Hansgrohe Pontos = Syr Safe Tech
Below is the response with get all (XX to replace sensitive info). I already have it working on my system, including adding it to the energy cost tracking and and automation which shuts the valve when leak detectors trip. So I don’t need anything more. But if I give you the info, and test the results, perhaps it will help some others later.
The sensor stopped working for a completely unrelated reason. Somehow a firewall rule got turned off which blocked communication. Once I corrected that, all was well again. For the functions I need right now, admin mode is not actually necessary, but there are a couple things that it would be nice to have it for.
{“getHWV”:“0000000001”,“getVER”:“syr001-A-B-000-112”,“getSRN”:“XXXXXXXX”,“getFCM”:0,“getFCD”:XXXXXXXX,“getFFM”:0,“getMAC1”:“XXXXXXXX”,“getMAC2”:“XXXXXXXX”,“getWFC”:“XXXXXXXX”,“getWFS”:2,“getWFR”:100,“getWFL”:[{“SSID”:“XXXXXXXX”,“Signal”:-53},{“SSID”:“XXXXXXXX”,“Signal”:-70},{“SSID”:“XXXXXXXX”,“Signal”:-76},{“SSID”:“XXXXXXXX”,“Signal”:-77},{“SSID”:“XXXXXXXX”,“Signal”:-77},{“SSID”:“XXXXXXXX”,“Signal”:-77},{“SSID”:“XXXXXXXX”,“Signal”:-89},{“SSID”:“XXXXXXXX”,“Signal”:-89},{“SSID”:“XXXXXXXX”,“Signal”:-89},{“SSID”:“XXXXXXXX”,“Signal”:-89},{“SSID”:“XXXXXXXX”,“Signal”:-93},{“SSID”:“XXXXXXXX”,“Signal”:-94}],“getWIP”:“10.XX.XX.105”,“getWGW”:“10.XX.XX.1”,“getEIP”:“0.0.0.0”,“getEGW”:“0.0.0.0”,“getWNS”:false,“getWAH”:false,“getWAD”:true,“getAPT”:300,“getWTI”:1800,“getCEN”:true,“getCCK”:“XXXXXXXX*****************”,“getCURL”:“XXXXXXXX.XXXXXXXX.net”,“getRURL”:" “,“getTURL”:”“,“getPRF”:1,“getPRN”:2,“getPV”:300,“getPT”:60,“getPF”:3500,“getPM”:true,“getPB”:true,“getPW”:false,“getPA1”:true,“getPN1”:“Anwesend”,“getPV1”:300,“getPT1”:60,“getPF1”:3500,“getPM1”:true,“getPR1”:1,“getPB1”:true,“getPW1”:false,“getPA2”:true,“getPN2”:“Abwesend”,“getPV2”:20,“getPT2”:30,“getPF2”:3000,“getPM2”:true,“getPR2”:1,“getPB2”:true,“getPW2”:false,“getPA3”:false,“getPN3”:“new profile”,“getPV3”:0,“getPT3”:0,“getPF3”:0,“getPM3”:false,“getPR3”:0,“getPB3”:false,“getPW3”:false,“getPA4”:false,“getPN4”:“new profile”,“getPV4”:0,“getPT4”:0,“getPF4”:0,“getPM4”:false,“getPR4”:0,“getPB4”:false,“getPW4”:false,“getPA5”:false,“getPN5”:”“,“getPV5”:0,“getPT5”:0,“getPF5”:0,“getPM5”:false,“getPR5”:0,“getPB5”:false,“getPW5”:false,“getPA6”:false,“getPN6”:”“,“getPV6”:0,“getPT6”:0,“getPF6”:0,“getPM6”:false,“getPR6”:0,“getPB6”:false,“getPW6”:false,“getPA7”:false,“getPN7”:”“,“getPV7”:0,“getPT7”:0,“getPF7”:0,“getPM7”:false,“getPR7”:0,“getPB7”:false,“getPW7”:false,“getPA8”:false,“getPN8”:”“,“getPV8”:0,“getPT8”:0,“getPF8”:0,“getPM8”:false,“getPR8”:0,“getPB8”:false,“getPW8”:false,“getRTC”:1714321042,“getBAT”:643,“getNET”:517,“getLDT”:0,“getTMP”:0,“getLWT”:90,“getDMA”:2,“getDRP”:2,“getDTT”:“04:00”,“getDTR”:”[0,0,0,0,0,0,0,0]“,“getDSV”:0,“getDBD”:10,“getDBT”:15,“getDST”:180,“getDCM”:3,“getDOM”:60,“getDPL”:10,“getDTC”:3,“getSLP”:0,“getSLO”:10,“getSOF”:20,“getSMF”:2500,“getSLE”:0,“getSLV”:0,“getSLT”:0,“getSLF”:4200,“getBUZ”:true,“getALD”:600,“getALA”:“ff”,“getWRN”:“ff”,“getNOT”:“ff”,“getALM”:”",“getMM”:2,“getSMC”:0,“getAB”:false,“getLOCK”:false,“getVTO”:false,“getVLV”:20,“getTSD”:false,“getCEL”:null,“getPSD”:false,“getBAR”:null,“getBAR2”:null,“getCND”:null,“getCNL”:0,“getCNF”:10,“getFLO”:235,“getNPS”:0,“getLTV”:3,“getVOL”:728,“getAVO”:2002,“getBSA”:true,“getFSL”:,“getALH”:null,“getPAH”:null,“getSTH”:null}
Hi Tim,
Many thanks for the info. I have the SYR Trio and I am wondering what other differences you experienced? Maybe you can post your config (without the sensitive parts of course)?
E.g. I am wondering whether the Trio has the sensor for water hardness/conductivity - it is also not included in your getall-response. Have you managed to get these values?
Many thanks in advance.
Thomas
Hi. Sorry for the slow reply. I don’t think it has conductivity. I can enable temperature and pressure, but when I try to enable conductivity, I get no reply.
Hi Tim, thanks! But how can you enable pressure and temperature? Your getall-response does not show the values?
Btw, my Trio offers a new FW update now, but I didn’t dare to install it so far…
/trio/get/tsd, /trio/set/tsd/true
/trio/get/psd, /trio/set/psd/true
enables the temperature and pressure sensor. csd would be conductivity, but doesn’t do anything on mine. After enabling it, it is available in the get/all response.
Thanks Tim,
thats interesting - I get “OK” for all 3 set-commands, but anyway no values are sent via get/all. Maybe the Trio has different Hardware, without these sensors…
EDIT: Now I get error messages from SYR Cloud/App:
“Störung Leitwertsensor” (=conductivity), and the same for temp. and pressure.
Regarding temp. and pressure I was able to avoid the errors with setting set/tsd/false and set/psd/false again, but set/csd/false does not work (although setting it true was acknowledged with "OK). Any idea how to get rid of it again?
Hi. No ideas from my side on that one, sorry.
Hi sangvikh,
thanks a lot for your integration into HACS. It is really helpful and works very well!
The only thing is, that when changing the Activation Profile, the new profile will be displayed in the selection list of HA but will not be used by the Pontos Base with FW 1.29. Closing and opening the valve works very well.
Any idea?
Thanks!
Hans
Hi!
Not sure why it doesn’t work with v1.29 firmware. I am using v1.30, and the profile selection works here.
Can you change profile via this url? This is what the integration is doing.
http://IP:5333/pontos-base/set/prf/1
Maybe the way admin mode is set differs. What does this url return?
http://IP:5333/pontos-base/set/ADM/(2)f
Can you read the profile name?
http://IP:5333/pontos-base/get/pn/1
Or
http://IP:5333/pontos-base/get/pn1
On my firmware, the last slash is ignored, so the two urls return the same data
Anyway, there is some info (in german) on firmware updates here: HansGrohe PontosBase - #171 von kris - Haustechnik - IP-Symcon Community
Firmare can be found here: Index of /firmware/pontosbase/
Just updated to V1.31 myself. It was painless.
  • Download firmware file
  • Rename to pontosbase.bin
  • Plug a computer into the micro usb on the pontos base (next to the battery)
  • Transfer firmware file
  • Remove battery and power supply to reboot
  • When rebooting, it blinks red a few times, then it starts up with the new firmware
UPDATE: I had the same behaviour on my sensor this week. The icon on the device displayed “no connection”, but the integration worked fine, i could change profile from the dropdown, and the “active profile” sensor changed. I guess it lost contact with the cloud. The problem went away after a while.
Hi! v2.2.0 should now support SYR devices :grin:
There’s probably some errors in there. I really should set up a python server to answer with your json response for testing :nerd_face: I made the release just to get it out there
EDIT: It did not work. But i have tested v2.2.2 against a local server.
