yes im sure we all(most) know the difference between “Supervisor” and supervised" , but in common “terminology” most people talking about HA-setup uses “Supervisor” for a supervised, installation … the reason i chosed to start with “Supervised”, was that 1. i might have a “control-issue”
, 2. i wanted “Supervisor” functionality as-well, and i had no experience in regards to HA , as mentioned above, most reason for home-automation is to make life easier, convenient and comfortable
… and cant say i regret starting out, with “Supervised” with supervisor, but after 5-6 month, i took it offline, main reason i wanted to “transfer” various devices into a common “concept”, and the choice felt on HA, after some research, and i’ve been around since mid 80th, first pc, IBM, with intel i80286, worked with server-administration, integration, network, hardwareupgrade etc. etc… … what could go wrong ?
… well 1. i wanted an easy maintained environment, with the least amount of time spend using VI, emacs or notepad++ ( therefore the brilliant “Supervisor”)
… 2.And maybe most important, learn about HA, ( thou ofcause also including yaml,py etc.) … October i took “Supervised” offline for same reasons, and “bite the dust” installed HA in VM … On Windows ( so when i say , id like to go towards hass-os in vm i mend, in VB, on linux, so far im soo satisfied with ( recommended supported) installation in windows , performance-vice absolutely not a reason to not choose this setup( maybe because i’ve been around for a while, and know that “time!” chances, “resource” is just a matter of thinking ahead, and in a vm on windows i have 8 add-ons, 25 integrations( not counting HACS-frontend), and it’s been so must more fun ( AND less time spend, on the tasks i was looking to reduce, maintenance ) … i have already forgot the hassle, irritation, and time i spend on “Supervised” , joined this forum, when i redesigned my “home” network due to new router, that can handle the load, have most devices integrated ( that i had “i store”), so i could lean back, if it wasn’t for the “Big” task ahead, integrate my heating/cooling system
… yes i did realized that, “poking” around in HA’s OS (in a VM) had to be done via ssh or so, and as i also have no experience from “Container” topology, this was also new to me, … to sum upp i find way more benefit with VM/VB setup as im retired (not retarded, as some might think
