HASS.Agent: Windows client to receive notifications, use commands, sensors, quick actions and more!
Has anybody encountered this error appear when starting up HASS.Agent on Win10? It was working fine up until recently, not aware of any other changes that may have caused it.
followed by
and then HASS.Agent crashes.
Have tried deleting the json file and reinstalling the app.
Hi guys - is there a way to install HAAS. Agent on a 32-bit system ? I tried to install it on tablet using win 8 which is 32 bit and i got the message that the installer stopped because the system which i want to install on is a 32 bit one? - Is there a way to install HAAS even in a limited version ?
So sad to see that this plugin isn’t maintained anymore. It really should be a part of the Home Assistant project to have a PC-sensor.
It is, in another fork here. The link is already given some posts above…
This app is super useful, but it seems that it would be better if it had more pc system readings. As it stands, I can see my GPU temperature, but not the CPU temp. I’m looking to ventilate my wiring closet based on CPU usage (temperature), but that does not seem possible currently. Where would one put in a suggestion for the developer? I’m guessing the discussion section on the Github page? Thanks
You can literally pull any value available in WMI: (including any temp available to the OS)
https://hassagent.readthedocs.io/en/latest/wmi-examples/
Very cool. Not sure how I missed that, but thanks for the link!
Great tool, I use it for various tasks. Do you know if it is possible to change the refresh intervals of the local sensors or even better trigger a local sensor refresh on my windows machine from Home Assistants side?
With that I could for example refresh a sensor in a Home Assistant automation right before I check its status.
Do anyone know what the Internal Device Sensor does? I have no options in the dropdown and the advanced section just allows me to enter device classes and what not.
Create a Command using PublishAllSensors and type Button and then press the button it creates in HA.
Hi all - I’m trying to set up an automation that prevents my motion sensors from turning off the lights if my PC is active (keyboard stroke or mouse movement). I thought the “lastactive” sensor would work but it’s just resetting every 10 seconds even if I don’t touch the keyboard or mouse. Anyone have any thoughts on how I should proceed?
Can’t you just use a powerplug? If your system goes into standby it consumes much less watt. Then set the standby timer to three minutes. That’s how I’ve done it
