thanks a lot. I’ll try it
Could you please explain how to configure an automation with motion detection?
I’m not familiar with Mqtt.
Thanks.
Hello, so I have the camera setup (Thank you!) However I appear to be struggling with the home assistant controls.
The image is working however the motor and lights are not.
When watching my MQTT monitor, I can see the camera posting to the server, and if I use the home assistant tool I can post to the server and also see it, however my switches do not work.
Here are my switches:
- platform: mqtt
name: "DaFang Living Room RTSP"
state_topic: "Downstairs/HomeCamera1/status"
value_template: "{% if value_json[\"RTSP-Server\"] == 'running' %}h264_noseg_start{% else %}rtsp_stop{% endif %}"
command_topic: "Downstairs/HomeCamera1/set"
payload_on: "h264_noseg_start"
payload_off: "rtsp_stop"
optimistic: false
- platform: mqtt
name: "Dafang Living Room Up Down"
payload_off: "motor_up"
payload_on: "motor_down"
optimistic: false
- platform: mqtt
name: "Dafang Living Room Left Right"
payload_off: "motor_left"
payload_on: "motor_right"
optimistic: false
light:
- platform: mqtt
name: "Dafang Living Room Blue LED"
value_template: "{% if value_json.LEDs.Blue == 'on' %}blue_led_on{% else %}blue_led_off{% endif %}"
payload_on: "blue_led_on"
payload_off: "blue_led_off"
optimistic: false
- platform: mqtt
name: "Dafang Living Room Yellow LED"
value_template: "{% if value_json.LEDs.Yellow == 'on' %}yellow_led_on{% else %}yellow_led_off{% endif %}"
payload_on: "yellow_led_on"
payload_off: "yellow_led_off"
optimistic: false
Does anyone have any idea why the buttons don’t appear to move the camera?
In automations.yaml define something like this:
- action:
- data:
message: detected
title: motion
service: notify.me
alias: motion detector
condition: []
- payload: 'ON'
platform: mqtt
topic: myhome/dafang3/motion
To control leds and rtsp please use the new mqtt autodiscovery feature. You may need my open PR to publish the configuration though.
Concerning the motor controls, it should still work from what i see. you may need to debug into it.
Can I see your PR? I am using mosquitto currently, are you suggesting to not use this anymore? The auto discovery appears to bind to 0.0.0.0, which I rather it find to the internal IP of the server.
My PR was already merged, so I guess everything should work out of the box now. Of course you can use mosquitto as broker (i do too), just make sure your host, port etc is set accordingly in mqtt.conf.
The broker appears to work fine and I can see the cameras connecting to the broke and disconnecting in the mosquito log, for some reason the topics are not co-operating.
I have the topic in homeassistant as: command_topic: "Downstairs/HomeCamera2/set
I have the topic on the camera as:
# Define a location
LOCATION="Downstairs"
# Define device name
DEVICE_NAME="HomeCamera2"
# Define the base topic used by the camera
# send a message to myhome/dafang/set with the payload help for help.
# Results will be placed in myhome/dafang/${command} or topic/dafang/error - so please subscribe topic/dafang/# for testing purposes
TOPIC="$LOCATION/$DEVICE_NAME"
Please have a look on my new tutorial for home assistant integration:
I will look into the motor control issue
I now understand your problem. For general commands like motor_up mqtt_control will call:
/system/sdcard/bin/curl -m 2 "${CURLOPTS}" -s http://127.0.0.1/cgi-bin/action.cgi?cmd="${COMMAND}" -o /dev/null 2>/dev/null
Calling on cgis sometimes seems to need credentials now, as a workaround in mqtt.conf set the following curl options
CURLOPTS="–user root:ismart12"
and restart mqtt-control
that should help.
Thanks everyone getting me this far for trying to connect Dafang with HA, especially @jmtatsch and his manual. I got rtsp working, but now i am stuck with establishing an mqtt connection from dafang. HA is telling me following
Invalid connection from (client @=dafang:53256) : [MQTT-3.1.2-1] Incorrect protocol name: "MQIsdp"
any ideas?
getting this under services when I try to add MQTT services
Running script ‘mqtt-control’…
MQTT autodiscovery is enabled - now publishing initial configurations
Warning: Unable to locate configuration directory, default config not loaded.
Error: The connection was lost.
Starting MQTT - Control
then I get no additional cameras (part from rtsp-h264) states
me too
[MQTT-3.1.2-1] Incorrect protocol name: “MQIsdp”
however my MQTT tasmota light switches work fine so I know the inbuilt home assistant MQTT servers is working
Solved by installing separate MQTT server instance and connected HASS to it:
apt install mosquitto
Conf changed to:
mqtt:
broker: 127.0.0.1
discovery: true
discovery_prefix: homeassistant
so to check you are saying that I will need to run my own MQTT server and not the home assistant inbuilt one. Pants because I just swapped from Mosquito to the inbuilt one.
That’s what I did to get Discovery working. You need to reset both mqtt services on dafang after each HASS reset.
Confirmed switching back to Mosquito MQTT worked
Although this is a good work around not sure that it is the prefect answer.
Thanks for the reply, I feel we are a step forward. Neither the LEDS or motors are working though, see below for some debugging on the motor.
If I look at the camera’s log when using home assistant and it’s own GUI I see this:
Using HomeAssistant (Does not work)
127.0.0.1 - - [16/Apr/2018:20:31:16 +0000] "GET /cgi-bin/action.cgi?cmd=motor_down&val=100 HTTP/1.1" 401 0 "-" "curl/7.59.0-DEV"
auth_check_userpass(Root,ismart12,...);
Using GUI (works)
192.168.0.100 - - [16/Apr/2018:20:31:47 +0000] "GET /cgi-bin/action.cgi?cmd=motor_down&val=100 HTTP/1.1" 200 169 "http://192.168.0.112/cgi-bin/status.cgi" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/65.0.3325.181 Safari/537.36"
The only meaningful difference I notice is the source IP is localhost on the request from HA which doesn’t make much sense to me.
Regarding lights.
I see no log when using homeassistant but below is the working log from the cameras GUI
192.168.0.100 - - [16/Apr/2018:20:36:36 +0000] "GET /cgi-bin/action.cgi?cmd=blue_led_on HTTP/1.1" 200 108 "http://192.168.0.112/cgi-bin/status.cgi" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/65.0.3325.181 Safari/537.36"
Here is my mqtt config (HA and camera) and my switches:
CameraConfig (MQTT)
export LD_LIBRARY_PATH='/thirdlib:/system/lib:/system/sdcard/lib'
# Options for mosquitto_sub & mosquitto_pub
USER=
PASS=
HOST=192.168.0.106
PORT=1883
# Define a location
# Define an autodiscovery prefix, if autodiscovery is desired:
AUTODISCOVERY_PREFIX="homeassistant"
MOSQUITTOOPTS=""
# add Options for Mosquitto here. For example --cafile /system/sdcard/config/DST_Root_CA_X3.pem --tls-version tlsv1
# or using a special id to connect to brokers like azure
MOSQUITTOPUBOPTS=""
# add options for mosquitto_pub like -r for retaining messages
CURLOPTS=""
# add options for curl here e.g --user user:password
FIFO=/var/run/mqtt-sub
# the FIFO used. Change it if you like to
STATUSINTERVAL=30
# Send a mqtt statusupdate every 30 seconds
STATUSFORMAT=json
# Configure format of status. Standard is text, uncomment this line for json
Home Assistant MQTT Broker
mqtt:
broker: 192.168.0.106
port: 1883
discovery: true
HA Switches
- platform: mqtt
name: "Kitchen Blue LED"
state_topic: "Downstairs/HomeCamera2/status"
optimistic: false
- platform: mqtt
name: "Kitchen Yellow LED"
optimistic: false
- platform: mqtt
name: "Kitchen Up Down"
command_topic: "Downstairs/HomeCamera2/set"
payload_off: "motor_up&val=100"
payload_on: "motor_down&val=100"
optimistic: false
- platform: mqtt
name: "Kitchen Left Right"
optimistic: false
Worth noting I had to use mosquito as I saw this error when leaving out the broker ip
It says 401, that means access was unauthorized. HA is not able to send commands because the camera is pass-protected. I had the same error as well.
You need to edit following to mqtt.conf in Dafang…
# Add options for curl here e.g --user user:password
CURLOPTS="--user root:ismart12"
This will work
@runtman I see you already had
# CURLOPTS="–user root:ismart12"
“-user” needs to be with 2 dashes (–user) though. Further down you have it again
CURLOPTS=""
Better replace with the first line or comment it out.
