Harmony Activities, Volume Slider, and Lovelace
Just updated and for some reason my card no longer works. Has anything changed that might break this at all?
what ‘doesn’t work’?
ha
When I click on any of the buttons, nothing turns on.
However if I turn things on manually, then I can adjust the volume using the card. (The Pioneer bit turns into a volume control)
That’s not part of this setup, is that a different lovelace card type?
It’s what I created last year and has been working great until now.
cards:
  • cards:
    • color: auto
      color_type: card
      entity: switch.chromecast
      icon: ‘mdi:cast’
      layout: name_state
      name: Bottom Chromecast
      state:
      • color: red
        value: ‘on’
        styles:
        card:
        • height: 60px
          icon:
        • height: 50px
        • width: 50px
          type: ‘custom:button-card’
    • entity: switch.xboxone
      icon: ‘mdi:xbox’
      layout: name_state
      styles:
      card:
      - height: 60px
      icon:
      - height: 50px
      - width: 50px
      type: horizontal-stack
  • cards:
    • entity: switch.playstation_2
      icon: ‘mdi:playstation’
      layout: name_state
      styles:
      card:
      - height: 60px
      icon:
      - height: 50px
      - width: 50px
    • entity: switch.xbox360
      icon: ‘mdi:xbox’
      layout: name_state
      styles:
      card:
      - height: 60px
      icon:
      - height: 50px
      - width: 50px
  • cards:
    • entity: media_player.pioneer
      hide:
      controls: true
      power: true
      source: true
      type: ‘custom:mini-media-player’
      volume_stateless: true
      type: vertical-stack
      title: Media
      type: ‘custom:vertical-stack-in-card’
The solution in this guide doesn’t use custom cards, for a reason. It avoids them so that the thread is ‘timeless’ in regards to updates in lovelace.
You’re using alot of custom cards there, did you follow the breaking changes related to using resources in 107?
What happens if you CTRL+F5? I would expect this entire card to break (turn red) if your resources aren’t set up properly based on the new lovelace configurations.
I’ve refreshed and also restarted my HA quite a few times in the hope that may resolve it, but no joy.
The card stays the same, nothing breaks.
if the switches still work then it’s your lovelace configuration. Not sure what else to tell you. Your lovelace post is incorrectly formatted so I can’t look at the code.
Just rolled back to 0.104.3 and it seems to be working fine again.
Does this help with viewing the code any better?
cards:
  - cards:
      - color: auto
        color_type: card
        icon: 'mdi:cast'
        layout: name_state
        state:
          - color: red
            value: 'on'
        styles:
          card:
            - height: 60px
          icon:
            - height: 50px
            - width: 50px
        type: 'custom:button-card'
      - entity: switch.xboxone
        icon: 'mdi:xbox'
        layout: name_state
        styles:
          card:
            - height: 60px
          icon:
            - height: 50px
            - width: 50px
  - cards:
      - entity: switch.playstation_2
        icon: 'mdi:playstation'
        layout: name_state
        styles:
          card:
            - height: 60px
          icon:
            - height: 50px
            - width: 50px
      - entity: switch.xbox360
        icon: 'mdi:xbox'
        layout: name_state
        styles:
          card:
            - height: 60px
          icon:
            - height: 50px
            - width: 50px
  - cards:
      - entity: media_player.pioneer
        hide:
          controls: true
          power: true
          source: true
        type: 'custom:mini-media-player'
title: Media
type: 'custom:vertical-stack-in-card'
Yes, major changes occured with lovelace between 106 and 107. I’m not sure how else I can spell this for you. I’ve mentioned lovelace changes 3 times now.
And if you came from 104, TONS of changes occurred to lovelace.
So, check for errors in your logs. Verify there are none related to the front end. When you update to 107, update all your custom cards as well. If it’s still not working, make sure you read all the changes that occurred in 105, 106, and 107 related to resources. In 105, the state of switches may not be passed visually to cards unless they are a light, im not 100% sure if switches fall in this catagory. In 106 they changed the backend, many custom cards require an update for these changes. And in 107 they enabled multiple dashboards for lovelace, changing where/how resources need to be implemented.
I’m fully aware that the upgrade broke it with the changes to lovelace. No need for initial bruntness.
However, thank you for the advice further down.
I’m sorry for being brunt, but you have to understand that this is a universal issue. The first thing you should do when you update is look over breaking changes. It’s fine if you don’t understand the ramifications of said breaking changes. That’s the perfect time to make a post. But I answered you 3 times, on the second answer you should have taken the due diligence and found out what changes occurred instead of me hand holding you by telling you each change that occurred. Hell there could have been other changes that I overlooked between those versions because I’m going off the top of my head. I won’t always be here, you’ll need to learn how to do this on your own.
Hello @petro thank you so much for posting this.
I’m TOTALLY new to HA, been using other HA - Vera/SmartThings for over 10 years. Still learning the ins and outs of HA.
I have the basic config working, i can switch on/off various entities, displaying the images as you’ve outlined.
I am having a heck of a time getting the volume working. For the life of me I can’t seem to figure it out.
I’m using Harmony Hub, Yamaha RX-A3050 (only using 1 zone). I set up everything as you displayed (modifying entity names where appropriate).
I’m running 0.107.7 in docker.
Here are my various file:
automation.yaml:
- alias: Zone 1 Volume (Media to Slider)
    - platform: state
      entity_id: media_player.yamaha_receiver
  condition:
    - condition: template
      value_template: >
        # convert to decibel.
        {% set converted = ( -1.0 + trigger.to_state.attributes.volume_level | float ) * 100.0 | round(0.0) %}
        # Removes feedback loop
        {{ converted != states('input_number.yamaha_receiver') | float }}
     service: input_number.set_value
     data_template:
       entity_id: input_number.yamaha_receiver
       value: >
          {{ ( ( -1.0 + trigger.to_state.attributes.volume_level | float ) * 100.0 ) | round(0.0) }}
- alias: Zone 1 Volume (Slider to Media)
    - platform: state
  condition:
      value_template: >
        # convert from decibel.
        {% set converted = (1.0 - trigger.to_state.state | float / 100.0) | round(2) %}
        {{ converted != state_attr('media_player.yamaha_receiver','volume_level') | float }}
    - service: media_player.volume_set
      data_template:
        volume_level: >
          {{ (1.0 - trigger.to_state.state | float / 100.0) | round(2) }}
switch.yaml:
    switches:
        # ZONE 1 MEDIA SWITCH
        zone_1:
          value_template: "{{ is_state('media_player.yamaha_receiver', 'on') }}"
          turn_on:
            service: media_player.turn_on
          turn_off:
            service: media_player.turn_off
        # Watch TV HARMONY Activity
        watch_tv:
          value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'Watch TV') }}"
          turn_on:
            service: remote.turn_on
              entity_id: remote.living_room
              activity: 'Watch TV'
          turn_off:
              activity: 'PowerOff'
        # PlayStation 4 HARMONY Activity
        playstation_4:
          value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'PlayStation 4') }}"
          turn_on:
              activity: 'PlayStation 4'
          turn_off:
        # Xbox One X HARMONY Activity
        xbox_one_x:
          value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'Xbox One X') }}"
          turn_on:
              activity: 'Xbox One X'
          turn_off:
        # Nintendo Wii U HARMONY Activity
        nintendo_wii_u:
          value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'Nintendo Wii U') }}"
          turn_on:
              activity: 'Nintendo Wii U'
          turn_off:
        # Nintendo Wii HARMONY Activity
        nintendo_wii:
          value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'Nintendo Wii') }}"
          turn_on:
              activity: 'Nintendo Wii'
          turn_off:
        # Smart TV HARMONY Activity
        smart_tv:
          value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'Smart TV') }}"
          turn_on:
              activity: 'Smart TV'
          turn_off:
        # Listen To Living Room Sonos HARMONY Activity
        listen_to_living_room_sonos:
          value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'Listen to Living Room Sonos') }}"
          turn_on:
              activity: 'Listen to Living Room Sonos'
          turn_off:
        # Emby HARMONY Activity
        emby:
          value_template: "{{ is_state_attr('remote.living_room', 'current_activity', 'Watch Emby') }}"
          turn_on:
              activity: 'Watch Emby'
          turn_off:
I have the sensor in configuration .yaml:
    sensors:
      harmony_activity:
        value_template: >
          {% if is_state("remote.living_room", 'on') %}
            {{ states.remote.living_room.attributes.current_activity }}
          {% else %}
            PowerOff
          {% endif %}
input_number.yaml
yamaha_receiver:
  name: Zone 1 Volume
  icon: mdi:volume-high
  initial: -40
  min: -80
  max: +16
  step: 0.5
  unit_of_measurement: dB
ui-lovelace.yaml:
  - icon: mdi:television
    title: Entertainment
    cards:
      - type: vertical-stack
        cards:
          - type: picture-glance
            title: Harmony
            entities:
              - switch.xbox_one_x
              - switch.playstation_4
              - switch.nintendo_wii_u
              - switch.emby
              - switch.smart_tv
              - switch.watch_tv
            state_image:
              "PowerOff": /local/images/power_off.png
              "Xbox One X": /local/images/xbox_one_logo.png
              "PlayStation 4": /local/images/playstation_logo.png
              "Ninetendo Wii U": /local/images/wiiu_logo.png
              "Watch Emby": /local/images/emby.jpeg
              "Nintendo Wii": /local/images/nintendo-wii.jpg
              "Smart TV": /local/images/sony_logo.png
              "Watch TV": /local/images/sony_logo.png
            entity: sensor.harmony_activity
        cards:
            title: Yamaha Receiver
            entities:
              - switch.zone_1
            image: /local/images/yamaha3050.jpg
      - type: conditional
        conditions:
          - entity: switch.zone_1
            state: 'on'
        card:
          type: entities
          entities:
            - entity: input_number.yamaha_receiver
              name: Zone 1 Volume
        cards:
          - type: media-control
            title: Emby
            entity: media_player.emby_shieldtv
Any assistance you can provide would be greatly appreciated.
Thank you again!
Akash
So the slider isn’t working? First, remove the comment lines in the conditions and try again.
@petro
Yes the slider is not working.
I removed the comments from the automation.yaml file:
    - platform: state
  condition:
      value_template: >-
     data_template:
       value: >
    - platform: state
  condition:
      value_template: >-
      data_template:
        volume_level: >
Hmm…still not working, looking at other people’s configs, I see that there are three key pieces that they used: automation.yaml, input_number.yaml, and sensor.yaml.
I see all three, however in sensor.yaml I see no reference to the automation or the input_number entity. Still trying to figure all this out…I broke out the sensor from my configuration.yaml to a senors.yaml file:
    sensors:
      harmony_activity:
        value_template: >-
          {% else %}
            PowerOff
          {% endif %}
    sensors:
      yamaha_receiver:
        value_template: >
          {% if is_state('media_player.yamana_receiver', 'on')  %}
            {{ states.media_player.yamaha_receiver.attributes.volume_level }}
          {% else %}
            0
          {% endif %}
I attempted to add a sensor for the input_number.yamaha_receiver, but that is not working either. I’m totally stumped now! DOH!
:smiley:
Akash
Wow I can’t believe how dumb I am! I forgot to include automation.yaml in configuration.yaml!
It’s sort of working now. I’m able to move the slider and volume changes sometimes, but not others…I’ll keep playing around. Thanks again @petro!
When I move the slider to MAX volume, the receiver complies and turns the volume to MAX (for me its 0.0).
When I move the slider down, the volume is unchanged, in fact, I cant set it to anything other than MAX. I can’t turn it down or set to Min (-80).
Strange.
Thank a lot for sharing this perfect configuration, but I still have an issue to turn off the activity :confused: I have no problem to switch between activities but unable to turn one off. Here is my switch config in case someone can be so kind to help me :smiley:
listen_to_music:
      value_template: >
        {{ is_state_attr('remote.harmony_hub', 'current_activity', 'Listen to Music') }}"
      turn_on:
          entity_id: remote.harmony_hub
          activity: 'Listen to Music'
      turn_off:
What does your /config/harmony_*.conf file list as the power off activity?
-1 but you can use the word “PowerOff”
    "Activities": {
        "-1": "PowerOff",
        "24089909": "PS4",
        "24103421": "Xbox One",
        "26592473": "Switch",
        "30947237": "TV",
        "41729161": "Roku"
Yes, but I thought it might be worth checking as a reason why @benn’s config wasn’t working. I couldn’t see anything else wrong with it…
