GUITION 4" 480x480 ESP32-S3-4848S040 Smart Display with LVGL
Thanks for this, for me, I’d like CURRENT live info and some totals. So current info would be solar generation, grid import/export, battery draw/charge and battery SOC. And then for the running totals just: grid import and solar generation.
I get an error that mapping values are not allowed here for the page_button yaml when I try and compile it.
ERROR Error while reading config: Invalid YAML syntax:
  in "/config/esphome/modules/lvgl/buttons/page_button.yaml", line 208, column 74
When I open that page up in notepad++ this is what’s on line 208:
<body class="logged-in env-production page-responsive" style="word-wrap: break-word;">
I cloned the repository by downloading the zip and copying the files over to my home assistant just now so think it’s all correct. The only tweak i made was putting my own esphome api and ota info, the rest was as in your guition-esp32-s3-4848s040-solar.yaml file.
I asked for help from ChatGPT but thought I’d just ask on here too as chatgpt must have some old code it keeps wanting me to use and takes me down a bit of a rabbit hole.
If I can get past the error I’ll spend some time on which enitities to try and show and how they look.
Yeah sorry, 2025.2.0 has some breaking changes in it and I needed to fix a few things in the code base. While I was at it I made button creation more simple. You can now define the button right on the include line and you don’t need to have a substitutions section for it.
I also added swipe navigation! You can swipe left or right on each page to go to the next or previous page.
Check out the latest code a compile and it should work.
Yeah I have tried ChatGPT a few times with ESPHome and I don’t think it has a large enough sample to work on it efficiently. I does help with a few basic ideas but good old fashioned Googling works better.
changed the language, thx
This device has it’s own ESP microcontroller already so it’s suitable to work on it’s own.
The ‘only’ thing you have to do is to configure it to use with HA.
All the info is in this thread.
hello
since the last update it doesn’t work anymore
on_turn_on:
- lvgl.label.update:
bg_color: 0x000000
widgets:
- button:
checkable: false
eror:
id:
ID ‘dormitor_lightlvgl’ of type lv_btn_t doesn’t inherit from lv_label_t. Please double check your ID is pointing to the correct value.
bg_color: 0
@pantileionut
your widget is a button, but your action id is a label.
Hi guys.
I made a kitchen version of the device I posted before. It’s for Korean users, but if you want to refer to it, please refer to it.
https://github.com/plplaaa2/esphome-craft-480-kc
https://youtube.com/shorts/XZFKfd7OopM
yes it’s ok that was the problem. it also makes sense but I wasn’t paying attention
Look like you hae some codeing issues. Build the base then modify to fit your needs.
Thanks, I hadn’t adjusted that yet :slight_smile:
Is it possible that I add an input_number as a slider?
I have made a slider that mixed the (balance) to brightness and temp_color. Left is maximum dimmed and red glow, right is bright white light.
If I move the slider all the way to the left (0), the light goes into auto mode, where it switches on and off based on a PIR. That is why the standard light.* is not sufficient
this is a part of the slider in HA:
<br><br>
- type: entities
    entities:
      - type: custom:slider-entity-row
        entity: input_number.light_mood
I found some sample above in this topic, and I work. I think I’m only need to add a sensor to update the slider…
        - slider:
            x: 20
            y: 50
            width: 220
            height: 20
            pad_all: 8
            min_value: 0
            max_value: 100
            on_value:
              then:
                - homeassistant.service:
                    service: input_number.set_value
                      entity_id: input_number.light_mood
                      value: !lambda return x;
            on_release:
              then:
                    service: light.turn_on
                      entity_id: light.your_light_entity
                      brightness: !lambda return int(x);
Yeah this is a free open source project. Add a button to do anything you want.
Can anyone help, this is just about working except the buttons don’t actually work as buttons, they show the status correctly though, so if I turn on one of the things via my home assistant dashboard the relevant button illuminates correctly on the panel but it doesn’t activate the thing when I tap the button on the panel. I have enabled the device to be able to control home assistant actions from the configure menu. I’m sure I’m being thick!!
TIA.
captive_portal:
# Substitution variables used through the codebase
substitutions:
  lightbulb:         "\U000F0335"
  ceiling_light:     "\U000F0769"
  lamp:              "\U000F06B5"
  floor_lamp:        "\U000F08DD"
  string_lights:     "\U000F12BA"
  track_light:       "\U000F0914"
  bulkhead_light:    "\U000F1A2F"
  led_strip:         "\U000F07D6"
  coach_lamp:        "\U000F1020"
  ceiling_fan_light: "\U000F1798"
  bed:               "\U000F02E3"
  icon_font: light40
  text_font: roboto24
  button_on_color: "ep_orange"
  button_off_color: "very_dark_gray"
  icon_on_color: "yellow"
  icon_off_color: "gray"
  label_on_color: "white"
  label_off_color: "gray"
  button_text_color: "white"
  button_height_single: '109px'
  button_height_double: '228px'
  button_width: '150px'
  touchscreen_idle_timeout: "30s"
  touchscreen_daytime_brightness: "100%"
  touchscreen_nighttime_brightness: "50%"
  # Boot screen configuration
  boot_screen_delay: 30s
  # Set Night mode  at Mightnight
  screen_night_hour: '0'
  screen_night_minute: '0'
  # Set Day mode at 5:30am
  screen_day_hour: '5'
  screen_day_minute: '30'
  # Screen Size
  screen_height: '480px'
  screen_width: '480px'
time:
  - platform: homeassistant
# Time update script - This is run once per second. Use it to update any time related labels.
script:
  - id: time_update
    mode: queued
    then:
      - lambda: |-
          auto time = id(hatime).now();
          char buffer[6];
          snprintf(buffer, sizeof(buffer), "%02d:%02d", time.hour, time.minute);
          lv_label_set_text(id(clock_label), buffer);
          lv_obj_align(id(clock_label), LV_ALIGN_CENTER, 0, 0);  // ✅ Fully centers horizontally & vertically
      - delay: 60s
      - script.execute: time_update
packages:
  # Generic configuration for ESP32 screens
  wifi: !include modules/base/wifi.yaml
  base: !include modules/base/base.yaml
  colors: !include modules/base/color.yaml
  fonts: !include modules/base/fonts.yaml
  images: !include modules/base/images.yaml
  time: !include modules/base/time_sntp.yaml
  sensors: !include modules/sensors/sensors_base.yaml
  # Harware description file
  hardware: !include modules/hardware/guition-esp32-s3-4848s040.yaml
  # This section will Update button and relay state from Home Assistant
  # Any button that has real time updates needs a section here
  # Button 1 - Local relay button with state updates
  button_1_state: !include
    file: modules/sensors/switch_or_light_button_state.yaml
    vars:
      uid: button_1
      entity_id: "switch.alan_ensuite_lights"
  # Button 2 - Standard light button with state updates
  button_2_state: !include
    vars:
      uid: button_2
      entity_id: "switch.alan_towel_rail"
  # Button 3 - Standard light button with state updates including dimming
  button_3_state: !include
    vars:
      uid: button_3
      entity_id: "switch.alan_extract_fan"
  # Button 4 - Standard light button with state updates including dimming
  button_4_state: !include
    vars:
      uid: button_4
      entity_id: "switch.alan_mirror"
# LVGL pages and buttons
lvgl:
  theme: !include { file: modules/base/theme.yaml }
  page_wrap: true
  on_idle:
    - timeout: 6s
      then:
        - lvgl.page.show: clock_page
# Boot screen
  top_layer: !include
    file: modules/screens/boot_screen.yaml
    vars:
      height: $screen_height
      width: $screen_width
# Main Page
  pages:
    - id: main_page
      layout:
        type: flex
        flex_flow: COLUMN_WRAP
      width: 100%
      bg_color: black
      bg_opa: cover
      pad_all: 5
      widgets:
        # Button 1 - Standard (double hight) internal relay button with state updates
        - button: !include
            file: modules/buttons/light_button.yaml
            vars:
              uid: button_1
              height: $button_height_double
              text: Light
              icon: $lightbulb
        # Button 2 - Standard (double hight) internal relay button with state updates
        - button: !include
            vars:
              uid: button_2
              text: Towel Rail
              icon: $lightbulb
        # Button 3 - Standard (double hight) internal relay button with state updates
        - button: !include
            vars:
              uid: button_3
              text: Extractor
              icon: $lightbulb
        # Button 4 - Standard (double hight) internal relay button with state updates
        - button: !include
            vars:
              uid: button_4
              text: Mirror Light
              icon: $lightbulb
    - id: clock_page
      layout:
        type: flex
        flex_flow: COLUMN
      width: 100%
      height: 100%
      bg_color: black
      bg_opa: cover
      widgets:
        - label:
            text: "00:00"
            text_font: roboto190
            text_color: white
            align: CENTER  # ✅ Align the text inside the label
            width: 100%
            height: 100%
      on_click:
        then:
          - lvgl.page.show: main_page  # ✅ Go back to the main page on touch
That is because you did not include a device to control when you created the button.
Take a look at the examples in my repo.
        - button: !include
            file: modules/buttons/dimmer_light_button.yaml
            vars:
              uid: button_4
              text: RGB light
              icon: $string_lights
              entity_id: light.athom_rgb_light_d93662_rgb_light_strip
Your button is missing the entity_id: of the device to control so it does not control anything!
My word! Can’t believe I didn’t see that!!! Thanks so much. I know how it happened, i copied and pasted the first button for the other 3 buttons and incremented the numbers and that didn’t have an entity as it was a local button, I did of course have the entity IDs on the state updates higher up but somehow hadn’t noticed that!!
Thanks again.
For another one of these switches I’d love to have some pretty gauges like the korean one looks like but in English of course. It took me ages to make the clock work as a screensaver in this code… I’ll keep playing.
Hmmn, now got compilation errors. My head hurts lol.
INFO Reading configuration /config/esphome/esp32-wallpanelalan.yaml...
INFO Detected timezone 'Europe/London'
INFO Generating C++ source...
INFO Updating https://github.com/espressif/[email protected]
INFO Compiling app...
Processing esp32-wallpanelalan (board: esp32-s3-devkitc-1; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32.git#51.03.07)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
 - framework-espidf @ 3.50105.0 (5.1.5)
 - tool-cmake @ 3.21.3
 - tool-esptoolpy @ 4.8.1
 - tool-mklittlefs @ 3.2.0
 - tool-ninja @ 1.7.1
 - tool-riscv32-esp-elf-gdb @ 12.1.0+20221002
 - tool-xtensa-esp-elf-gdb @ 12.1.0+20221002
 - toolchain-esp32ulp @ 2.35.0-20220830
 - toolchain-riscv32-esp @ 12.2.0+20230208
 - toolchain-xtensa-esp32s3 @ 12.2.0+20230208
Reading CMake configuration...
Dependency Graph
|-- noise-c @ 0.1.6
|-- ArduinoJson @ 6.18.5
|-- lvgl @ 8.4.0
Compiling .pioenvs/esp32-wallpanelalan/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/esp32-wallpanelalan/src/main.cpp.o
Compiling .pioenvs/esp32-wallpanelalan/esp_local_ctrl/src/esp_local_ctrl_transport_httpd.c.o
Compiling .pioenvs/esp32-wallpanelalan/components/mdns/mdns.c.o
Compiling .pioenvs/esp32-wallpanelalan/components/mdns/mdns_networking_lwip.c.o
Compiling .pioenvs/esp32-wallpanelalan/components/mdns/mdns_console.c.o
Linking .pioenvs/esp32-wallpanelalan/firmware.elf
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/esp32-wallpanelalan/src/main.cpp.o:(.literal._Z5setupv+0x2b8): undefined reference to `_ZTVN7esphome13homeassistant19HomeassistantSensorE'
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/esp32-wallpanelalan/src/main.cpp.o:(.literal._Z5setupv+0x2bc): undefined reference to `_ZTVN7esphome13homeassistant19HomeassistantSensorE'
collect2: error: ld returned 1 exit status
*** [.pioenvs/esp32-wallpanelalan/firmware.elf] Error 1
========================= [FAILED] Took 35.03 seconds =========================
type or paste code here
Yes it does look like you have a bug in your code. What is this?“_ZTVN7esphome13homeassistant19HomeassistantSensorE” that seems to be the issue.
I have no idea. that doesn’t appear anywhere in my code. my code is as I pasted above except for the addition of the entitities on the buttons that i ommitted. i wonder if its when it pulls down the things it needs from the internet at compilation time, perhaps one of those dependencies has changed or something. Blindness aside (from how you helped me) I can’t see where my code would cause this.
clean you build environment and try it again. Also try building one of my example files.
