🎉 "HA over iHost" Open Source Project is Officially Live — Try It Out and Join the Community!
Second crash occurred. First one after one week of running. (Due to cube update schema?) Second crash after 2 weeks flauless running. Is there still dependances with the ihost os. And pulling ha down?
We’re happy to share that the Matter Server Add-on is now available and can run on HA over iHost.
This version has been built and tested to work on 32-bit systems, making it easier to integrate Matter devices on iHost.
You can find the add-on and usage instructions here.
Here are some notes when using Matter Server add-on on iHost:
  1. If you want to Commission new Wi-Fi device in the Matter Server Web UI, you’ll need to set bluetooth_adapter_id: 0 in the Configuration tab.
  1. Deselect the checkbox in the prompt when adding Matter integration.
Hi! Thanks a lot for reporting this — and sorry to hear you’re experiencing crashes.
Just to clarify: once HAOS is booted from the SD card, it runs fully independently from the iHost’s original CUBE system. There are no runtime dependencies on eWeLink CUBE services or schema updates. So CUBE OS updates should not affect HAOS stability in any way.
That said, we absolutely want to help get to the bottom of this.
  • If possible, could you share any system logs around the time of the crash?
    You can find them in: Settings → System → Logs
  • Also, let us know if you were running any specific add-ons or integrations before the crash.
Since HAOS is running from a microSD card, storage quality can have a direct impact on long-term stability.
Could you let us know the brand and model of the TF card you’re currently using?
We recommend using an Application Class 2 (A2) microSD card with at least 32GB capacity for better performance, especially for small random read/write operations.
We’ve had the best testing results with SanDisk, Kingston, or Samsung cards — these are the ones we use internally.
If you’re currently using a generic or low-endurance card, switching to one of the recommended brands may help improve overall system reliability.
New Release: OpenThread Border Router Add-on for iHost
We’ve built a 32-bit compatible version of the OpenThread Border Router add-on for use with HA over iHost.
This allows iHost (ARMv7) users to run an OpenThread Border Router directly in Home Assistant, enabling Matter-over-Thread integration in local environments.
You can find it here:
:link: OpenThread Border Router Add-on (32-bit build)
Let us know if you try it — feedback is welcome!
New Release: Silicon Labs Multiprotocol Add-on
We are excited to announce the release of our Silicon Labs Multiprotocol Add-on! This add-on enables simultaneous use of Zigbee and OpenThread protocols on a single Silicon Labs based radio. To support multiple IEEE 802.15.4 Personal Area Networks (PAN), the radio needs to have the RCP Multi-PAN firmware installed.
Supported Architectures:
  • armv7
  • aarch64
  • amd64
This add-on is modified from the Silicon Labs Multiprotocol Addon and has been successfully tested on the SONOFF ZBDongle-E.
For installation instructions and more details, please refer to the README.
Feel free to try it out and provide feedback!
:rocket: [Giveaway Alert] Want to try HA over iHost?
We just launched a giveaway for our “HA over iHost” project! :gift:
If you’re an active HA user and would like to test Home Assistant OS on iHost hardware, we’re sending out free iHost RV1109 devices to selected users.
Just share your current HA setup & use case and tell us how you’d like to use iHost.
We’re looking for real users with real stories — your feedback will help shape the next version of iHost!
:point_right: Check out the details here:
Looking forward to hearing your story!
@LonelystartO any news on “next-generation of iHost” from Sonoff/ITead or eWeLink/CoolKit?
Also wondering if plan to sell models of such a next-generation Sonoff iHost pre-loaded with the Home Assistant Operating System? …hopefully it will be 64-bit and support some AI acceleration?
@LonelystartO Suggest that youy could add value maybe take inspiration from Dunsun DSGW-290 hardware which has an M.2 storage slot and includes support for optional Frigate NVR add-on with on-device Local AI Object Detection:
Of course, if add several USB-ports then external harddrive is an option to internal M.2 harddrive.
Anyway, option to run Frigate NVR add-on locally would be good, local storage better, and on-device Local AI Object Detection great!
Cross-posting from Post a deprecate warning since Sonoff iHost uses a 32-bit CPU that will soon no longer be supported · Issue #11 · iHost-Open-Source-Project/ha-operating-system · GitHub
New Release: Zigbee2MQTT Add-on for iHost
Zigbee2MQTT has officially dropped support for 32-bit add-ons. To ensure iHost users can continue using Zigbee2MQTT without interruption, we are maintaining and providing the latest working version specifically for 32-bit systems.
Link
