HA stops reporting Wink state changes
Awesome news, wish I was having the same results. Makes me think I have some other problem. I think you are good to go, let me know if anything changes.
It would be nice, but it also added support for a new platform (Thermostats) so no. Wishing I would have made two different pull requests.
I’m still good over here and in fact got an immediate notification when the mailbox sensor was tripped.
@w1ll1am23 it finally reared it’s ugly head on my system. Couldn’t figure out why I hadn’t gotten a mailbox notification and went out to check and the mail was there. Didn’t register when I opened it either. Went back inside and tried to turn on the front door light and it didn’t register. Also showed the door still locked from this morning when I went to vote.
Did a reboot and the door showed unlocked again, and the light was registering as on. I was able to turn it off and the state updated correctly - so it’s not just your setup.
I had my logger set to warning only and I didn’t see anything related to Wink. Let me know what can I do to help track this down.
Thanks for the update. If you are running on Linux can you check your journalctl output for pubnub and see if you see any tracebacks? You are running 0.32 correct? Not dev?
What’s the command for that? I’m not that familiar with journalctl.
I am running Raspian Jessie and HA 0.32.2
sudo journalctl -u NAME_OF_HA_SERVICE > log.log
That will output everything to a file called log.log the name if the service can very, but it should be easy to find if you run systemctl status h[TAB] I think it will auto complete with the service name.
I did a reboot though; should I still run this or wait until the state issue shows again?
Yeah should be fine to run. I am not sure on how far the logs go back, but mine goes back for several days.
I’m not sure there’s much to see here but here goes.
-- Logs begin at Tue 2016-11-08 16:40:47 EST, end at Tue 2016-11-08 19:15:34 EST. --
Nov 08 16:41:09 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:41:38 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:42:09 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:42:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478641350,"wtst":1462914442,"t":"b"}
Nov 08 16:42:39 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:43:08 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:43:38 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:44:08 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:44:38 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:45:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478641500,"wtst":1462914442,"t":"b"}
Nov 08 16:45:09 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:45:38 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:46:08 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:46:39 raspi1 hass[18649]: ERROR:homeassistant.components.sensor.snmp:SNMP error: No SNMP response received before timeout
Nov 08 16:47:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478641650,"wtst":1462914442,"t":"b"}
Nov 08 16:50:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478641800,"wtst":1462914442,"t":"b"}
Nov 08 16:52:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478641950,"wtst":1462914442,"t":"b"}
Nov 08 16:55:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478642100,"wtst":1462914442,"t":"b"}
Nov 08 16:57:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478642250,"wtst":1462914442,"t":"b"}
Nov 08 17:00:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478642400,"wtst":1462914442,"t":"b"}
Nov 08 17:02:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478642550,"wtst":1462914442,"t":"b"}
Nov 08 17:05:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478642700,"wtst":1462914442,"t":"b"}
Nov 08 17:07:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478642850,"wtst":1462914442,"t":"b"}
Nov 08 17:10:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478643000,"wtst":1462914442,"t":"b"}
Nov 08 17:12:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478643150,"wtst":1462914442,"t":"b"}
Nov 08 17:15:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478643300,"wtst":1462914442,"t":"b"}
Nov 08 17:17:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478643450,"wtst":1462914442,"t":"b"}
Nov 08 17:20:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478643600,"wtst":1462914442,"t":"b"}
Nov 08 17:22:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478643750,"wtst":1462914442,"t":"b"}
Nov 08 17:25:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478643900,"wtst":1462914442,"t":"b"}
Nov 08 17:27:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478644050,"wtst":1462914442,"t":"b"}
Nov 08 17:30:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478644200,"wtst":1462914442,"t":"b"}
Nov 08 17:32:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478644350,"wtst":1462914442,"t":"b"}
Nov 08 17:35:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478644500,"wtst":1462914442,"t":"b"}
Nov 08 17:37:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478644650,"wtst":1462914442,"t":"b"}
Nov 08 17:40:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478644800,"wtst":1462914442,"t":"b"}
Nov 08 17:42:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478644950,"wtst":1462914442,"t":"b"}
Nov 08 17:45:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478645100,"wtst":1462914442,"t":"b"}
Nov 08 17:47:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478645250,"wtst":1462914442,"t":"b"}
Nov 08 17:50:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478645400,"wtst":1462914442,"t":"b"}
Nov 08 17:52:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478645550,"wtst":1462914442,"t":"b"}
Nov 08 17:55:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478645700,"wtst":1462914442,"t":"b"}
Nov 08 17:57:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478645850,"wtst":1462914442,"t":"b"}
Nov 08 18:00:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478646000,"wtst":1462914442,"t":"b"}
Nov 08 18:02:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478646150,"wtst":1462914442,"t":"b"}
Nov 08 18:05:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478646300,"wtst":1462914442,"t":"b"}
Nov 08 18:07:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478646450,"wtst":1462914442,"t":"b"}
Nov 08 18:10:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478646600,"wtst":1462914442,"t":"b"}
Nov 08 18:11:29 raspi1 hass[18649]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
Nov 08 18:11:29 raspi1 hass[18649]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
Nov 08 18:11:29 raspi1 hass[18649]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant>
Nov 08 18:11:29 raspi1 hass[18649]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=reload_core_config, domain=homeassistant>
Nov 08 18:11:29 raspi1 hass[18649]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=create, domain=persistent_notification>
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.bootstrap:Home Assistant core initialized
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded input_boolean from homeassistant.components.input_boolean
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded script from homeassistant.components.script
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded group from homeassistant.components.group
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded history from homeassistant.components.history
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded http from homeassistant.components.http
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded scene from homeassistant.components.scene
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded mqtt from homeassistant.components.mqtt
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded wink from homeassistant.components.wink
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded api from homeassistant.components.api
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded ecobee from homeassistant.components.ecobee
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded zone from homeassistant.components.zone
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded device_tracker from homeassistant.components.device_tracker
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded shell_command from homeassistant.components.shell_command
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded ifttt from homeassistant.components.ifttt
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded proximity from homeassistant.components.proximity
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded notify from homeassistant.components.notify
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded logger from homeassistant.components.logger
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded alexa from homeassistant.components.alexa
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded binary_sensor from homeassistant.components.binary_sensor
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded light from homeassistant.components.light
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded nest from homeassistant.components.nest
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded automation from homeassistant.components.automation
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded zwave from homeassistant.components.zwave
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded alarm_control_panel from homeassistant.components.alarm_control_panel
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.loader:Loaded media_player from homeassistant.components.media_player
Nov 08 18:11:30 raspi1 hass[18649]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
Nov 08 18:11:36 raspi1 hass[18649]: WARNING:homeassistant.components.sensor.statistics:mean requires at least one data point
Nov 08 18:11:36 raspi1 hass[18649]: WARNING:homeassistant.components.sensor.template:UndefinedError: 'None' has no attribute 'state'
Nov 08 18:11:36 raspi1 hass[18649]: WARNING:homeassistant.components.sensor.template:UndefinedError: 'None' has no attribute 'attributes'
Nov 08 18:11:39 raspi1 hass[18649]: WARNING:homeassistant.components.sensor.statistics:variance requires at least two data points
Nov 08 18:11:48 raspi1 hass[18649]: WARNING:homeassistant.components.sensor.template:UndefinedError: 'None' has no attribute 'state'
Nov 08 18:11:51 raspi1 hass[18649]: WARNING:homeassistant.components.sensor.template:UndefinedError: 'None' has no attribute 'state'
Nov 08 18:12:06 raspi1 hass[18649]: ERROR:homeassistant.components.media_player.firetv:Could not connect to firetv-server at localhost
Nov 08 18:12:17 raspi1 hass[18649]: WARNING:homeassistant.components.sensor.template:UndefinedError: 'None' has no attribute 'state'
Nov 08 18:12:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478646750,"wtst":1462914442,"t":"b"}
Nov 08 18:12:44 raspi1 hass[18649]: ERROR:netdisco.ssdp:Error fetching description at https://192.168.1.242:8888
Nov 08 18:12:45 raspi1 hass[18649]: ERROR:netdisco.ssdp:Error fetching description at https://192.168.1.159:8888
Nov 08 18:12:47 raspi1 hass[18649]: WARNING:homeassistant.components.zwave:zwave not ready after 30 seconds, continuing anyway
Nov 08 18:15:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478646900,"wtst":1462914442,"t":"b"}
Nov 08 18:17:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478647050,"wtst":1462914442,"t":"b"}
Nov 08 18:20:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478647200,"wtst":1462914442,"t":"b"}
Nov 08 18:22:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478647350,"wtst":1462914442,"t":"b"}
Nov 08 18:25:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478647500,"wtst":1462914442,"t":"b"}
Nov 08 18:27:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478647650,"wtst":1462914442,"t":"b"}
Nov 08 18:30:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478647800,"wtst":1462914442,"t":"b"}
Nov 08 18:32:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478647950,"wtst":1462914442,"t":"b"}
Nov 08 18:35:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478648100,"wtst":1462914442,"t":"b"}
Nov 08 18:37:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478648250,"wtst":1462914442,"t":"b"}
Nov 08 18:40:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478648400,"wtst":1462914442,"t":"b"}
Nov 08 18:42:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478648550,"wtst":1462914442,"t":"b"}
Nov 08 18:45:01 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478648700,"wtst":1462914442,"t":"b"}
Nov 08 18:47:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478648850,"wtst":1462914442,"t":"b"}
Nov 08 18:50:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478649000,"wtst":1462914442,"t":"b"}
Nov 08 18:52:31 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478649150,"wtst":1462914442,"t":"b"}
Nov 08 18:55:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478649300,"wtst":1462914442,"t":"b"}
Nov 08 18:57:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478649450,"wtst":1462914442,"t":"b"}
Nov 08 19:00:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478649600,"wtst":1462914442,"t":"b"}
Nov 08 19:02:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478649750,"wtst":1462914442,"t":"b"}
Nov 08 19:05:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478649900,"wtst":1462914442,"t":"b"}
Nov 08 19:07:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478650050,"wtst":1462914442,"t":"b"}
Nov 08 19:10:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478650200,"wtst":1462914442,"t":"b"}
Nov 08 19:12:30 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478650350,"wtst":1462914442,"t":"b"}
Nov 08 19:15:00 raspi1 hass[18649]: WARNING:homeassistant.components.device_tracker.owntracks:Ignoring GPS in region exit because accuracyis zero: {"_type":"transition","tid":"ra","acc":0.0,"desc":"home","event":"leave","lat":40.658933,"lon":-74.390372,"tst":1478650500,"wtst":1462914442,"t":"b"}
Yeah, not seeing anything could be because of your logging levels. Thanks for looking.
OK, I am resetting to standard logging and will let it run. If I see the behavior again, I’ll shoot you the log.
@w1ll1am23, sorry I’m just jumping back into this conversation, as far as the situation with @rpitera, if hes running 0.32, not dev, we should be expecting this behavior correct?
As far as my situation, I’ve had several issues with Wink itself not updating the state in the last few days so I haven’t had a long duration without a restart of HA (I was thinking it was a HA issue again and restarting but turns out it was a Wink problem, seems to be resolved now). But I will say I think everything is working fine on my end, I’ve seen several instances of sensors going unavailable that would have killed HA before but its not causing issues now.
Version mentioned here:
Right, that was my point. The fix for this problem is only in the dev branch currrently, it wouldn’t be implemented in version 0.32.2 AFAIK.
Sorry, I read that wrong. Now I understand what you were saying.
Any update here? So far I have been running the pubnub update automation which seems to be working.
I am working on this daily trying to find a programmatic solution. I think I made a break through this morning though!
Every morning when I wake up, none of my sensors are working. I try something new every morning. This morning I subscribed to a sensors pubnub channel via pubnubs debug console https://www.pubnub.com/docs/console I then tried to activate the sensors and never received an update in HA or the debug console. I unsubscribed and resubscribed multiple times with no luck. I then manually made a Wink API request to /users/me/wink_devices and then tried to activate the sensor again. At this point the debug console and HA started reporting! I am implementing some test code now to poll the Wink API at /user/me/wink_devices every hour to see if this works out.
I will keep everyone updated.
I have gone two morning in a row now without issues!
This is going to be a pretty major change and is going to require a PR for python-wink https://github.com/python-wink/python-wink/pull/60.
It also removes the PubNub requirement from HomeAssistant and replaces it with a new library I have written https://github.com/w1ll1am23/pubnubsub-handler which is using the new PubNub v4 SDK.
As soon as the python-wink PR is merged in I will start work on opening the HomeAssistant PR. In the mean time, I really would like some assistance testing this out. If anyone has the ability to run my fork of HomeAssistant please let me know and I can get you setup testing this!
I’m willing to test.
