Its tested now and works for me.
After making my own custom media_player widget to include album art I discovered that my iPad 1 (IOS v5) did not update.
So, to test out these patches I built my own docker image including the patches, and it worked at once, media player updated including my album art as background image. Nice work
git clone https://github.com/home-assistant/appdaemon.git
cd appdaemon
git checkout master
git pull https://github.com/zarya/appdaemon.git socket_io
cd ..
docker image build appdaemon --tag frafall/appdaemon
hello,
can someone explain how to install zarya/appdaemon files on a Raspberry PI? (I have HADashboard fully installed and working)
if you have HADashboard installed, you also have appdaemon installed, unless you have the old version from dashboard.
sure I have, but I want to get it work with old ios i.e. ipad 1 using the zarya patch for appdaemon
i guess you need to uninstall your appdaemon and install the fork from zarya.
I originally installed appdaemon using pip3 (sudo pip3 install appdaemon), not using docker.
I tried to copy manually the content of zarya/appdaemon directory to my original intallation of appdaemon of my raspberry pi in /usr/local/lib/python3.5/dist-packages/appdaemon, but did not wok, I have this error:
File "/usr/local/bin/appdaemon", line 7, in <module>
from appdaemon.admain import main
File "/usr/local/lib/python3.5/dist-packages/appdaemon/admain.py", line 21, in <module>
import appdaemon.appdaemon as ad
File "/usr/local/lib/python3.5/dist-packages/appdaemon/appdaemon.py", line 21, in <module>
import appdaemon.rundash as appdash
File "/usr/local/lib/python3.5/dist-packages/appdaemon/rundash.py", line 13, in <module>
import socketio
ImportError: No module named 'socketio'
any help?
like i said, you need to uninstall and use the setup from the git from zarya.
Unfortunately, I donāt know how to uninstall, and reinstall zarya version of appdaemonā¦ I donāt know how to install manually, I just typed āpip3 install appdaemonā for thr original installation, so I donāt know how to install a different version unless someone explain a diffetent way.
i dont remember exactly. (has been a while)
you need to download the git, and then go to that dir and run the install.
but i am sure that @aimc knows exactly what to do and how to go on the best way with another fork.
Iām looking into adding this into AppDaemon 3.0 so it might be easiest to wait a little while.
Any idea when the appdaemon will be available?
Still mulling it over, but it is on my list yes.
Hello, everybody.
I WAS having same problem with iOS 5.1.1, but managed to implement (if you can call this implementation) SockJS on AppDaemon version 3 and my iPad came back to use
Here is a link to my repo: https://github.com/algirdasc/appdaemon
Iām running AppDaemon in Docker, so you can build Docker image with create_docker_image.sh script.
Is it possible to use this with hass.io? Or do I need to alter the docker? Iām also using an ipad1 and want to use websocket. Thanks
I cant tell for sure. Iām just using AppDaemon as separate docker container and it works fine with my ipad and HA.
Iām no expert in HASSIO docker but in the docker github page itās possible to add python packages
. described here:
and the sockjs algirdasc uses is in the list
do i need to add something else to use this sockjs?
