Let me give you a few things to consider for getting this done if you have a non-trivial network setup.
Firstly this is the config file for emulated hue:
emulated_hue:
host_ip: 123.123.123.123
listen_port: 8300
advertise_ip: 123.123.123.123
advertise_port: 8300
upnp_bind_multicast: true
off_maps_to_on_domains:
- script
- scene
expose_by_default: true
exposed_domains:
- light
- switch
- group
123.123.123.123 is the IP of the HASSio VM running on KVM, using br0 as interface.
br0 is the untagged traffic interface on the network 123.123.123.0/24 (numbers changed for editorial reasons).
The pairing should work without problems if you have the harmony hub on the same network as your HASSio machine/VM.
If you have them in different networks, you enter a world of pain, be prepared.
First you need to route multicast traffic back and fourth between these networks, I recommend using smcroute. You will find some information on how to do that with your particular equipment.
Then you need to tell your firewall to increment the TTL of the SSDP packets, otherwise the router will discard them silently. Depending on your fireall you need to look out how to do packet mangling to increase the TTL at least by 1.
IPtables:
iptables -t mangle -A PREROUTING -d 239.255.255.250 -j TTL --ttl-inc 1
Finally, you may need to open your firewall to allow the SSDP packets to pass from the harmony hub to HASSio.
Allow UDP from Harmony Hub any port, to IP 239.255.255.250, port 1900
Allow UDP from HASSio any port to HarmonyHub any port (DO NOT allow only packets from port 1900 as you might think, HASSio responds from a random port!)
That should do the trick!
Adjusting color temperature does not work well with RGBW lights, they are using the color LEDs then of course, which are much darker. You need proper CCT lights to use the white temperature adjustment properly
Now my question:
-The handheld remote only allows on/off, brightness and white temperature control, but the mobile app also allows color adjustment. The color adjustment does not work for me at all. Any hints what could be wrong here?
However, now my questions:
