Harmony update fail after 0.84.6 and not working
I ended up rolling back to 0.84 in the end as a quick fix.
I have find a new solution for me… actually work fine !
i have create a link with my google home and home assistant (this link for tuto : https://www.home-assistant.io/components/google_assistant/
i have bought domaine with ssl in Gandi.net (0.69 € for 1 year with SSL)
and i have scripted channel for my Hub in configuration.yaml :
google_assistant:
  project_id: YOURPROJECTIDWITHGOOGLEHOME
  api_key: YOUR APIKEY
  expose_by_default: true
  exposed_domains:
    - switch (for enable script)
  entity_config:
    script.ok:
      expose: true
    script.13emerue:
      expose: true
    script.beinsport1:
      name: bein sports 1
      expose: true
    script.beinsport2:
      name: bein sports 2
      expose: true
    script.beinsport3:
      name: bein sport 3
      expose: true
    script.c8:
      expose: true
    script.canalplus:
      expose: true
    script.cstar:
      expose: true
    script.fr2:
      expose: true
    script.fr3:
      expose: true
    script.fr4:
      expose: true
    script.m6:
      expose: true
    script.mute:
      name: coupe le son
      expose: true
    script.nrj12:
      expose: true
    script.nrjhits:
      expose: true
    script.rmcsport1:
      name: RMC sport 1
      expose: true
    script.rmcsport2:
      name: RMC sport 2
      expose: true
    script.rmcsport3:
      name: RMC sport 3
      expose: true
    script.rmcsport4:
      name: RMC sport 4
      expose: true
    script.tf1:
      expose: true
    script.tfx:
      expose: true
    script.tmc:
      expose: true
    script.w9:
      expose: true
    script.volumedown:
      expose: true
    script.volumeup:
      expose: true
and now just say hey google turn on “name” and immediatly google change channel :slight_smile:
i have bypass ifttt and change channel is immediatly
i dont now i its possible to change “turn on” by “put the channel” but actully all it’s ok.
Need to try 5/6 day without restart my home assistant because old solution need to restart home assistant everyday
I have do it even easier, if you make switched that execute an script. , Then expose the switch , you can just say the name , without the word “on”
just my google home is in french language so i need to say : "dis google allume “channel” (hey google turn on “channel”
and google answer ok j’allume 2 scenes (ok i turn on “2 scenes”) i dont know what is the 2 scenes ?
maybe scripts.yaml and configuration.yaml have duplicate ?
in my log when i call in script i have that :
Script script.13emerue already running.
18:21 components/script.py (WARNING)
Script script.volumeup already running.
17:23 components/script.py (WARNING)
Script script.volumedown already running.
Script script.nrj12 already running.
17:22 components/script.py (WARNING)
Log Details (WARNING)
Fri Jan 18 2019 18:21:43 GMT+0100 (heure normale d’Europe centrale)
you probably have “ghost devices” , its indeed a known issue
unlink your app
command: sync my devices
delete any empty rooms if you created them by HA
link your app
again command : sync my devices
should be fixed then
Thank you for your reply i have try your solution work partialy some channel say again 2 scenes but i retry tomorrow this solution maybe google home or HA have again ghost in “cloud” or memory
Also be careful with the commands, for example
I have a command like : vacuum kitchen and vacuum diner room, …
So if I say : vacuum, then it response : ok starting vacuum 2 times… , That’s not good offcourse, but it’s normal…
Ok thank you for information :slight_smile:
