Sorry there is no way to manually trigger a discovery. It might be possible to do this with integration options but I don’t think that is the intent of these settings in Home Assistant.
Discovery does run automatically every 5 minutes and should eventually detect initially undetected fans. Are you having a specific or frequent problem with missing fans?
I noticed it after a restart. I have given it 15-30 minutes to update and nothing happens. It will be available in the app. So I restart HA and it’s available again.
2020-07-21 18:29:14 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for senseme which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-07-21 18:29:14 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-07-21 18:29:24 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform senseme.light: Platform not found (No module named 'aiosenseme').
2020-07-21 18:29:24 ERROR (MainThread) [homeassistant.helpers.integration_platform] Unexpected error importing senseme/logbook.py
File "/usr/src/homeassistant/homeassistant/helpers/integration_platform.py", line 30, in _process
platform = integration.get_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 322, in get_platform
f"{self.pkg_path}.{platform_name}"
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 965, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'custom_components.old.logbook'
2020-07-21 18:29:24 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform senseme.fan: Platform not found (No module named 'aiosenseme').
Wow I have no idea what is going wrong. The Platform not found (No module named 'aiosenseme') error indicates the Home Assistant is not able to install the aiosenseme library using pip. This is all handled by Home Assistant so I’m not sure why it’s not working. HA must have internet access to download these libraries. Do you have an unusual HA instance? Docker? VM?
The last error indicates it can’t import senseme/logbook.py. That would be correct because there is no senseme/logbook.py in either the senseme integration or aiosenseme library.
I would switch to a fresh install of Home Assistant on a Raspberry Pi without HACS and try the manual installation of the senseme integration as shown on Github.
Hmm… I’ve a pretty standard installation. Entire system is running on HassIO (or Home Assistant Operating System as it’s now called?
When is ‘aiosenseme’ installed? Is it upon adding the integration? If so, it would make sense that it’s not installed as I’ve not been able to add the integration.
By manual installation, do you mean copying and adding the folder into the custom_components folder? If so, I’ve tried that to the same result. The integration does not appear when I try to add it.
I guess I will try a fresh installation if there are no other suggestions, though I naturally dread the idea of moving everything over…
So I think Home Assistant now means everything running a Raspberry Pi. This used to be called HASSIO.
Home Assistant automatically installs the aiosenseme library but I can’t remember if it’s when the integration is detected or added by the GUI. Either way this is a function of Home Assistant and not the integration. Your error messages look like it can’t figure out where get aiosenseme. Does your Home Assistant have access to the internet?
Manual installation is as you described.
You could test a fresh install on a separate Raspberry Pi. Running multiple Home Assistant instances is possible on one network.
I will be back home Friday and can do some additional testing if you haven’t figured it out by then.
I was digging around the logs and realised where the log entries I had were originating from. I had ‘senseme’ defined in the configuration.yaml to test.
I also looked at some documentation on components and your code (i’m no means a competent programmer!). It seems like that aiosenseme library is added after the integration is added in the GUI.
I’ve edited the configuration file and all the above logs i pasted above have disappeared. I guess that kind of makes sense since the integration is never added.
As i was typing the above, i had a ‘doh’ moment. It’s solved. I had your (really) old component (0.1.5) in the custom_component folder. I had renamed the folder… BUT i just realised that I needed to remove the folder as both use the same “senseme” domain!
Leaving this here so others do not make the same mistake!
Is there a recommended Lovelace card to use with this? I’ve had a pretty good search, but all the fan cards I found seem to be “low, medium, high” rather than the seven speeds of the Haiku.
This is good enough for me because 99% of the time I rely upon the fan to adjust speed on its own. I can control it through this button, but usually it’s just a visual confirmation of what it’s doing.
Hi Mike - wondering if you have any tips for this scenario. I added the custom_components folder and in integrations I can see the SenseME integration. This works well (thanks!), unfortunately, when I click submit, I get an Aborted message “No SenseME devices found on the network.” The fan connected well via the app and google integration works well, any ideas would be very much appreciated (I am pretty new to Home Assistant so it could be something pretty basic).
Discovery is a bit inconsistent on the Sensme Fans so try multiple times even waiting a bit. Make sure you don’t have one of the new fans like the i6 since they are not supported by this component. Finally unusual networks do not work well with broadcast discovery mechanisms. The fan and Home Assistant must be on the same network. (no VLANs…)
