is this some kind of workaround for HA startup Automation issue? won’t it trigger again when HA is running and state of sun.sun change to above_horizon?
Of course, I wasn’t thinking, this won’t work for restart trigger alternative. I will experiment with from ‘unknown’ perhaps with another sensor. Thanks
I corrected my restart trigger replacement by turning off the automation at the end of the action so not to be triggered again until next restart. In fact, you can use anything to trigger like time as long as you shut off the automation in the action.
automation restart:
alias: restart
initial_state: 'on'
- platform: state
entity_id: sun.sun
to: 'above_horizon'
- platform: state
entity_id: sun.sun
to: 'below_horizon'
- delay: 00:00:05
- service: logbook.log
data_template:
message: Restart replacement has been triggered
- service: automation.turn_off
entity_id: automation.restart
Btw, you can turn off the automation as the first action too. Putting it first doesn’t stop the rest of the actions from running, it just disables the triggers.
Doesn’t matter in this case (unless the sun changes state again within five seconds) but for other triggers it might.
