Hass.io error while connecting to IKEA Tradfri gateway
lucky you… :frowning:
deleted file in config folder… no folder in deps… and still a no go
File “/usr/lib/python3.6/asyncio/tasks.py”, line 179, in _step
result = coro.send(None)
File “/usr/lib/python3.6/site-packages/homeassistant/components/tradfri.py”, line 66, in configuration_callback
psk = yield from api_factory.generate_psk(callback_data.get(‘key’))
File “/usr/lib/python3.6/site-packages/pytradfri/api/aiocoap_api.py”, line 193, in generate_psk
self._psk = yield from self.request(command)
File “/usr/lib/python3.6/site-packages/pytradfri/api/aiocoap_api.py”, line 149, in request
result = yield from self._execute(api_commands)
File “/usr/lib/python3.6/site-packages/pytradfri/api/aiocoap_api.py”, line 141, in _execute
api_command.result = _process_output(res, parse_json)
File “/usr/lib/python3.6/site-packages/pytradfri/command.py”, line 71, in result
self._result = self._process_result(value)
File “/usr/lib/python3.6/site-packages/pytradfri/gateway.py”, line 28, in process_result
return result[ATTR_PSK]
TypeError: ‘NoneType’ object is not subscriptable
tradfri gateway fw version you guys are using?
1.2.42 here
Same here. gateway firmware version 1.2.42 .
I’m able to use the Tradfri component on a development board with Docker on CentOS, that has same hassio version (0.57.2).
try factory reset on tradfri gateway…
that will issue a new key
