I might be doing wrong or missing a vital step as I don’t seem to be able to get into the boot loader of my 2nd gen SilverCrest GW. When I power on the device with my thumb already on the ESC key I only get the following:
Booting...
@ chip__no chip__id mfr___id dev___id cap___id size_sft dev_size chipSize
@ 0000000h 0c84018h 00000c8h 0000040h 0000018h 0000000h 0000018h 1000000h
@ blk_size blk__cnt sec_size sec__cnt pageSize page_cnt chip_clk chipName
@ 0010000h 0000100h 0001000h 0001000h 0000100h 0000010h 000004eh GD25Q128
DDR1:32MB
---RealTek(RTL8196E)at 2021.07.29-21:33+0800 v3.4T-pre2 [16bit](380MHz)
P0phymode=01, embedded phy
check_image_header return_addr:05010000 bank_offset:00000000
no sys signature at 00010000!
---Ethernet init Okay!
tuya:start receive production test frame ...
Jump to image start=0x80c00000...
decompressing kernel:
Uncompressing Linux... done, booting the kernel.
done decompressing kernel.
start address: 0x80003780
Linux version 3.10.90 (zhangpc@embed) (gcc version 4.6.4 (Realtek RSDK-4.6.4 Build 2080) ) #1 Thu Jul 29 21:36:28 CST 2021
CPU revision is: 0000cd01
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
Zone ranges:
Normal [mem 0x00000000-0x01ffffff]
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x00000000-0x01ffffff]
icache: 16kB/16B, dcache: 8kB/16B, scache: 0kB/0B
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line: console=ttyS0,38400 root=/dev/mtdblock2
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 27344k/32768k available (2763k kernel code, 5424k reserved, 562k data, 192k init, 0k highmem)
SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:128
console [ttyS0] enabled
Calibrating delay loop... 378.47 BogoMIPS (lpj=1892352)
pid_max: default: 4096 minimum: 301
Mount-cache hash table entries: 512
reg e0=0
reg e1=0
reg e2=0
reg e3=0
reg e4=0
reg e5=0
reg e6=0
reg e7=0
reg f0=0
reg f1=0
reg f2=0
reg f3=0
reg f4=0
reg f5=0
reg f6=0
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
NET: Registered protocol family 2
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 53
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x18002000 (irq = 9) is a 16550A
serial8250: ttyS1 at MMIO 0x18002100 (irq = 13) is a 16550A
Realtek GPIO Driver for Flash Reload Default
tuya_gpio_init ok, scan expire time:50
SPI INIT
------------------------- Force into Single IO Mode ------------------------
|No chipID Sft chipSize blkSize secSize pageSize sdCk opCk chipName |
| 0 c84018h 0h 1000000h 10000h 10000h 100h 84 0 GD25Q128|
SPI flash(GD25Q128) was found at CS0, size 0x1000000
boot+cfg offset=0x0 size=0x20000 erasesize=0x10000
linux offset=0x20000 size=0x1e0000 erasesize=0x10000
rootfs offset=0x200000 size=0x200000 erasesize=0x10000
tuya-label offset=0x400000 size=0x20000 erasesize=0x10000
jffs2-fs offset=0x420000 size=0xbe0000 erasesize=0x10000
5 rtkxxpart partitions found on MTD device flash_bank_1
Creating 5 MTD partitions on "flash_bank_1":
0x000000000000-0x000000020000 : "boot+cfg"
0x000000020000-0x000000200000 : "linux"
0x000000200000-0x000000400000 : "rootfs"
0x000000400000-0x000000420000 : "tuya-label"
0x000000420000-0x000001000000 : "jffs2-fs"
PPP generic driver version 2.4.2
nf_conntrack version 0.5.0 (427 buckets, 1708 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
l2tp_core: L2TP core driver, V2.0
8021q: 802.1Q VLAN Support v1.8
Realtek FastPath:v1.03
Probing RTL819X NIC-kenel stack size order[1]...
eth0 added. vid=9 Member port 0x10f...
eth1 added. vid=8 Member port 0x10...
[peth0] added, mapping to [eth1]...
VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Freeing unused kernel memory: 192K (80340000 - 80370000)
init started: BusyBox v1.13.4 (2021-07-29 21:31:51 CST)
Set power startcmd read
b8000038: 2794A104 0000000F 00000042 00000018 '▒▒ B
cmd write
Write memory 0xb8000038 dat 0x1794a104: 0x1794a104
Set power end
udhcpc (v1.13.4) started
Sending discover...
Please press Enter to activate this console. Tuya Gateway Application Normal Srart /tuya/tuya_start.sh UserAppRunDir:
set defult run_dir:/tuya
TY_ENV_APP_RUN_DIR=/tuya
get user cfg file error, load defult cfg file
load platform configure file:/tuya/def.cfg
start.conf is exist
Normal mode.
current run dir:/tuya/tuya_user1
tuya_start_children.sh:UserAppRunDir:/tuya JsonFile Path:/tuya/def.cfg [engineer_mode: ]
grep: /var/resolv.conf: No such file or directory
Sending discover...
killall: app_detect.sh: no process killed
killall: tyZ3Gw: no process killed
killall: log_detect.sh: no process killed
killall: process_monitor.sh: no process killed
Sending discover...
cat: can't open '/tuya/eng_mode': No such file or directory
no eng file
Sending discover...
nameserver 114.114.114.114
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
killall: udhcpc: no process killed
route: SIOCADDRT: File exists
nlRecvFromAppSock sg_netlinkKeyPid:417
nlRecvFromAppSock port link sg_netlinkPid:417
Jan 1 00:02:08 mDNSResponder: mDNSResponder (Engineering Build) (Jul 27 2021 20:15:30) starting
Jan 1 00:02:08 mDNSResponder: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0)
Jan 1 00:02:08 mDNSResponder: WARNING: mdnsd continuing as root because user "nobody" does not exist
1970-01-01'T'00:02:09'Z' Default [com.apple.mfi.HomeKit.Core:AccessoryServer] Version information:
- ADK Version: 5.1 (dfeceb3a) - compatibility version 8
- Extensions:
- HAP over Thread
- Dynamic memory allocation
- Platform: Tuya IoTOS
- Compiler:
- Version: 2.2.8 (2021_07_29 20_22_42)
- Available features:
- Key-Value store
- Accessory setup manager
- TCP stream manager
- Service discovery
- Software Token provider
- Wi-Fi Reconfiguration Control
1970-01-01'T'00:02:10'Z' Default [com.apple.mfi.HomeKit.Core:AccessoryValidation] [0000000000000001 Gateway] An accessory should advertise one of its services as its primary service.
1970-01-01'T'00:02:10'Z' Error [com.apple.mfi.HomeKit.Platform:TCPStreamManager] Could not configure TCP User Timeout socket option.
Any pointers to what I might need to additionally do or doing wrong?
Do I need to first install and activate it or can it be hacked straight from the box?
I have not plugged in a ethernet cable and only connected my CH340 USB Serial (at 3.3V) to J1 (RX, TX and GND) and using putty and connect using 38400bps/1/N, parity off, flow control none as suggested in the original write up.
