GUITION 4" 480x480 ESP32-S3-4848S040 Smart Display with LVGL
I think this setting has moved. In my case I just commented out these lines.
Yes , comment out it works. But now I have in the bottom buttons (navigatieon buttons) between them some space. So it should be defined somewhere else to let it work
Yes, it was moved somewhere else. Since it made no difference to my setup I didn’t check the documentation.
Edit:
pad_row is now in the styling variables
Stick with the Guition ESP32-S3-4848S040 it’s cheaper and there are more people using it.
LVGL has been added to 2024.8.0 so there is no longer a need to use the @clydebarrow external repo. I updated my demo code to only use stock 2024.8.0 . I had to update a bunch of small stuff to bring it in line with the latest LVGL code.
What an amazing leap forward for ESPhome!
The link at the start of the thread to AliExpress says “this item is no longer available”, but if you click on “Find similar items” it does so.
Yeah it’s always a good idea to dig around for the best price.
Hmm.
I shouldn’t know how t solve it, where I should put the code to fix it.
I have nog this in style definirations
 style_definitions:
    - id: header_footer
      bg_color: 0x444444
      bg_grad_color: 0x444444
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 0
      radius: 0
      pad_all: 0
      border_color: 0x333333
      text_color: 0xFFFFFF
      width: 100%
      height: 40
andi this as buttonmatrix to create them. But putting hem here I get also an error.
  - buttonmatrix:
      align: bottom_mid
      styles: header_footer
      pad_all: 0
      outline_width: 0
      items:
      rows:
        - buttons:
          - id: page_prev
            text: "\uF053"
            on_press:
              then:
                lvgl.page.previous:
          - id: page_home
            text: "\uF015"
            on_press:
              then:
                lvgl.page.show: clock_page
          - id: page_next
            text: "\uF054"
            on_press:
              then:
                lvgl.page.next:
is this the same device? (link in the first post is for us and fcks up aliexpress for non us users)
https://www.aliexpress.com/item/1005006622809642.html
As far as I can tell it is. Same model number (ending 4848s040) and a reference in the reviews to bring openhasp compatible. Also pics from customers referring to guition.
Found one and ordered :smiley: thanks for the info!
Here my designs. The only issue I can’t fix is on the bottom, to have it as one bar , and not as three buttons.
I also have the issue when booting and also when the condition change, I get first tjhe state in the big font, and after a minute or so the icon. It should be nice that I only get this icon.
On first page I have my Airco. On top you see state icons that will be visibile when it is on or open (garage door open, audio on, airco mode, hot water etc.)
Other page is my light, and my shuttters. I;m using this panel in my office.
Code please?
In 3 pieces
substitutions:
  lightbulb: "\U000F1802"
  boiler_on: "\U000F0238"
  boiler_off: "\U000F1722"
  radiator: "\U000F0438"
  ceiling_light: "\U000F0769"
  house_temp: "\U000F0F55"
  house_hum: "\U000F058E"
  house_solar: "\U000F1A73"
  house_solar2: "\U000F0A72"
  house_valve: "\U000F1066"
  airco: "\U000F001B"
  powerbutton: "\U000F0906"
#weather icons
  cloudy: "\U000F0590"
  cloudyalert: "\U000F0F2F"
  cloudyarrowright: "\U000F0E6E"
  fog: "\U000F0591"
  hail: "\U000F0592"
  hazy: "\U000F0F30"
  hurricane: "\U000F0898"
  lightning: "\U000F0593"
  lightningrainy: "\U000F067E"
  night: "\U000F0594"
  nightpartlycloudy: "\U000F0F31"
  partlycloudy: "\U000F0595"
  partlylightning: "\U000F0F32"
  partlyrainy: "\U000F0F33"
  partlysnowy: "\U000F0F34"
  partlysnowyrainy: "\U000F0F35"
  pouring: "\U000F0596"
  rainy: "\U000F0597"
  snowy: "\U000F0598"
  snowyheavy: "\U000F0F36"
  snowyrainy: "\U000F067F"
  sunny: "\U000F0599"
  sunnyalert: "\U000F0F37"
  sunnyoff: "\U000F14E4"
  sunset: "\U000F059A"
  sunsetdown: "\U000F059B"
  sunsetup: "\U000F059C"
  tornado: "\U000F0F38"
  windy: "\U000F059D"
  windyvariant: "\U000F059E"
  happyface: "\U000F01F5"
#airco
  cool: "\U000F0717"
  heat: "\U000F0510"
  dry: "\U000F058E"
  fan: "\U000F0210"
esphome:
  friendly_name: HA panel 1
  platformio_options:
    board_build.flash_mode: dio
  on_boot:
    - delay: 5s
    - lvgl.widget.hide: boot_screen
    - delay: 30s
    - light.turn_on:
          brightness: 75%
          transition_length: 4s
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  flash_size: 16MB
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
psram:
  mode: octal
  speed: 80MHz
# Enable logging
logger:
# Enable Home Assistant API
api:
  on_client_connected:
    - if:
        condition:
          lambda: 'return (0 == client_info.find("Home Assistant "));'
        then:
          - lvgl.widget.show: lbl_hastatus
  on_client_disconnected:
    - if:
        condition:
        then:
          - lvgl.widget.hide: lbl_hastatus
ota:
  - platform: esphome
    password: "secret"
wifi:
  networks:
  - ssid: ssidname
    password: secret
  #use_address: 192.168.9.75
  ap:
    ssid: "Ha-Panel-1 Fallback Hotspot"
    password: secret
captive_portal:
external_components:
  - source: github://pr#7338
    components: [lvgl]
# Content
lvgl:
  displays:
    - my_display
  touchscreens:
    - my_touchscreen
  theme:
    #label:
     # text_font: roboto24 # set all your labels to use your custom defined font
    button:
      bg_color: 0x333333
      #bg_grad_color: 0x333333
      #bg_grad_dir: VER
      text_font: roboto24
      bg_opa: 85%
      border_width: 0
      pressed: # set some btn colors to be different in pressed state
        bg_color: 0x111111
        bg_grad_color: 0x111111
      checked: # set some btn colors to be different in checked state
        bg_color: 0x111111
        text_color: 0xf6ff00
    buttonmatrix:
      bg_opa: TRANSP
      border_width: 0
      pad_all: 0
      items: # set all your btnmatrix buttons to use your custom defined styles and font
        bg_color: 0x333333
        bg_grad_dir: VER
        bg_opa: COVER
        border_width: 1
        #text_font: roboto10
        pressed:
          bg_color: 0x111111
        checked:
          bg_color: 0x111111
          text_color: 0xEEEEEE
    switch:
      bg_color: 0xC0C0C0
      bg_grad_color: 0xb0b0b0
      bg_grad_dir: VER
      bg_opa: COVER
      checked:
        bg_color: 0x1d5f96
        bg_grad_color: 0x03324A
        bg_grad_dir: VER
        bg_opa: COVER
      knob:
        bg_color: 0xFFFFFF
        bg_grad_color: 0xC0C0C0
        bg_grad_dir: VER
        bg_opa: COVER
    slider:
      border_width: 1
      border_opa: 30%
      bg_color: 0x9c9c9c
      bg_opa: 15%
      indicator:
        bg_color: 0x333333
        bg_opa: COVER
      knob:
        bg_color: 0x444444
        bg_opa: COVER
        border_color: 0x444444
        border_width: 1
  style_definitions:
    - id: header_footer
      bg_color: 0x444444
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 0
      radius: 0
      pad_all: 0
      width: 100%
      height: 40
  top_layer:
    widgets:
      - label:
          text: "\uF1EB"
          hidden: true
          align: top_right
          x: -10
          y: 90
          text_align: right
      - label:
          text: "\U000F04C3"
          hidden: true
          align: top_left
          x: 300
          y: 2
          text_font: top_icons
          text_align: left
      - label:
          text: "\U000F0379"
          hidden: true
          align: top_left
          x: 260
          y: 2
          text_align: left
      - label:
          text: "\U000F10AF"
          hidden: true
          align: top_left
          x: 220
          y: 2
          text_align: left
      - label:
          text: "\U000F0872"
          hidden: true
          align: top_left
          x: 180
          y: 2
          text_align: left
      - label:
          text: "\U000F081C"
          hidden: true
          align: top_left
          x: 140
          y: 2
          text_align: left
      - label:
          text: "\U000F058F"
          hidden: true
          align: top_left
          x: 100
          y: 2
          text_align: left
          text_color: 0x800000
      - label:
          text: "\U000F0438"
          hidden: true
          align: top_left
          x: 60
          y: 2
          text_align: left
      - label:
          align: top_left
          x: 40
          y: 2
          text_font: top_airco
          text_align: left
      - label:
          align: RIGHT_MID
          text: date
          text_font: roboto24
          y: -60
          x: -45
      - label:
          align: RIGHT_MID
          text: clock
          text_font: roboto90
          y: -120
          x: -30
      - label:
          align: LEFT_MID
          text: house temp
          text_font: roboto32
          y: 10
          x: 20
      - label:
          align: LEFT_MID
          text: house hum
          text_font: roboto32
          y: 52
          x: 20
      - label:
          align: LEFT_MID
          text: $happyface
          bg_opa: TRANSP
          text_font: weather_icons
          y: -90
          x: 30
      - label:
          align: CENTER
          text: temp
          text_font: roboto32
          y: -140
          x: -80
      - buttonmatrix:
          align: bottom_mid
          pad_all: 0
          outline_width: 0
          items:
          rows:
            - buttons:
              - id: page_prev
                text: "\uF053"
                on_press:
                  then:
                    lvgl.page.previous:
              - id: page_home
                text: "\uF015"
                on_press:
                  then:
              - id: page_next
                text: "\uF054"
                on_press:
                  then:
                    lvgl.page.next:
      - obj:
          x: 0
          y: 0
          width: 100%
          height: 100%
          bg_color: 0x000000
          bg_opa: COVER
          radius: 0
          pad_all: 0
          border_width: 0
          widgets:
            - image:
                align: CENTER
                src: boot_logo
                y: -40
            - spinner:
                align: CENTER
                y: 95
                height: 50
                width: 50
                spin_time: 1s
                arc_length: 60deg
                arc_width: 8
                indicator:
                  arc_color: 0x18bcf2
                  arc_width: 8
          on_press:
  page_wrap: true
  pages:
    - id: clock_page
      widgets:
        - image:
            align: CENTER
            src: back7
        - label:
            align: LEFT_MID
            text: Solar
            text_font: roboto24
            y: 95
            x: 20
        - label:
            align: LEFT_MID
            text: Solar2
            text_font: roboto24
            y: 130
            x: 20
        - button:
            x: 320
            y: 260
            width: 60
            height: 58
            checkable: true
            widgets:
               - label:
                  text_font: light32
                  text: "\U000F0335"
                  align: center
            on_click:
              - homeassistant.service:
                  service: switch.toggle
                  data_template:
                    entity_id: switch.zolderverlichting
        - button:
            x: 250
            y: 340
            width: 60
            height: 50
            widgets:
              - label:
                  text_font: roboto24
                  align: CENTER
                  text:  "\U000F0143"
            on_press:
              then:
                    service: cover.open_cover
                      entity_id: cover.rolluikzolder_cover_1
        - button:
            x: 320
            y: 340
            width: 60
            height: 50
            widgets:
              - label:
                  align: CENTER
                  text: STOP
            on_press:
              then:
                    service: cover.stop_cover
        - button:
            x: 390
            y: 340
            width: 60
            height: 50
            widgets:
              - label:
                  align: CENTER
                  text: "\U000F0140"
            on_press:
              then:
                    service: cover.close_cover
    - id: hvac_page
      widgets:
        - image:
            align: CENTER
            src: back7
        - obj: # a properly placed coontainer object for all these controls
            layout: # enable the GRID layout for the children widgets
              type: GRID # split the rows and the columns proportionally
              grid_columns: [FR(1), FR(1), FR(1)] # equal
              grid_rows: [FR(50), FR(50)] # like percents
            width: 100%
            height: 90%
            #align: CENTER
            pad_all: 15
            pad_top: 22
            #pad_row: 6
            #pad_column: 2
            bg_opa: TRANSP
            border_opa: TRANSP
            widgets:
              - obj:
                  #checkable: false
                  grid_cell_column_pos: 2 # place the widget in
                  grid_cell_row_pos: 1 # the corresponding cell
                  grid_cell_x_align: STRETCH
                  grid_cell_y_align: STRETCH
                  bg_color: 0x333333
                  bg_opa: TRANSP
                  border_width: 0
                  widgets:
                    - button:
                        align: CENTER
                        width: 110
                        height: 35
                        #x: 0
                        y: -60
                        checkable: false
                        widgets:
                          - label:
                              text_font: roboto24
                              text: "+"
                              align: CENTER
                        on_click:
                              service: input_number.increment
                                entity_id: input_number.house_temperature_setpoint
                    - label:
                        text_font: btn_icons_font2
                        text: $house_temp
                        align: CENTER
                        y: -5
                    - label:
                        text_font: roboto24
                        text: "--- °C"
                        align: CENTER
                        y: 25
                    - button:
                        align: CENTER
                        width: 110
                        height: 35
                        #x: 0
                        y: 60
                        checkable: false
                        widgets:
                          - label:
                              text_font: roboto24
                              text: "-"
                              align: CENTER
                        on_click:
                              service: input_number.decrement
        - label:
            align: LEFT_MID
            text: valve
            text_font: roboto32
            y: 95
            x: 20
2nd part
    - id: airco_page
      widgets:
        - image:
            align: CENTER
            src: back7
            width: 100%
            height: 90%
            #align: CENTER
            pad_all: 15
            pad_top: 22
            #pad_row: 6
            #pad_column: 2
            bg_opa: TRANSP
            border_opa: TRANSP
            widgets:
              - obj:
                  #checkable: false
                  bg_color: 0x333333
                  bg_opa: TRANSP
                  border_width: 0
                  widgets:
                    - button:
                        align: CENTER
                        width: 110
                        height: 35
                        #x: 0
                        y: -60
                        checkable: false
                        widgets:
                          - label:
                              text_font: roboto24
                              text: "+"
                              align: CENTER
                        on_click:
                                entity_id: input_number.zolderairco_temperature_setpoint
                    - label:
                        text_font: roboto40
                        text: $airco
                        align: CENTER
                        y: -5
                    - label:
                        text_font: roboto24
                        text: "--- °C"
                        align: CENTER
                        y: 25
                    - button:
                        align: CENTER
                        width: 110
                        height: 35
                        #x: 0
                        y: 60
                        checkable: false
                        widgets:
                          - label:
                              text_font: roboto24
                              text: "-"
                              align: CENTER
                        on_click:
              - obj:
                  #checkable: false
                  grid_cell_column_pos: 1 # place the widget in
                  bg_color: 0x333333
                  bg_opa: TRANSP
                  border_width: 0
                  widgets:
                    - button:
                        align: LEFT_MID
                        width: 50
                        height: 35
                        x: 0
                        y: 20
                        checkable: false
                        widgets:
                          - label:
                              text_font: airco24
                              text: $cool
                              align: CENTER
                        on_click:
                              service: climate.set_fan_mode
                                entity_id: climate.aircozolder_mqtt_hvac
                                fan_mode: night
                              service: climate.set_hvac_mode
                                hvac_mode: cool
                    - button:
                        align: LEFT_MID
                        width: 50
                        height: 35
                        x: 0
                        y: -20
                        checkable: false
                        widgets:
                          - label:
                              text_font: airco24
                              text: $dry
                              align: CENTER
                        on_click:
                                hvac_mode: dry
                    - button:
                        align: RIGHT_MID
                        width: 50
                        height: 35
                        #x: 0
                        y: 20
                        checkable: false
                        widgets:
                          - label:
                              text_font: airco24
                              text: $heat
                              align: CENTER
                        on_click:
                                hvac_mode: heat
                    - button:
                        align: RIGHT_MID
                        width: 50
                        height: 35
                        #x: 0
                        y: -20
                        checkable: false
                        widgets:
                          - label:
                              text_font: airco24
                              text: $fan
                              align: CENTER
                        on_click:
                                hvac_mode: fan_only
                    - button:
                        align: CENTER
                        width: 110
                        height: 35
                        #x: 0
                        y: 60
                        checkable: false
                        widgets:
                          - label:
                              text_font: airco24
                              text: $powerbutton
                              align: CENTER
                        on_click:
                              service: climate.turn_off
#--------------------- Sensors -------------------
globals:
  - id: dimmer_level
    type: int
    restore_value: no
  - platform: uptime
  - platform: homeassistant
    entity_id: sensor.aircozolder_ble_temp
    on_value:
      then:
         - lvgl.label.update:
            text:
              format: "$house_temp %.1f°C"
              args: ["id(house_temp_sensor).state"]
    on_value:
      - logger.log: id(house_setpoint_ha).state.c_str()
          text:
            format: "%.1f °C"
            args: ["id(house_setpoint_ha).state"]
    on_value:
      - logger.log: id(airco_setpoint_ha).state.c_str()
          text:
            format: "%.1f °C"
            args: ["id(airco_setpoint_ha).state"]
    entity_id: sensor.aircozolder_ble_humidity
    on_value:
      then:
            text:
              format: "$house_hum %.1f%% "
              args: ["id(house_hum_sensor).state"]
    entity_id: sensor.zonvandaag
    on_value:
      then:
            text:
              format: "$house_solar %.3f Kwh"
              args: ["id(house_solar_sensor).state"]
    entity_id: sensor.zolder_trv
    on_value:
      then:
            text:
              format: "$house_valve %d%% "
              args: ["int(round(id(house_valve_sensor).state))"]
    on_value:
      - if:
          condition:
            lambda: |-
              return id(airco_mode_sensor).state == "cool";
          then:
            - lvgl.widget.update:
                text_color: 0x0096FF
          else:
                text_opa: 100%
      - if:
          condition:
            lambda: |-
              return id(airco_mode_sensor).state == "heat";
          then:
                text_color: 0xFF2C2C
          else:
                text_opa: 100%
      - if:
          condition:
            lambda: |-
              return id(airco_mode_sensor).state == "fan_only";
          then:
                text_color: 0x00FFFF
          else:
                text_opa: 100%
      - if:
          condition:
            lambda: |-
              return id(airco_mode_sensor).state == "dry";
          then:
                text_color: 0xFFCB75
          else:
                text_opa: 100%
    attribute: current_position
    on_value:
      - if:
          condition:
            lambda: |-
              return x == 100;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
      - if:
          condition:
            lambda: |-
              return x == 0;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
    entity_id: sensor.solar_sensor
    on_value:
      then:
            text:
              format: "$house_solar2 %.0f W"
              args: ["id(house_solar2_sensor).state"]
time:
  - platform: sntp
    timezone: Europe/Amsterdam
    on_time:
      - seconds: 0
        minutes: 45
        hours: 22
        then:
          - light.turn_off: backlight
  - platform: sntp
    on_time:
      - seconds: 0
        minutes: 00
        hours: 7
        then:
          - light.turn_on: backlight
text_sensor:
    entity_id: sensor.time
    on_value:
      then:
            text: !lambda return id(ha_time).state.c_str();
    on_value:
      - if:
          condition:
            lambda: |-
              return ((0 == x.compare(std::string{"opening"})) or (0 == x.compare(std::string{"closing"})));
          then:
                text: "STOP"
          else:
                text:
                  format: "%.0f%%"
                  args: [ 'id(cover_myroom_pos).get_state()' ]
    update_interval: 10s
    lambda: |-
      static const char* dagen[] = {"Zondag", "Maandag", "Dinsdag", "Woensdag", "Donderdag", "Vrijdag", "Zaterdag"};
      auto now = id(ha_date).now();
      std::string dag_van_week = dagen[now.strftime("%w").c_str()[0] - '0'];
      char buffer[20];
      sprintf(buffer, "%s, %02d.%02d", dag_van_week.c_str(), now.day_of_month, now.month);
      return std::string(buffer);
    on_value:
      then:
        - lambda: |-
            lv_label_set_text(id(display_date), x.c_str());
    on_value:
      then:
        - text_sensor.template.publish:
            state: !lambda return id(ha_airco_cond).state.c_str();
    lambda: |-
      std::string state = id(ha_airco_cond).state.c_str();
      if (state == "cool") { return std::string("$cool"); }
      else if (state == "heat") { return std::string("$heat"); }
      else if (state == "dry") { return std::string("$dry"); }
      else if (state == "fan") { return std::string("$fan"); }
      return std::string("$happyface");
    on_value:
      then:
        - logger.log: id(zolder_airco_icon).state.c_str()
            text: !lambda return id(zolder_airco_icon).state.c_str();
    entity_id: weather.weerstation
    filters:
      - to_upper
    on_value:
      then:
#        - lvgl.label.update:
#            id: display_weather
#            text: !lambda return id(ha_weather_cond).state.c_str();
            state: !lambda return id(ha_weather_cond).state.c_str();
    lambda: |-
      std::string state = id(ha_weather_cond).state.c_str();
      if (state == "RAINY") { return std::string("$rainy"); }
      else if (state == "CLOUDY") { return std::string("$cloudy"); }
      else if (state == "PARTLYCLOUDY") { return std::string("$partlycloudy"); }
      else if (state == "SUNNY") { return std::string("$sunny"); }
      else if (state == "FOG") { return std::string("$fog"); }
      else if (state == "HAIL") { return std::string("$hail"); }
      else if (state == "HAZY") { return std::string("$hazy"); }
      else if (state == "LIGHTNING") { return std::string("$lightning"); }
      else if (state == "LIGHTNINGRAINY") { return std::string("$lightningrainy"); }
      else if (state == "NIGHT") { return std::string("$night"); }
      else if (state == "NIGHTPARTLYCLOUDY") { return std::string("$nightpartlycloudy"); }
      else if (state == "PARTLYRAINY") { return std::string("$partlyrainy"); }
      else if (state == "PARTLYLIGHTNING") { return std::string("$partlylightning"); }
      else if (state == "PARTLYSNOWY") { return std::string("$partlysnowy"); }
      else if (state == "PARTLYSNOWYRAINY") { return std::string("$partlysnowyrainy"); }
      else if (state == "POURING") { return std::string("$pouring"); }
      else if (state == "SNOWY") { return std::string("$snowy"); }
      else if (state == "SNOWYHEAVY") { return std::string("$snowyheavy"); }
      else if (state == "SUNSET") { return std::string("$sunset"); }
      else if (state == "TORNADO") { return std::string("$tornado"); }
      else if (state == "WINDY") { return std::string("$windy"); }
      else if (state == "HURRICANE") { return std::string("$hurricane"); }
    on_value:
      then:
        - logger.log: id(weather_condition_icon).state.c_str()
            text: !lambda return id(weather_condition_icon).state.c_str();
    attribute: temperature
    on_value:
      then:
            text:
              format: "%s°C"
              args: ["id(ha_weather_temp).state.c_str()"]
binary_sensor:
    publish_initial_state: true
    on_state:
      then:
            state:
              checked: !lambda "return x;"
    entity_id: binary_sensor.radio_on
    on_state:
      then:
        - if:
            condition:
               lambda: 'return id(radio_status_sensor).state == true;'
            then:
               - lvgl.widget.show: radio_status
            else:
               - lvgl.widget.hide: radio_status
    entity_id: binary_sensor.tv_on
    on_state:
      then:
        - if:
            condition:
               lambda: 'return id(tv_status_sensor).state == true;'
            then:
               - lvgl.widget.show: tv_status
            else:
               - lvgl.widget.hide: tv_status
    entity_id: binary_sensor.schuurdeur2
    on_state:
      then:
        - if:
            condition:
               lambda: 'return id(schuur_status_sensor).state == true;'
            then:
               - lvgl.widget.show: schuur_status
            else:
               - lvgl.widget.hide: schuur_status
    entity_id: binary_sensor.garage2
    on_state:
      then:
        - if:
            condition:
               lambda: 'return id(garage_status_sensor).state == false;'
            then:
               - lvgl.widget.show: garage_status
            else:
               - lvgl.widget.hide: garage_status
    entity_id: switch.kelderlamp
    on_state:
      then:
        - if:
            condition:
               lambda: 'return id(kelder_status_sensor).state == true;'
            then:
               - lvgl.widget.show: kelder_status
            else:
               - lvgl.widget.hide: kelder_status
    entity_id: binary_sensor.boiler_tapwater_active
    on_state:
      then:
        - if:
            condition:
               lambda: 'return id(hotwater_status_sensor).state == true;'
            then:
               - lvgl.widget.show: hotwater_status
            else:
               - lvgl.widget.hide: hotwater_status
    entity_id: binary_sensor.boiler_heating_active
    on_state:
      then:
        - if:
            condition:
               lambda: 'return id(heating_status_sensor).state == true;'
            then:
               - lvgl.widget.show: heating_status
            else:
               - lvgl.widget.hide: heating_status
3rd part
# Internal outputs
output:
  # Backlight LED
  - platform: ledc
    pin: GPIO38
    frequency: 100Hz
  # Built in 240v relay
  - platform: gpio
    pin: 40
# LIGHTS
light:
  - platform: monochromatic
    output: GPIO38
    restore_mode: ALWAYS_ON
  - platform: binary
    output: panel_output
# Graphicsd and Fonts
image:
  #- file: 'images/back1.png'
  #  id: back1
  #  type: RGB565
  - file: 'images/back2.png'
    type: RGB565
  #- file: 'images/back3.png'
  #  id: back3
  #  type: RGB565
  #- file: 'images/back4.png'
  #  id: back4
  #  type: RGB565
  #- file: 'images/back5.png'
  #  id: back5
  #  type: RGB565
  - file: 'images/back6.png'
    type: RGB565
  - file: 'images/back7.png'
    type: RGB565
  - file: 'images/ha_logo2.png'
    type: RGB565
font:
  - file: "gfonts://Roboto"
    bpp: 4
    extras:
      - file: 'fonts/materialdesignicons-webfont.ttf' # http://materialdesignicons.com/cdn/7.4.47/
        glyphs: [
          "\U000F004B",
          "\U0000f0ed",
          "\U000F006E",
          "\U000F012C",
          "\U000F179B",
          "\U000F0748",
          "\U000F1A1B",
          "\U000F02DC",
          "\U000F0A02",
          "\U000F035F",
          "\U000F0156",
          "\U000F0C5F",
          "\U000f0084",
          "\U000f0091",
          "\U000F04C3",
          "\U000F0143", # mdi-arrow_up
          "\U000F0140", # mdi-arrow_down
          "\U000F050F", # Thermometer
          $house_solar,
          $house_solar2,
          $house_valve,
	  $house_hum,
          $house_temp
    bpp: 4
    extras:
        glyphs: [
          "\U000F004B",
          "\U0000f0ed",
          "\U000F006E",
          "\U000F012C",
          "\U000F179B",
          "\U000F0748",
          "\U000F1A1B",
          "\U000F02DC",
          "\U000F0A02",
          "\U000F035F",
          "\U000F0156",
          "\U000F0C5F",
          "\U000f0084",
          "\U000f0091",
          "\U000F04C3",
          $house_solar,
          $house_valve,
          $house_solar2,
          $house_hum,
          $house_temp
    bpp: 4
    glyphs: [
      "\U000F04C3",
      "\U000F0379",
      "\U000F10AF",
      "\U000F081C",
      "\U000F058F",
      "\U000F0438",
      "\U000F0872",
      "\U000F0717",
      "\U000F0510",
      "\U000F058E",
      "\U000F0210"
    bpp: 4
    extras:
        glyphs: [
          $cool,
          $heat,
          $dry,
          $fan,
          $happyface,
          $airco
    bpp: 4
    extras:
        glyphs: [
          $cool,
          $heat,
          $dry,
          $fan,
          $happyface,
          $airco,
          $powerbutton
    bpp: 4
    extras:
        glyphs: [
          $cloudy,
          $cloudyalert,
          $cloudyarrowright,
          $fog,
          $hail,
          $hazy,
          $hurricane,
          $lightning,
          $lightningrainy,
          $night,
          $nightpartlycloudy,
          $partlycloudy,
          $partlylightning,
          $partlyrainy,
          $partlysnowy,
          $partlysnowyrainy,
          $pouring,
          $rainy,
          $snowy,
          $snowyheavy,
          $snowyrainy,
          $sunny,
          $sunnyalert,
          $sunnyoff,
          $sunset,
          $sunsetdown,
          $sunsetup,
          $tornado,
          $windy,
          $windyvariant,
          $happyface
    bpp: 4
    glyphs: [
      "\U000F0335", # mdi-lightbulb
      "\U000F0769", # mdi-ceiling-light
      "\U000F08DD", # mdi-floor-lamp
      "\U000F12BA", # mdi-string-lights
    bpp: 4
    extras:
        glyphs: [
          $lightbulb,
          $house_temp,
          $airco
    bpp: 4
    extras:
        glyphs: [
          $lightbulb,
          $boiler_on,
          $boiler_off,
          $radiator,
          $ceiling_light,
          $house_temp
    bpp: 4
    extras:
        glyphs: [
          $lightbulb,
          $house_temp,
          $airco
    bpp: 4
# Touchscreen gt911 i2c
i2c:
  - id: bus_a
    sda: GPIO19
    scl: GPIO45
    #frequency: 100kHz
touchscreen:
  platform: gt911
  transform:
    mirror_x: false
    mirror_y: false
  display: my_display
  on_touch:
    - logger.log:
          format: Touch at (%d, %d)
          args: [touch.x, touch.y]
    - lambda: |-
          ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
    - script.stop: screen_light
    - script.execute: screen_light
script:
  - id: screen_light
    mode: restart
    then:
      - lvgl.resume:
      - light.turn_on:
          brightness: 100%
          transition_length: 1s
      - delay: 30s
      - light.turn_on:
            brightness: 75%
            transition_length: 2s
      - delay: 15min
      - light.turn_on:
            brightness: 75%
            transition_length: 5s
# Display st7701s spi
spi:
  - id: lcd_spi
    clk_pin: GPIO48
    mosi_pin: GPIO47
display:
  - platform: st7701s
    update_interval: never
    auto_clear_enabled: false
    data_rate: 2MHz
    spi_mode: MODE3
    color_order: RGB
    invert_colors: false
    dimensions:
      width: 480
      height: 480
    transform:
      mirror_x: false
      mirror_y: false
    cs_pin: 39
      # reset not defined
    de_pin: 18
    hsync_pin: 16
    vsync_pin: 17
    pclk_pin: 21
    init_sequence:
      - 1
      - [0xFF, 0x77, 0x01, 0x00, 0x00, 0x10] # CMD2_BKSEL_BK0
      - [0xCD, 0x00] # disable MDT flag
    pclk_frequency: 12MHz
    pclk_inverted: false
    data_pins:
      red:
        - 11         # R1
        - 12         # R2
        - 13         # R3
        - 14         # R4
        - 0          # R5
      green:
        - 8          # G0
        - 20         # G1
        - 3          # G2
        - 46         # G3
        - 9          # G4
        - 10         # G5
      blue:
        - 4          # B1
        - 5          # B2
        - 6          # B3
        - 7          # B4
        - 15         # B5
I think you need to set pad_column to 0 somewhere. With the original code there was no gap between the buttons.
I didn’t understand, which icon and text are you referring to?
I know but I got errors when I went to the lvgl implementation in esphome on style_definitions. (I posted 9 days ago) but couldn’t solve it.
I got first this cloudy text before I get the icon, on booting, but also in condition change
I moved the automation directly to the home assistant sensor, excluding the sensor template, but I’m using text instead of icons.
if you want to test to see if it works:
text_sensor:
    entity_id: weather.casa
    filters:
      - to_lower
      - substitute:
        - "- -> _"
    on_value:
          text: !lambda |-
              std::string state = id(ha_weather_cond).state.c_str(); {
                  if (state == "clear_night") return "Noite Clara";
                  else if (state == "cloudy") return "Nublado";
                  else if (state == "fog") return "Neblina";
                  else if (state == "hail") return "Granizo";
                  else if (state == "lightning") return "Relâmpagos";
                  else if (state == "lightning_rainy") return "Tempestade com Relâmpagos";
                  else if (state == "partlycloudy") return "Parcialmente Nublado";
                  else if (state == "pouring") return "Chuva forte";
                  else if (state == "rainy") return "Chuva";
                  else if (state == "snowy") return "Nevando";
                  else if (state == "snowy_rainy") return "Neve com Chuva";
                  else if (state == "sunny") return "Ensolarado";
                  else if (state == "windy") return "Ventania";
                  else if (state == "windy_variant") return "Variante Ventosa";
                  else if (state == "exceptional") return "Excepcional";
                  //else if (state == "hazy") return "Embaçado";
                  //else if (state == "nightpartlycloudy") return "Noite Parcialmente Nublada";
                  //else if (state == "partlyrainy") return "Parcialmente Chuvoso";
                  //else if (state == "partlylightning") return "Parcialmente com Relâmpagos";
                  //else if (state == "partlysnowy") return "Parcialmente Nevado";
                  //else if (state == "partlysnowyrainy") return "Parcialmente Nevado com Chuva";
                  //else if (state == "snowyheavy") return "Neve Intensa";
                  //else if (state == "sunset") return "PĂ´r do Sol";
                  //else if (state == "tornado") return "Tornado";
                  //else if (state == "hurricane") return "FuracĂŁo";
                  return state;
Sort of a bit OT, but has anyone come across a rectangular version (portrait) of this screen WITH relays?
I want to install on a distribution box but need a larger screen size with the corresponding escutcheon/surround, (no DIY) needs to look good and don’t want to have to make a separate relay board to accompany the screen.
