with install-media i did mean, another sd / SSD , or same ?
Oh, yes, another SSD as my NUC as integrated SSD (might be nvme)
Ok, when people says Reboot, it means Reboot, i.e turn off your server AND start it again ā¦ did you just Restart ?
Host
First entry
Oct 12 20:09:52 homeassistant systemd
Oct 12 20:41:17 homeassistant systemd
No Reboot inbetween ! , To rebuild the DB a Reboot is needed
Supervisor
First entry 23-10-12 15:30:57
23-10-12 15:53:01 INFO (SyncWorker_2) [supervisor.docker.manager] Restarting homeassistant ( Not Rebooting) iāts Your manually restart !
Last entry 23-10-12 16:38:57
So here it 's Supervisor which are āRestartingā ā¦ NOTE the gap of 5min, of itās repeated API requests
And among other things complaining about āmissingā schemas
Also itās fetching Updates from GitHub,(meaning so far so good), just before these āmissing schemasā occurs
Im not aware whether itās do to the fact you might have installed ālatestā HA-OS , and āappliedā and āolder/already corruptā backup-file , or whether HA can/will recreate the DB after a Reboot
Othervice as you See, NodeRed SambaShare
I guess Iāll be rebuilding from scratch. Just reinstalled and no reboot for now
First, save your yaml files. They wonāt change much, if at all.
Weird issue. I completely reinstalled, used to work great, didnāt add anything special, just add-ons.
All of a sudden, it seems like itās crashing every day (instead of every 7 min)
Well, as your on whole new hardware, with ssd instead of sd, and a new āclean installā ) NO āoldā broken/faulty backup files applied ?, then i guess you have to monitor, your log-files ( and your storage-size ) , AND btw ( it seems like itās crashing every day ) is Absolute not a ātechnicalā description, itās in fact just useless information , and you dont even specify what crashes ???, Supervisor ??? Host ??? your NUC ?
What does the logfiles says ??? have you tried enabling DEBUG ???.
Obviously beside your āreporting methodā you should also āexamineā your install/maintenance/troubleshooting Methods
