HACS: restart later
nope, repairs is not an integration, repairs are helpers within the Home Assistant Core, which integrations can make use of - for details, see the repairs dev-docs.
As i mentioned above, the integrations, which make uses of this repairs framework are responsible to configure their repair issues as neccessary.
Instead of trying to get rid of the repairs that you get after updating, why not skip the updates and with that avoid the repairs all together?
I am pretty sure you can still see them in the HACS page in something like a Pending updates section. That way you can apply them at a time it suits you and then reboot after applying all pending updates.
Yes, technically it is an integration (better said a component) as almost everything is in HA, but it is an internal one, those part of the HA core features (like the sensor or switch component).
It still counts (this is the last time I’ll repat it) the integrations, which make uses of this repairs framework are responsible to configure their repair issues as neccessary.
I believe the user, and not the developer of the integration, should have the last word about what can and cannot be ignored. If the user gets a warning and they explicitly ignore it, it’s their own risk.
In the case of HACS, I completely understand that the developer thinks this warning cannot be ignored, since the update cannot be applied without a restart, there is no way around it. However, I don’t care that it is only applied later.
I’m not sure, but isn’t the functionality to skip an addon update part of HA as well? That’s not part of what the addon does, is it? Or can an update to an addon or core version be marked as unskippable? (note this would not mean you are forced to do the update, just that you keep being warned about it)
I think it would be good to keep that end responsibility with the user.
Since nobody raised this request or question to the HACS project, yet, we don’t know if this is on purpose by the HACS maintainers, or just has been implemented as is and no one ever complained about it.
Even the update entity component, allows the integrations to disable skipping an update.
The GitHub issues policy on HACS forbids feature requests so I posted on Discord:
If you are not on Discord:
Support “Ignore” for “Restart” in Repairs
Would it be possible to ignore the “Restart required” step after updating an integration?
I often install integrations when they are available but I don’t need / want to restart HA immediately.
The number badge on “Settings” is annoying and I’d rather ignore / dismiss the “Restart required” action.
It’s not preventing HA or the integration to work while they are loaded so no immediate action in required.
Other reasons discussed there (for the “dismiss notification” part, not the “restart later” ability):
HACS: restart later
And the answer of Ludeeus:
Thank you!
If I would restart HA every time it wants to, I had to restart twice a day!
