Harmon/Kardon AVR
@touliloup do you have the code somewhere on github? Is it okay if I take your code and put it there? (with credits ofcourse)
I think I only have it on a private repo. But if you don’t mind it would actually be great if you can push it in the official repo. So that it become available to anyone. Don’t worry for the credit, I don’t believe in code ownership so much, and I don’t have much time for it at the moment :slight_smile:
@touliloup any news on this? When you upload the code, we can make a pull request and merge it into main code.
Code is here: https://pastebin.com/ZLMHYcbw
I have converted it to a small pypi library:
Also, I’ve made a v0.1 for the platform in Hass:
Awesome, thanks for the integration :grinning:
The pull request is merged and scheduled for 0.85.0
I see it’s now available, I’ll test that today :muscle:
Edit: working fine :slight_smile:
For me it works fine
Thank you
since the the update to 0.90.2 my harman kardon media player is not working anymore
anyone else the same issue?
After upgrading to 2021.1.5 HK AVR 170 stopped working.
Logger: HkAVR
Source: /usr/local/share/homeassistant/lib/python3.7/site-packages/hkavr/hkavr.py:76
First occurred: 14:16:00 (1 occurrences)
Last logged: 14:16:00
Connection error: [Errno 61] Connection refused
Ping on HK ip is, HK port 10025 is open
i’m trying to add the avr, but i’m nog getting an working entity.
using this link:
i have an avr 171s and using hass on a raspberry pi4 ssd
does anyone got this working?
Hi guys.
I just bought an old HK Avr. AVR171S.
It’s not as good integrated in Home Assistant as i hoped but i can turn it on, off, select source.
But, is is my receiver or doesn’t the HK Avr component support control of zone 2?
Hi Devqon,
How is this different than what Touliloup posted?
Mine doesn’t work anymore, so how can I use your integration?:slight_smile:
Thanks for your help!
Hey everyone, I stumbled across this whilst trying to change the source on my Citation Soundbar, has any one else tried/tested? I appreciate it isn’t an AVR spcifically but curious.
Each time I try to send a command using this integration I receive the following error:
Logger: HkAVR
Source: components/harman_kardon_avr/media_player.py:115
First occurred: 11:57:55 (40 occurrences)
Last logged: 12:52:12
Connection error: [Errno 111] Connection refused
Cannot connect to AVR
