert_colors: false
    dimensions:
      width: 480
      height: 480
    transform:
      mirror_x: false
      mirror_y: false
    cs_pin: 39
      # reset not defined
    de_pin: 18
    hsync_pin: 16
    vsync_pin: 17
    pclk_pin: 21
    init_sequence:
      - 1
      - [0xFF, 0x77, 0x01, 0x00, 0x00, 0x10] # CMD2_BKSEL_BK0
      - [0xCD, 0x00] # disable MDT flag
    pclk_frequency: 12MHz
    pclk_inverted: false
    data_pins:
      red:
        - 11         # R1
        - 12         # R2
        - 13         # R3
        - 14         # R4
        - 0          # R5
      green:
        - 8          # G0
        - 20         # G1
        - 3          # G2
        - 46         # G3
        - 9          # G4
        - 10         # G5
      blue:
        - 4          # B1
        - 5          # B2
        - 6          # B3
        - 7          # B4
        - 15         # B5
PLEASE assume any changes I made are sus… :slight_smile:
Thank you for your support. I copy and paste your code, and it’s let me compile without any problem
I briefly compare your code to mine and didn’t find any difference. Not at home yet( did it remotely )
Will check the result later and let you know how it is on actual devices. Thank you again for your help
@groveh1 Thank you again. Everything is working, and no changes in interface. Still can’t see a difference between your and my codes,but it’s not important. Main thing is updates and works.
The error is saying that at least one page must not be skipped. You must be skipping all the pages you’ve created in LVGL. Add “skip: false” to at least one page e.g:
  • id: main_page
    skip: false
I see it now, thank you for pointing me the right direction.
My previous code:
New , thank to @groveh1 is correct
Thank you guys for your help. Learn from bright people in our community every day
so im having some issues making this modular so i can update the value of a temp.
what im trying to do is set a ‘tado’ switch on the panel each of which reads the current room temperature from climate.roomname (although the temperature is not the state, the state is ‘auto/off/heat’, so im not entirely sure how to read the ‘current_temperature’ attribute of this entity_.
    entity_id: button_${id}_device
    entity_category: diagnostic
    unit_of_measurement: "C"
    on_value:
        then:
              text:
                format: "Temp: %.0fC"
                args: [ 'id(lv_button${id}_text).state' ]
above is the ‘set state of button’ logged under ‘sensors’
# Basic climage control switch button - define its setting in substitutions
            height: ${hight}
            checkable: true
            widgets:
              - label:
                  text_font: $icon_font
                  align: top_left
                  text: $button_${id}_icon
              - label:
                  align: bottom_left
                  text: "Temp N/A"
            on_click:
                    service: tado.set_climate_timer
                      entity_id: $button_${id}_device
                      temperature: $button_${id}_temp
                      time_period: $button_${id}_time
above is the ‘climate button’
  button_6_name: "OmarHeat"
  button_6_id: button_6
  button_6_icon: $radiator
  button_6_device: "climate.omar_s_room"
  button_6_temp: "25.0"
  button_6_time: "0:25:00"
that is the substitution.
all i seem to be getting is this error
text_sensor.unknown: [source /config/esphome/esphome-web-d7a2e0.yaml:139]
  Platform schemas must be key-value pairs.
    entity_id: button_6_device
    unit_of_measurement: C
    on_value:
      then:
            text:
              format: Temp: %.0fC
              args:
If you need to read an attribute you need to add the attribute detail to your sensor so it knows what to read. e.g:
    attribute: current_temperature
    on_value:
You should also really be doing this under sensor: not text_sensor: to pull the float value back.
Hi everyone,
I’m struggling playing with this guition for a while and after trying to use OpenHASP I came upon this topic and tried using ESPHOME which feels so much more understandable to me.
I’ve got my plate up & running and I’m adding buttons one by one, trying to make something nice and usable that fits my needs.
I have a question though :
I’m trying to setup a button that controls a light (yeelight led bulb), but I would like that when I long press the button, it opens a rainbow circle that I could pick color from (like the lovelace card more or less).
Here’s where I am as for now :
  • I copied the basic_light_switch_button.yaml and named it dimmer_light_switch_button_rainbow.yaml
  • I added the following code at the end in it :
            on_long_press:
            min_lenght: 1000ms
            then:
                  service: switch.toggle
                  effect: color_wheel
Don’t laugh I’m a total beginner in coding in Yaml and I still have a hard time understanding what is LVGL related and what is homeassistant, and how do all this interacts… :sweat_smile:
I’m feeling I’m not on the right path, but even with the LVGL documentation, I still don’t understand what is dependant from the widget or anything else.
In short, I’m lost… Can anyone help me ?
BTW if you’ve got any article or documentation that explains the LVGL concepts in a simple way, and how it interacts with HA, I’m interested !
And thanks @andrew_NH for the awesome work !
Edit: I feel like it is not possible at the moment, I assume that we can only rely on the differents widget types implemented in LVGL for now, which are listed here Widgets — LVGL documentation and does not contain what I’m looking for… Am I Right ?
Edit 2 : The extra widget color_wheel seems promessing, but no idea on how to implement it in yaml and what is the structure
I updated my panel, and also got images for weather to work with scripts. The idea iof the layout is inspired on nspanel blueprint
panel
@kroonen: Looks great, can you share your yaml? :slight_smile: Goed bezig! :wink:
Hello all - when using Andrews code in post 282 with the slider and using it to dimme the light. When the light is off, the slider is jumping to the top, and not to the bottom og the widget. I’m using the same code as Andrew ?
Thanks for the help
@IJsvogels.nl
I placed the files on my github.
