/// which integration makes you have such file, in /config ? , i have never seen such file, so i guess it must be related to some “specific” integration /// … <<< Ignore that . some people might have seen such file, in a default installation, thou “unknown” in which situations this is created
OK, so it’s an auto-generated, thou not necessarily created prior to those “log-messages” ( not sure what “triggers” the creation, or when )
Good to hear, that it seems to turn out well for you
PS: I assume it was this post
in that Topic which you followed, un fortunately is it not “marked as Solved ( His “solved mark” is " i gave up” ) — You should/could mark your post above where you refers to the solution, as it might help others in same situation.
