I’ve revised your sensor.py to include the 5-min LMP average, and 2-hr load forecast. You also need the code to report as an application instead of a browser or you’ll be IP banned by PJM.
The 2 hr load forecast can be used predict the peak. It’s updated every 5 min and extends out 2 hrs. You can then run an automation that triggers if the peak is predicted to occur within the next hour.
You should be able to pass any utility zone, so it’s now applicable to any utility within PJM.
Here’s the config.yaml:
- platform: pjm
monitored_variables:
- type: instantaneous_total_load
- type: total_load_forecast
- type: total_short_forecast
- type: instantaneous_zone_load
zone: "COMED"
- type: zone_load_forecast
zone: "COMED"
- type: zone_short_forecast
zone: "COMED"
# - type: zonal_lmp
# zone: "COMED"
# Compare to short forecast timestamp attribute (PJM and Zone) to determine if peak occurs within next hour
sensors:
current_time_plus_one_hour:
value_template: >
{{ (as_timestamp(now()) + 3600) | int }}
friendly_name: "Next Hour"
Sensor.py
Was also having trouble with getting the sql to work - kept getting invalid errors using the SQL integration in the web UI. These ended up working for me (just tweak to point to the ComEd or PJM load sensor to create the hourly peak, and point to the new hourly peak SQL sensor to develop a 5th coincident peak):
Hourly Peak
FROM (
SELECT CAST(state AS INTEGER) AS state,
ROW_NUMBER() OVER (ORDER BY state DESC) as rownum
FROM states
WHERE metadata_id = (
SELECT metadata_id
FROM states_meta
WHERE entity_id = 'sensor.comed_zone_load'
AND state != 'unknown'
AND state != ''
AND strftime('%Y-%m-%d %H', last_updated_ts, 'unixepoch') = strftime('%Y-%m-%d %H', 'now')
) AS ranked
WHERE rownum = 1;
and 5th Coincident Peak
WITH daily_peaks AS (
SELECT
date(last_updated_ts, 'unixepoch') AS date,
state,
MAX(CAST(state AS INTEGER)) AS peak_value
FROM states
SELECT metadata_id FROM states_meta WHERE entity_id = 'sensor.pjm_total_load_current_hour_high'
AND state NOT IN ('unknown', '', 'unavailable')
AND state GLOB '[0-9]*' -- Ensures the state contains only digits
AND last_updated_ts >= strftime('%s', 'now', '-4 months')
GROUP BY date
ranked_peaks AS (
SELECT state, peak_value, date,
ROW_NUMBER() OVER (ORDER BY peak_value DESC) AS rank
FROM daily_peaks
SELECT peak_value
FROM ranked_peaks
WHERE rank = 5
