I would like HA to send a MQTT topic/payload out based on a timer trigger.
Any examples?
Thanks in advance.
Any examples?
Thanks in advance.
Like when a timer
entity finishes and generates a timer.finished
event (use an Event Trigger) or at a specific time (use a Time Trigger)?
Publish the payload using the mqtt.publish
service call.
alias: example_1
- platform: event
event_type: timer.finished
event_data:
entity_id: timer.your_timer
condition: []
- service: mqtt.publish
topic: your/topic
payload: 'Your payload'
alias: example_2
- platform: time
at: '08:30:00'
condition: []
topic: your/topic
Thank you!! Example 2 looks like the ticket.
I’ll test it tomorrow and respond back.
Thank you, Thank you, Thanks you! Worked perfectly!
You’re welcome!
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
For more information about the Solution tag, refer to guideline 21 in the FAQ.
