Great
Works perfect!
Now another question:
This turns of three lamps, I want to dim tre other lamps on the same action. Is that doable?
Great
Works perfect!
ya, just add the to the entity_id list
But this will turn off the lamp, not dim them?
Oh, yeah, that you’ll have to separate into a second service and adjust the data sent to the lights.
- service: switch.turn_off
entity_id: switch.fibaro_system_blomster_lampe
- service: light.turn_on
entity_id:
- light.le_klint_stalampe
- light.light.trapp_2
brightness: 10
Then I get this error
Invalid config for [automation]: expected dict for dictionary value @ data[‘action’][1][‘data’]. Got None
extra keys not allowed @ data[‘action’][1][‘brightness’]. Got None. (See /config/configuration.yaml, line 75). Please check the docs at https://home-assistant.io/components/automation
The automation looks like this now:
- alias: Turn off light after watching TV
- platform: state
entity_id: remote.harmony_hub
condition: # this list of conditions is 'and'ed together.
- condition: template
value_template: >
{{ trigger.from_state.attributes.current_activity == 'Watch TV' and
trigger.to_state.attributes.current_activity == 'PowerOff' }}
- condition: time
after: '19:00:00' # 7 pm
- service: homeassistant.turn_off
entity_id:
- switch.fibaro_system_blomster_lampe
- light.trapp_2
entity_id:
- light.trapp_2
- light.soverom
brightness: 25
because your data: and entity_id lines are not indented properly. Look at my example again and make sure your spacing is correct.
