My Yellow just came in. Assuming I can make it work with the PINE CM4 module, I’ll see if that makes a difference though I expect it would be the same since it’s the same pins and such. It’s been frustrating but when I’m not having the dead device issue it is overall better than my old stick.
Good news, a long delay but I’ve my Home Assistant Yellow, the PoE version (hardware rev 1.3 if that makes any difference). I’d canceled my previous order for the full kit because of the CM4 shortages. Fortunately I’ve purchased a CM4 4GB Lite (has WiFi/Bluetooth but no EMC) and used an SSD for the OS install.
I didn’t have to do anything other than connect the GPIO module. No edit of the boot config file, nothing.
Best part is that both Z-Wave (added several devices already) and BlueTooth (added some BT devices too) are both working.
Nice!
Cool!
I’m glad it worked well for you. I think an update somewhere around Dec 2022 introduced a fix because mine starting working without any config change.
It’s good to know everyone can use this without any extra setup.
What is everyone running the Normal and Measured power levels at?
I have mine set with the defaults, and the range is impressive. The warnings definitely made me think twice about changing anything.
Is that 0 and 0?
Left that part out, sorry. Yes, exactly how you have it in your screenshot.
