My Home Assistant (homeassistant 0.28.0) stopped working all of a sudden.
Here is the log. I have tried updating to homeassistant-0.28.2, but no luck in starting HA.
Please help.
Sep 15 22:28:15 RaspberryPi3 systemd[1]: Starting Home Assistant...
Sep 15 22:28:15 RaspberryPi3 systemd[1]: Started Home Assistant.
Sep 15 22:28:16 RaspberryPi3 hass[5629]: Traceback (most recent call last):
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "/srv/hass/bin/hass", line 11, in <module>
Sep 15 22:28:16 RaspberryPi3 hass[5629]: sys.exit(main())
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "/srv/hass/lib/python3.4/site-packages/homeassistant/__main__.py", line 313, in main
Sep 15 22:28:16 RaspberryPi3 hass[5629]: args = get_arguments()
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "/srv/hass/lib/python3.4/site-packages/homeassistant/__main__.py", line 75, in get_arguments
Sep 15 22:28:16 RaspberryPi3 hass[5629]: import homeassistant.config as config_util
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "/srv/hass/lib/python3.4/site-packages/homeassistant/config.py", line 17, in <module>
Sep 15 22:28:16 RaspberryPi3 hass[5629]: from homeassistant.core import valid_entity_id
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "/srv/hass/lib/python3.4/site-packages/homeassistant/core.py", line 33, in <module>
Sep 15 22:28:16 RaspberryPi3 hass[5629]: import homeassistant.util as util
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "/srv/hass/lib/python3.4/site-packages/homeassistant/util/__init__.py", line 17, in <module>
Sep 15 22:28:16 RaspberryPi3 hass[5629]: from .dt import as_local, utcnow
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "/srv/hass/lib/python3.4/site-packages/homeassistant/util/dt.py", line 8, in <module>
Sep 15 22:28:16 RaspberryPi3 hass[5629]: import pytz
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "/srv/hass/lib/python3.4/site-packages/pytz/__init__.py", line 33, in <module>
Sep 15 22:28:16 RaspberryPi3 hass[5629]: from pytz.tzinfo import unpickler
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "<frozen importlib._bootstrap>", line 2237, in _find_and_load
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "<frozen importlib._bootstrap>", line 2226, in _find_and_load_unlocked
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "<frozen importlib._bootstrap>", line 1200, in _load_unlocked
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "<frozen importlib._bootstrap>", line 1129, in _exec
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "<frozen importlib._bootstrap>", line 1467, in exec_module
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "<frozen importlib._bootstrap>", line 1570, in get_code
Sep 15 22:28:16 RaspberryPi3 hass[5629]: File "<frozen importlib._bootstrap>", line 656, in _compile_bytecode
Sep 15 22:28:16 RaspberryPi3 hass[5629]: ValueError: bad marshal data (invalid reference)
Sep 15 22:28:16 RaspberryPi3 systemd[1]: home-assistant.service: main process exited, code=exited, status=1/FAILURE
Sep 15 22:28:16 RaspberryPi3 systemd[1]: Unit home-assistant.service entered failed state.
Update log
100% |ââââââââââââââââââââââââââââââââ| 6.2MB 32kB/s
Requirement already up-to-date: pip>=7.0.0 in /srv/hass/lib/python3.4/site-packages (from homeassistant)âââââââââââââââââ
Requirement already up-to-date: pytz>=2016.6.1 in /srv/hass/lib/python3.4/site-packages (from homeassistant)ââââââââââââ
Requirement already up-to-date: jinja2>=2.8 in /srv/hass/lib/python3.4/site-packages (from homeassistant)ââââââââââââââ
Requirement already up-to-date: requests<3,>=2 in /srv/hass/lib/python3.4/site-packages (from homeassistant)ââââââââââ
Requirement already up-to-date: voluptuous==0.9.2 in /srv/hass/lib/python3.4/site-packages (from homeassistant)ââââââ
Requirement already up-to-date: typing<4,>=3 in /srv/hass/lib/python3.4/site-packages (from homeassistant)âââââââââââ
Requirement already up-to-date: pyyaml<4,>=3.11 in /srv/hass/lib/python3.4/site- 100% |ââââââââââââââââââââââââââââââââ| 471kB 110kB/s
Installing collected packages: homeassistant, setuptools
Found existing installation: homeassistant 0.28.0
Uninstalling homeassistant-0.28.0:
Successfully uninstalled homeassistant-0.28.0
Found existing installation: setuptools 27.1.2
Uninstalling setuptools-27.1.2:
Successfully uninstalled setuptools-27.1.2
Successfully installed homeassistant-0.28.2 setuptools-27.2.0
