Many Thanks Luma for the new version, I’m installing it.
Hello, i need a small help for setup my cover with slider
i change code:
# when the user moves the slider, change the light in Hass
- alias: hasp_chambre1_p4_Dimmer7UpdateHass
- platform: mqtt
topic: "hasp/chambre1/state/p[4].b[7].val"
- service: cover.set_cover_position
data_template:
entity_id: cover.fibaro_volet_principale_level
position: "{{ trigger.payload }}"
# When the light is changed in Hass, update HASP to move the dimmer
- alias: hasp_chambre1_p4_Dimmer7UpdateHASP
- platform: state
entity_id: "binary_sensor.chambre1_connected"
to: "on"
- platform: homeassistant
event: start
- platform: state
- service: mqtt.publish
data_template:
topic: "hasp/chambre1/command/p[4].b[7].val"
payload_template: "{{states.cover.fibaro_volet_principale_level.attributes.current_position|default(0)|int}}"
and is work but slider don’t go over middle because brigtness is 0 to 255 position and cover is 0 to 100
easy way is multiplied by 2.55 i don’t no who make that
thanks for your help
Hello, i don’t understand your p9_hvac.yaml “temp_high/temp_low”
for me it’s more efficient and easy to setup like this
for controling air conditioner is perfect
So i tried to adapt P9 plate and is work for 80%
All mode, b9 (+) and b12 (-) work, if i click on them i can change mode or turn off, i can change temp b9 for +1° and b12 for -1°
but i can’t change background color on b5 and on right side nothing on screen
my code
# Automations for handling climate controls on page 9
automation:
# Set font and text labels for scene buttons on device connection
- alias: hasp_chambre1_p9_HVACInit
- platform: state
to: "on"
event: start
topic: "hasp/chambre1/command/json"
payload_template: >-
["p[9].b[4].font=8","p[9].b[4].txt=\"\"",
"p[9].b[5].font=8","p[9].b[5].txt=\"\"",
"p[9].b[6].font=10","p[9].b[6].ycen=2",
"p[9].b[7].font=8","p[9].b[7].txt=\"\"",
"p[9].b[8].font=8","p[9].b[8].txt=\"\"",
"p[9].b[9].font=10","p[9].b[9].bco=63488","p[9].b[9].txt=\"+\"",
"p[9].b[10].font=8","p[9].b[10].txt=\"\"",
"p[9].b[11].font=8","p[9].b[11].txt=\"\"",
"p[9].b[12].font=10","p[9].b[12].bco=31","p[9].b[12].txt=\"-\""]
topic: "hasp/chambre1/command/p[9].b[6].txt"
payload_template: '{{ state_attr("climate.office_ac", "temperature") }}'
# Catch either of the "mode" buttons, iterate through the list of supported modes, and
# select the next one in the list or loop back to the beginning if it's the last item
- alias: hasp_chambre1_p9_HVACModeB4
- platform: mqtt
topic: "hasp/chambre1/state/p[9].b[4]"
payload: "ON"
- service: climate.set_hvac_mode
entity_id: "climate.office_ac"
hvac_mode: "off"
- alias: hasp_chambre1_p9_HVACModeB5
- platform: mqtt
topic: "hasp/chambre1/state/p[9].b[5]"
payload: "ON"
hvac_mode: "heat"
- alias: hasp_chambre1_p9_HVACModeB7
- platform: mqtt
topic: "hasp/chambre1/state/p[9].b[7]"
payload: "ON"
hvac_mode: "cool"
- alias: hasp_chambre1_p9_HVACModeB8
- platform: mqtt
topic: "hasp/chambre1/state/p[9].b[8]"
payload: "ON"
hvac_mode: "dry"
- alias: hasp_chambre1_p9_HVACModeB10
- platform: mqtt
topic: "hasp/chambre1/state/p[9].b[10]"
payload: "ON"
hvac_mode: "fan_only"
- alias: hasp_chambre1_p9_HVACModeB11
- platform: mqtt
topic: "hasp/chambre1/state/p[9].b[11]"
payload: "ON"
hvac_mode: "heat_cool"
# Display current HVAC temp on HASP when updated in Home Assistant
- alias: hasp_chambre1_p9_UpdateHVACTemp
platform: state
condition:
condition: template
value_template: '{{ trigger.from_state and trigger.to_state.attributes.temperature != trigger.from_state.attributes.temperature }}'
payload_template: '{{ state_attr("climate.office_ac", "temperature") }}°'
# Increment HVAC high temp set point when p[9].b[9] is pressed
- alias: hasp_chambre1_p9_SetHVACTempPlus
- platform: mqtt
topic: "hasp/chambre1/state/p[9].b[9]"
payload: "ON"
- service: climate.set_temperature
data_template:
temperature: '{{ state_attr("climate.office_ac", "temperature") + 1 | int}}'
# Decrement HVAC high temp set point when p[9].b[12] is pressed
- alias: hasp_chambre1_p9_SetHVACTempMinus
- platform: mqtt
topic: "hasp/chambre1/state/p[9].b[12]"
payload: "ON"
data_template:
temperature: '{{ state_attr("climate.office_ac", "temperature") - 1 | int}}'
# Automations to set colors on HASP Page 9
- alias: hasp_chambre1_p9_ColorConfig_selectedbackgroundcolor
- platform: state
to: "on"
event: start
- platform: state
entity_id: input_number.hasp_chambre1_selectedbackgroundcolor
["p[9].b[4].pco={{ states('input_number.hasp_chambre1_selectedbackgroundcolor')|int }}",
"p[9].b[5].bco={{ states('input_number.hasp_chambre1_selectedbackgroundcolor')|int }}",
"p[9].b[6].bco={{ states('input_number.hasp_chambre1_selectedbackgroundcolor')|int }}",
"p[9].b[7].pco={{ states('input_number.hasp_chambre1_selectedbackgroundcolor')|int }}",
"p[9].b[8].pco={{ states('input_number.hasp_chambre1_selectedbackgroundcolor')|int }}",
"p[9].b[9].bco={{ states('input_number.hasp_chambre1_selectedbackgroundcolor')|int }}",
"p[9].b[10].pco={{ states('input_number.hasp_chambre1_selectedbackgroundcolor')|int }}",
"p[9].b[11].pco={{ states('input_number.hasp_chambre1_selectedbackgroundcolor')|int }}",
"p[9].b[12].bco={{ states('input_number.hasp_chambre1_selectedbackgroundcolor')|int }}"]
- alias: hasp_chambre1_p9_ColorConfig_unselectedforegroundcolor
- platform: state
to: "on"
event: start
- platform: state
entity_id: input_number.hasp_chambre1_unselectedforegroundcolor
[{%- for i in range(4,13) -%}"p[9].b[{{i}}].pco2={{ states('input_number.hasp_chambre1_unselectedforegroundcolor')|int }}"{% if not loop.last %},{% endif %}{%- endfor -%}]
- alias: hasp_chambre1_p9_ColorConfig_unselectedbackgroundcolor
- platform: state
to: "on"
event: start
- platform: state
entity_id: input_number.hasp_chambre1_unselectedbackgroundcolor
[{%- for i in range(4,13) -%}"p[9].b[{{i}}].bco2={{ states('input_number.hasp_chambre1_unselectedbackgroundcolor')|int }}"{% if not loop.last %},{% endif %}{%- endfor -%}]
if you can help me thank you
Not sure if this is your problem, but at the bottom of your P9 automations you just posted I’m not seeing the hasp_plate01_p9_ColorConfig_selectedforegroundcolor
automation. Did you remove that on purpose?
hello, i see, i remove a part of code for tests and forget
i fix it now :
my last problem is b5 to have a white background (like other)
automation:
- platform: state
to: "on"
event: start
"p[9].b[9].font=10","p[9].b[9].bco=63488","p[9].b[9].txt=\"\"",
"p[9].b[12].font=10","p[9].b[12].bco=31","p[9].b[12].txt=\"\""]
payload_template: '" {{ state_attr("climate.office_ac", "temperature") }}°"'
platform: state
condition:
condition: template
- platform: mqtt
payload: "ON"
hvac_mode: "off"
- platform: mqtt
payload: "ON"
hvac_mode: "heat"
- platform: mqtt
payload: "ON"
hvac_mode: "cool"
- platform: mqtt
payload: "ON"
hvac_mode: "dry"
- platform: mqtt
payload: "ON"
- platform: mqtt
payload: "ON"
- platform: mqtt
payload: "ON"
data_template:
- platform: mqtt
payload: "ON"
data_template:
- alias: hasp_chambre1_p9_ColorConfig_selectedforegroundcolor
- platform: state
to: "on"
event: start
- platform: state
entity_id: input_number.hasp_chambre1_selectedforegroundcolor
["p[9].b[4].bco={{ states('input_number.hasp_chambre1_selectedforegroundcolor')|int }}",
"p[9].b[5].pco={{ states('input_number.hasp_chambre1_selectedforegroundcolor')|int }}",
"p[9].b[6].pco={{ states('input_number.hasp_chambre1_selectedforegroundcolor')|int }}"]
- platform: state
to: "on"
event: start
- platform: state
- platform: state
to: "on"
event: start
- platform: state
- platform: state
to: "on"
event: start
- platform: state
Can you tell me what display you are using? Thank you
if the question is for me, a nextion 3.5" if you want .tft file send me a PM
Voila, i find solution for background, now i need only translate state of weather for this plate
thanks for your project is amazing
Please TFT file, I will be grateful thank you Michal
here you have
for 3.5"
Hello, for my cover i can’t make working
- platform: mqtt
topic: "hasp/chambre1/state/p[4].b[8].val"
data_template:
position: "{{ (trigger.payload|int) }}"
- platform: state
to: "on"
event: start
- platform: state
data_template:
topic: "hasp/chambre1/command/p[4].b[8].val"
payload_template: "{{states.cover.fibaro_volet_principale_level.attributes.current_position|default(0)|int * 2.55 | round(0) }}"
Silder showing good position now (with |int * 2.55 | round(0)), but problem is moving slider on screen only on first 1/3 of slider works, (0 to 100 is ok, 101 to 255 not working)
i tried a lot of code but nothing work / 2.55 | round(0) or / 2.55
"{{ (trigger.payload|int) / 2.55 | round(0) }}"
Hi, I am new here so sorry If this question is already asked. I am looking for a solution that fits in a bticino living light frame. A 2.8 inch Nextion panel that can be nicely integrated in such a frame. A 3d model that can be printed would be great. Thank you.
I’m new here as well and can’t code yaml but i want to try to make a display for my alarm clock.
Is it possible to use this project for it?
Or is it nessesary to re-write Aurdino_sketch as well?
Like I said I can’t write yaml so I will try to do automation part in Node-red.
I have seen other projects as well they use ESPhome for it. i guess thats replace the mqtt part.
But thats more code to write i think.
I see al lot of automations in HA but where are they stored? Can i see/change them?
Sorry for the absolute beginners questions
The default project includes a set of automations that looks like this, so maybe you can make this work like you’d want?
You can get pretty advanced with this project without ever touching the Arduino code. You will however need to be able to get Home Assistant to send MQTT messages back and forth and to Do Things in response. This project uses Home Assistant automations in a set of YAML files to do that. One could do the same thing in Node-Red, but you’d be re-inventing a lot of wheels and it would require being able to understand the existing YAML files in order to figure out what they’re doing. So… either way, you’re going to need to be able to deal with YAML files at some point.
You can browse most of the automations used by the project here in this folder. This here is the clock bit.
The other day, I did a stupid thing. While working on another project, I accidentally uploaded that file to my HASP. Well, since I had to reflash it now, I upgraded to 0.40 and LCD 2 to see all the new changes. Looking really great. After getting all the problems created by the hass developers worked out, I started playing with the new features. The one in particular I wanted was the fan control. I was able to work out the basic changes to get it to control my fan, but there are still a couple glitches I need to work out.
First, when I press the OFF button, the fan turns off, but the last speed that was selected stays highlighted.
Second, when the unit starts up, it doesn’t set the controls to the current status of the fan (light and speed).
I am using a Sonoff iFan03 controller with the latest version of Tasmota. It looks like there are some differences between what is in the automation and what this version of the controller firmware does. It seems the controller is not updating HA as the state shows the speed as off, but it is running on medium. Any suggestions on where to look or what to do?
Trying to get my Honeywell Home RTH9585WF1004 thermostat to work with HASP. Partial success. I can display the temperature (climate.current_temperature) and target temperature (climate.temperature). I can’t get it to set the target temperature. I can set it with the thermostat card, so I know it can be done, but not sure how. I don’t see anything in my MQTT Explorer when I change the target temperature with the card so I don’t think it is talking through the MQTT server.
Does anyone have any suggestions of a good thermostat that would work with this, other than Nest? Don’t want one that has to have an outside network connection to work.
UPDATE: Got it working. Because this thermostat doesn’t support the min/max setting, I changed how the interface works. There is only one temperature setting field and it changes based on the hvac mode. I can also get the inside humidity and I display that in the lower field.
Ran into an issue with 0.40 when changing pages. When I issue the command to change pages, the icons on the page are not shown. Text shows up, but not the icons. The icons will eventually show when the field is updated.
EDIT: This occurs when going back to the status page.
