I think people are avoiding helping you (in this post and your other post) because you’ve done pretty much nothing. You’re asking everyone to set up the entire hub for you in home assistant without you knowing the basics. I suggest you spend time reading the docs first. The docs cover every aspect of harmony inside home assistant including calling commands. Once you have the basics understood, come to the forum and ask specific questions.
Hello, and thank you for the reply.
Perhaps you are correct, i didnt know harmony setup required so much work. Was hoping for a " just copy and paste this and that into your configuration file" type of answer.
Have gotten pretty far with home assistant without help, but regarding harmony i got confused as people seemes to have done different things, and everyone has a different setup.
But i see your point if its taking so much work
regardig the docs i have been trying to understand since ive started this project, but i dont understand why i can do some of the start like volum, and channels, but not change inputs etc.
But i will try again
