I have read all the posts about using NGINX as reverse proxy for HA, but all suggestions I tried didn’t solve my issue.
The configuration files are below. The scenario I want to create is a single domain (let’s call it sub.domain.tld) with various web servers behind an NGINX reverse proxy. One of those services is Home Assistant, to be accessed via https://sub.domain.tld/ha.
I should note that a setup without the /ha route works as advertised but has the side-effect of making the other web servers inaccessible (details below the configuration files) in a strange way.
Content of nginx.conf
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
events {
worker_connections 1024;
use epoll;
multi_accept on;
http {
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
server_tokens off;
# Needed for Home Assistant (?)
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
include /etc/nginx/mime.types;
default_type application/octet-stream;
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
client_body_buffer_size 10M;
client_max_body_size 100M;
server_names_hash_bucket_size 96;
add_header X-Frame-Options DENY; # don't display inside an iframe
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
Content of /etc/ngnix/sites-enabled/reverse-proxy.conf
(this is of course a softlink from sites-available/)
server {
listen 80;
server_name sub.domain.tld;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl;
# SSL settings
include /etc/nginx/snippets/strong-ssl.conf;
ssl_certificate /etc/letsencrypt/live/sub.domain.tld/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/sub.domain.tld/privkey.pem;
# Basic auth to protect the sites
auth_basic "Restricted";
auth_basic_user_file /etc/nginx/.htpasswd;
# Let's Encrypt Webroot plugin location -- allow access
location ^~ /.well-known/acme-challenge/ {
auth_basic off;
autoindex on;
# Home Assistant route
location /ha/ {
proxy_pass http://192.168.1.20:8123/;
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
# Other web server route
location /xyz {
proxy_pass bla bla;
HA configuration.yaml snippet
http:
api_password: secret
trusted_networks:
- 127.0.0.1
- 192.168.1.0/24
ip_ban_enabled: true
login_attempts_threshold: 5
base_url: sub.domain.tld/ha
use_x_forwarded_for: true
Relevant log files
nginx error.log file
[error] 3670#3670: *35 open() "/usr/share/nginx/html/static/core-2a7d01e45187c7d4635da05065b5e54e.js" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /static/core-2a7d01e45187c7d4635da05065b5e54e.js HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *35 open() "/usr/share/nginx/html/static/custom-elements-es5-adapter.js" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /static/custom-elements-es5-adapter.js HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *38 open() "/usr/share/nginx/html/static/frontend-7e13ce36d3141182a62a5b061e87e77a.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /static/frontend-7e13ce36d3141182a62a5b061e87e77a.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *37 open() "/usr/share/nginx/html/static/mdi-89074face5529f5fe6fbae49ecb3e88b.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /static/mdi-89074face5529f5fe6fbae49ecb3e88b.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *37 open() "/usr/share/nginx/html/frontend/panels/map-565db019147162080c21af962afc097f.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/map-565db019147162080c21af962afc097f.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *38 open() "/usr/share/nginx/html/frontend/panels/kiosk-b40aa5cb52dd7675bea744afcf9eebf8.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/kiosk-b40aa5cb52dd7675bea744afcf9eebf8.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *39 open() "/usr/share/nginx/html/frontend/panels/history-fe2daac10a14f51fa3eb7d23978df1f7.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/history-fe2daac10a14f51fa3eb7d23978df1f7.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *35 open() "/usr/share/nginx/html/frontend/panels/dev-template-928e7b81b9c113b70edc9f4a1d051827.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/dev-template-928e7b81b9c113b70edc9f4a1d051827.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *37 open() "/usr/share/nginx/html/frontend/panels/logbook-771afdcf48dc7e308b0282417d2e02d8.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/logbook-771afdcf48dc7e308b0282417d2e02d8.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *38 open() "/usr/share/nginx/html/frontend/panels/config-61f65e75e39368e07441d7d6a4e36ae3.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/config-61f65e75e39368e07441d7d6a4e36ae3.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *40 open() "/usr/share/nginx/html/frontend/panels/dev-state-7948d3dba058f31517d880df8ed0e857.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/dev-state-7948d3dba058f31517d880df8ed0e857.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *39 open() "/usr/share/nginx/html/frontend/panels/dev-event-d409e7ab537d9fe629126d122345279c.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/dev-event-d409e7ab537d9fe629126d122345279c.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *35 open() "/usr/share/nginx/html/frontend/panels/dev-info-b0e55eb657fd75f21aba2426ac0cedc0.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/dev-info-b0e55eb657fd75f21aba2426ac0cedc0.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *37 open() "/usr/share/nginx/html/frontend/panels/dev-service-422b2c181ee0713fa31d45a64e605baf.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/dev-service-422b2c181ee0713fa31d45a64e605baf.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
[error] 3670#3670: *41 open() "/usr/share/nginx/html/frontend/panels/dev-mqtt-94b222b013a98583842de3e72d5888c6.html" failed (2: No such file or directory), client: 192.168.1.152, server: sub.domain.tld, request: "GET /frontend/panels/dev-mqtt-94b222b013a98583842de3e72d5888c6.html HTTP/1.1", host: "sub.domain.tld", referrer: "https://sub.domain.tld/ha/"
Home Assistant log file
INFO (MainThread) [homeassistent.components.http] Serving / to 192.168.1.152 (auth: True)
Browser window
Message in browser window (Chrome or FF): “Home Assistant had trouble connecting to the server. TRY AGAIN”
If I leave out the /ha/ part in both the NGINX and HA configuration files, it works fine for HA, but than other routes via the same reverse proxy start to fail, probably because of the javascripts and caching for HA that somehow get loaded for other URL routes (e.g. sub.domain.tld/xyz). These other routes work initially as expected until I visit https://sub.domain.tld/ha once to display the HA page. From then on the previously accessible web server pages fail to load and show a partial HA screen (just the left menu and the blue top bar) instead of their own web pages.
What am I missing here? ;o(
