This is by design, and you should read the documentation. Particularly the section labeled “Usage”. Unless you’ve followed those directions and you’re still stuck, in which case I’m happy to help more.
D’oh!! Such an eeejit. Sorry I missed that…
Upload now in progress…where’s the embarassed emoji?!
The only query I have now is is there a setting to ONLY upload the most recent snapshot? No big deal if not.
I’ve opened an issue on Githib because I get this error
*** FAILED An error occurred requesting /chunked_upload
Log is:
[Info] Files will be uploaded to: /hass_b3_backup/
[Info] Saving OAUTH_ACCESS_TOKEN to /etc/uploader.conf
[Info] Listening for messages via stdin service call...
{"command": "upload"}
[Info] Received message with command upload
[Info] Uploading all .tar files in /backup (skipping those already in Dropbox)
> Uploading "/backup/14c13bf3.tar" to "/hass_b3_backup/yyyyyyyyy.tar" by 6 chunks *** FAILED
My config is:
"oauth_access_token": "xxxxxxxx", # app_key in Dropbox developer page
"output": "/hass_b3_backup/", # folder created under Application in Dropbox
"keep_last": 7
Hi - Wanted to say thanks for the add-on. Before the whole update debacle happened 3 days ago - I was in the process of installing this add-on, and I didn’t quite finish. It would run when I called the service, however it assumed my folder name was the FILE name I wanted to save it as. I would use “/hassio/snapshots/” (and with testing, several variations of that) - it would just create snapshots in hassio folder, and then try to create 9 more, and obviously failing. (9 more attempts because I have 10 snapshots in my backup folder). Normally I would assume thats because of a trailing slash issue in my folder syntax, however I couldn’t really test that because the addon wouldn’t update the folder name no matter how many times I saved config and restarted addon.
However as I’m writing this - I just realized why. My hassio_supervisor was updated coincidentally at the same time as me trying this, and AppArmor was preventing any of the addons from shutting down or restarting… Thats why it wasn’t accepting the new config… because there wasn’t any being saved.
Ok back to testing… I still wrote this post, in case someone else is having the same problem. You need to shut off apparmor temporarily (don’t think this is recommended, or suggested however) and then you can shut down those containers and reboot the server with a fresh status.
I’ll post back here if or when this is sorted and let others know, in case they have the same experience as I did.
When I first set mine up I had it pointed to a specific subfolder on DropBox but that stopped working after a short time and the only way I could fix it was to point the add-on at the root, been fine ever since.
Given I have an account only for hassio snapshots it make no odds where they go, just that they are there. Might be worth a try for those having problems as I notice most are trying to use subfolders…
So weird. I do specify a folder and it works. However, on dropbox it seems to have another folder under the folder I specify… odd. I haven’t checked because I really don’t care but maybe it’s something to do with how I set up the app…
My path is /Home-Assistant/Backups/home-assistant-backups/*.tar files
My Options in the dropbox add-on are: /home-assistant-backups/*.tar
So I guess in the app setup seems to me it makes a folder using the app name… in my case the app name I created on dropbox is ‘Home Assistant Backups’ and then it uses your options to create a folder under that.
There’s two ways to setup a Dropbox Apps in their interface - one is give access to an application specific folder only (that appears to be what you did) - and the other is to give the app full root access in Dropbox. So depending on which one you chose, it will use the application name as the root. or if you gave full access, it will use your dropbox root folder. Both work, just one limits the access you gave the application.
I dont remember what I did to be honest… just followed Daniels instructions. Is there any way to check or reconfigure an app? I was poking around the app on my iPad last night in chrome as you can’t see much of anything in the iPhone dropbox app.
If you goto your dropbox.com/account/connected_apps/ - you’ll see your linked apps and it will say in the table of data., whether you gave it “app folder” access. or “full dropbox” access.
I velieve that will put the files in your dropbox account like: /hass_b3_backup/hass_b3_backup/ folder. ie, you’re using an application folder as the root… so you don’t need to add /hass_b3_backup/ folder in your add on config. if you just put “/” as the folder in the config of the addon - then it will prob be where you are hoping it will show up.
It’s neither right nor wrong either way. You really just need to be able to find them. On my Windows PC I run a script to leave only 5 in dropbox otherwise it fills up - so script moves them to where I keep them longer term. The script knows where to find them - that’s all you need.
