Again, just like the other
Actually no, the other addon only runs at a set time interval.
To be pedantic, if for whatever reason you really donāt like running at a set interval, you could automate the add-on to start and stop using service calls. Dougalās add-on is great
Actually yes!
The add-on doesnāt have any kind of time interval built in, itās entirely down to the automation you create to trigger it like everything in HA.
To clarify for anyone else who stumbles upon this because I had to read into it myself: It looks like the Dropbox uploader here has an interval for the time between checks for new backups. The interval doesnāt pertain to actually creating the backup. You need to trigger a backup via automation then every X mins the add-on will check if there are new backups to upload.
Set this up today and itās awesome. I now have daily backups with the last 5 being saved to dropbox.
Simply brilliant
I installed the add on today and had chose access to app rather than folder. This created a folder in dropbox and saved each backup as āHassio Backupā rather than dated. I figured iād try āFull Dropboxā (Makes no odds to me anyway as i donāt use Dropbox for any other reason )
So i tried a fresh uninstall/install of the add on with a fresh token, but when i try to start the add on i get the following error:
18-12-24 13:45:37 ERROR (SyncWorker_5) [hassio.docker] Can't start addon_7be23ff5_dropbox_sync: 403 Client Error: Forbidden ("endpoint with name addon_7be23ff5_dropbox_sync already exists in network hassio")
I have Hassio installed through Rasbian Stretch on a Pi running from USB.
Any ideas how i can resolve this? It was running great and i was triggering automations which were running perfect, but since i tried to re-configure it is saying itās already there.
Dougalās addons set interval is actually how often to check for backups. You still have to create an automation to create the backup.
Hi All
Thanks for the great Plugin !
I have a question, I would like to store my jpg in different directory, and I want to modify the
find /share -regextype posix-extended -regex ā^.*.(${FILETYPES})ā -exec ./dropbox_uploader.sh -s -f /etc/uploader.conf upload {} ā$OUTPUT_DIRā āmyDIRā;
But I could not find the run.sh file, why ? Where is this file in hassio?
Ima using rabery Pi3.
Thx.
Am I missing how to keep the dated name in Dropbox? My backups show the name in HASS but in Dropbox they show the old ugly name
Thatās because the file name is the ugly name and Hass.io reads inside the file for the other information it displays. Thereās no way around it other than sorting in date order.
thatās ugly. Thanks for the quick reply though!
Check out dougalās version, it allows for snapshot_name as opposed to the slugly name.
Not sure if I need to start a new thread or notā¦ But, I added the add-on through the add-on store in Hass.io. I set up the app in my Dropbox account and generated the auth code. (The permission type is āApp Folderā).
Here is my config:
Now what?
I did a new backup, but nothing shows up in the newly created folder in my DropBox/Apps folder.
I read in the ReadMe file that to trigger an upload āby calling the hassio.addon_stdin serviceā, but in the <>Services tab, I have no such service.
So, what have I done wrong?
Thanks,
The addon works perfectly, however, my automation to do a local snapshot is not a 100%.
I have this for the automation.
alias: Backup Local
- at: 02:00:00
platform: time
condition: []
- data:
name: "Automated Backup {{ now().strftime('%Y-%m-%d') }}"
It seems to be creating snapshots with the name Automated Backup {{ now().strftime(ā%Y-%m-%dā) }} and not Automated Backup 2019-01-29
What am I doing wrong here?
Use data_template: and not data:
That did the trick. Thanks
Hi there
Iām using @danielwelchās addon in an automationā¦ is there a way to know when the upload is finished?
I see in the addonās log:
[Info] Received message with command upload
[Info] Uploading all .tar files in /backup (skipping those already in Dropbox)
> Uploading ā/backup/39480781.tarā to ā/hassio-backups/39480781.tarā by 6 chunks ā¦ DONE
> Skipping already existing file ā/hassio-backups/683575fe.tarā
[Info] keep_last option is set, cleaning up filesā¦
[Info] Deleted snapshot 683575fe
how can I use such an info in my automation?
TIA
I think I got everything in place for dropbox backup: the add-on + configuration and an account.
How can I test is via services in the UI?
Iāve read some automation tasks, what is best to do now?
