please check if you have enough space on your device
this is my space situation:
Filesystem Size Used Available Use% Mounted on
none 13.7G 1.7G 11.2G 13% /
tmpfs 486.1M 0 486.1M 0% /dev
tmpfs 486.1M 0 486.1M 0% /sys/fs/cgroup
/dev/mmcblk0p2 294.1M 225.8M 48.7M 82% /dev/init
/dev/mmcblk0p6 13.7G 1.7G 11.2G 13% /share
/dev/mmcblk0p6 13.7G 1.7G 11.2G 13% /data
/dev/mmcblk0p6 13.7G 1.7G 11.2G 13% /config
/dev/mmcblk0p6 13.7G 1.7G 11.2G 13% /ssl
/dev/mmcblk0p6 13.7G 1.7G 11.2G 13% /addons
/dev/mmcblk0p6 13.7G 1.7G 11.2G 13% /backup
/dev/mmcblk0p6 13.7G 1.7G 11.2G 13% /etc/resolv.conf
/dev/mmcblk0p6 13.7G 1.7G 11.2G 13% /etc/hostname
/dev/mmcblk0p6 13.7G 1.7G 11.2G 13% /etc/hosts
shm 64.0M 0 64.0M 0% /dev/shm
tmpfs 486.1M 0 486.1M 0% /proc/timer_list
tmpfs 486.1M 0 486.1M 0% /proc/timer_stats
tmpfs 486.1M 0 486.1M 0% /proc/sched_debug
tmpfs 486.1M 0 486.1M 0% /sys/firmware
is it correct? Seems to me that there is plenty of space.
Or i have to watch somewere else?
Thanks in advice
I haven’t find a solution yet.
I reinstalled from scratch with a 32gb sd card.
Everything worked ok for a week or so.
Now if I try to install any addon i get the same error:
Can’t install hassioaddons/sonweb-armhf:0.1.1 -> 404 Client Error: Not Found (“no such image: hassioaddons/sonweb-armhf:0.1.1: No such image: hassioaddons/sonweb-armhf:0.1.1”).
Please help.
