Mine is a arduino with YUN Shield. I had the arduino but it was not wifi enabled. If the HASS is going to control the scheduling then I didn’t really need a RPI. Mine you set the duration for each zone, the turn it on the Arduino is responsible for turning it off.
I have the switch to turn it on, the mqtt for the status update working. The slider to send the duration setting. Now I just need a way to schedule and display.
I do wish the configuration files for something could all be wrapped up in one. i.e. Boolean inputs, sliders, mqtt configs, etc. So you could literally package it up and share it. I guess that is more in the component category though…
I’m on holiday and became grandfather a week ago so my response is a bit behind…
It is all based on MQTT… The status is just a calculation from timenow and when the switch was activated just a little template sensor.
The last run is when the switch was turned on last time however this is not always the right status as when HASS is restarted it is set to the restart tome so needs a bit of work…
Still have one week holiday but after that I will post some of my yaml templates…
OK below here is some of the yaml and scripts I use for this… now as I have my config split up in multiple files you cannot cut & past but you have to make sure it all goes in the right place in your config… and check the yaml as at some places there will be too many spaces
Hope it helps to understand how I have done a few things… might be that I forgot something so let me know if it is not working.
Btw as this is very script heavy with template sensors I planning to move parts of it to the apps.
sensors:
starttime_valve_1:
friendly_name: 'Start Time'
entity_id:
- input_slider.valve_1_hour
- input_slider.valve_1_minutes
value_template: '{% if states.input_slider.valve_1_hour.state|length < 4%}0{% endif %}{{states.input_slider.valve_1_hour.state | int }}:{% if states.input_slider.valve_1_minutes.state|length < 4%}0{% endif %}{{ states.input_slider.valve_1_minutes.state | int }}'
duration_valve_1:
friendly_name: 'Duration'
entity_id: input_slider.valve_1_duration
value_template: '00:{% if states.input_slider.valve_1_duration.state|length < 4%}0{% endif %}{{ states.input_slider.valve_1_duration.state | int }}'
status_valve_1:
friendly_name: 'Status'
value_template: "{% if states.switch.valve_1.state == 'on'%}Opened {{((as_timestamp(now) - as_timestamp(states.switch.valve_1.last_changed)) / 60) | round(0) }} minutes ago{% else %}Closed{% endif %}"
last_run_valve_1:
friendly_name: 'Last Run'
entity_id: switch.valve_1
value_template: "{{states.switch.valve_1.last_changed.strftime('%a')}}, {{states.switch.valve_1.last_changed.strftime('%d-%m-%Y')}}"
schedule_valve_1:
friendly_name: 'Schedule'
entity_id: input_select.valve_1_schedule
value_template: "{{ states.input_select.valve_1_schedule.state }}"
next_run_valve_1:
friendly_name: 'Next Run'
entity_id:
- input_select.valve_1_schedule
- switch.valve_1
value_template: >
{# runDay set to 9 = Not Set #}
{% set runDay = 9 |int %}
{# Set todays day #}
{% set currentDay = now.weekday() |int %}
{%- macro monthu() -%}
{%- if currentDay == 0 -%}
{{0}}
{%- elif currentDay <= 3 -%}
{{3}}
{%- else -%}
{{0}}
{%- endif -%}
{%- endmacro -%}
{%- macro monwedfrisun() -%}
{{0}}
{%- elif currentDay <= 2 -%}
{{2}}
{%- elif currentDay <= 4 -%}
{{4}}
{%- elif currentDay <= 6 -%}
{{6}}
{%- endif -%}
{%- endmacro -%}
{# set configured runDay from input_select #}
{% if states.input_select.valve_1_schedule.state == "Monday" %}
{% set runDay = 0 |int %}
{% elif states.input_select.valve_1_schedule.state == "Tuesday" %}
{% set runDay = 1 |int %}
{% elif states.input_select.valve_1_schedule.state == "Wednesday" %}
{% set runDay = 2 |int %}
{% elif states.input_select.valve_1_schedule.state == "Thursday" %}
{% set runDay = 3 |int %}
{% elif states.input_select.valve_1_schedule.state == "Friday" %}
{% set runDay = 4 |int %}
{% elif states.input_select.valve_1_schedule.state == "Saturday" %}
{% set runDay = 5 |int %}
{% elif states.input_select.valve_1_schedule.state == "Sunday" %}
{% set runDay = 6 |int %}
{% elif states.input_select.valve_1_schedule.state == "Mon/Thu" %}
{% set runDay = monthu() |int -%}
{% elif states.input_select.valve_1_schedule.state == "Mon/Wed/Fri/Sun" %}
{% set runDay = monwedfrisun() |int %}
{% elif states.input_select.valve_1_schedule.state == "Every Day" %}
{% set runDay = currentDay |int %}
{% endif %}
{# determine the next runday #}
{% if runDay == 9 %}
{# schedule not active #}
{% set runDate = "Not set" %}
{% else %}
{# schedule is active so determine next run #}
{# first check if runDay = today #}
{% if currentDay == runDay %}
{# are we passed the scheduled time? #}
{% if states.sensor.starttime_valve_1.state < now.time().strftime("%H:%M") %}
{# than we need to fake tomorrow #}
{% set currentDay = (currentDay + 1) |int %}
{# and calculate new runDay in case we have a list of multiple run days in in a week #}
{% if states.input_select.valve_1_schedule.state == "Mon/Thu" %}
{% endif %}
{% endif %}
{% endif %}
{# Now we can determine next runDate base on now.weekday() and not currentDay as that can be set to fake tomorrow #}
{% if currentDay <= runDay %}
{% set Days = runDay - now.weekday() |int %}
{% else %}
{% set Days = runDay + 7 - now.weekday() |int %}
{% endif %}
{% set runDate = ((as_timestamp(now) + (86400 * Days)) | timestamp_local) %}
{# we also want to show the weekday of the next date #}
{% set weekdayList = ["Mon", "Tue", "Wed", "Thu", "Fri", "Sat", "Sun"] %}
{% if now.weekday()+ Days < 7 %}
{% set weekday = weekdayList[(now.weekday()+ Days)] %}
{% else %}
{% set weekday = weekdayList[(now.weekday()+ Days)- 7] %}
{% endif %}
{% endif %}
{# all done #}
{# set states.sensor.next_run_date_valve_1.state = runDate #}
{{runDate}}
{% else %}
{{weekday}}, {{runDate[8:10]}}-{{runDate[5:7]}}-{{runDate[0:4]}} at {{states.sensor.starttime_valve_1.state}}
{% endif %}
#### input_sliders
valve_1_hour:
icon: mdi:clock
initial: 9.00
min: 0
max: 23
step: 1
valve_1_minutes:
icon: mdi:clock
initial: 0.00
min: 0
max: 55
step: 5
valve_1_duration:
icon: mdi:timer-sand
initial: 30.00
min: 0
max: 55
step: 5
#### input_select
valve_1_schedule:
options:
- None - Close Valve
- Run Now
- Every Day
- Mon/Wed/Fri/Sun
- Mon/Thu
- Monday
- Tuesday
- Wednesday
- Thursday
- Friday
- Saturday
- Sunday
initial: None - Close Valve
icon: mdi:calendar
#### groups
valve_1_status:
icon: mdi:water-pump
entities:
- sensor.status_valve_1
- sensor.last_run_valve_1
- sensor.next_run_valve_1
- sensor.schedule_valve_1
- sensor.starttime_valve_1
- sensor.duration_valve_1
- group.valve_1_settings
valve_1_settings:
icon: mdi:settings
entities:
- input_slider.valve_1_duration
##### Switch
- platform: mqtt
state_topic: "5ccf7f18d3c/valve/1/state"
command_topic: "5ccf7f18d3c/valve/1/cmd"
payload_on: "1"
payload_off: "0"
optimistic: false
qos: 0
retain: true
##### Automation
alias: "Turn on valve based on schedule"
platform: template
value_template: '{{states.sensor.starttime_valve_1.state == now.time().strftime("%H:%M")}}'
condition:
- condition: state
state: 'off'
- condition: template
value_template: "{{states.sensor.next_run_valve_1.state[5:15] == now.date().strftime('%d-%m-%Y')}}"
- service: script.turn_on
entity_id: script.open_valve_1
alias: "Turn on valve"
- platform: state
state: "Run Now"
alias: "Turn off valve"
- platform: state
state: "None - Close Valve"
entity_id: script.close_valve_1
#### scripts
open_valve_1:
alias: "Open Valve 1 for duration below"
sequence:
- service: script.turn_off
entity_id: script.close_valve_1_delayed
- service: switch.turn_on
close_valve_1_delayed:
alias: "Close Valve 1 after duration"
sequence:
- delay: '00:{% if states.input_slider.valve_1_duration.state|length < 4%}0{% endif %}{{ states.input_slider.valve_1_duration.state | int }}'
- service: switch.turn_off
close_valve_1:
alias: "Close Valve 1 immediately"
sequence:
One of the key opportunities automating the sprinkler brings is not sprinkling when there is rain. Generally the current plug ins provide data for looking forward (so for example expected rain today). But as we all know this is often off. So best would be to look back two days and forward 1 day. And only trigger sprinkler when rain < x.
Wow, this is some pretty serious stuff. Very cool! This is way beyond what I had thought was possible and I’d like to try and implement what you’ve done. I have an Electrodragon 2-relay IOT board that drives two water valves and has two inputs; one I’m using for the rain sensor mounted on the roof (0/1). The device is controlled via MQTT like yours. I also have my configuration split with ‘scripts’ and ‘auto’ folders.
Is there any way you could share your files on GitHub as others have done? I’m planning to do they same once I have something useful and have implemented the secrets file.
Good to hear that you got it working and indeed after 29 you need to change the function into now().
Yes it is hidden normally only when you click on settings you see it. It is not perfect or very intuitive in the way HASS works at the moment as I would like to see Settings as a link (blue and underlined) … but he maybe in the future
I did it this way as otherwise the GUI is very full with stuff you only need when changing the cycle of watering.
Sorry xbmcnut I will not find the time to create a working example without all other stuff I have in there… The C&P above should help you along the way … the template sensors are the most important parts as they calculate the next run based on how the sliders and input select are set.
Please note that the function now should be replaced by now() since 29
Hi Ron. Of course, I completely understand and in hindsight, it would probably be above my capabilities at the moment (I’m a hardware guy) are an overkill for my requirements. All I’m attempting to do is the following:
Schedule my two water valves on at 0630 everyday for 20 minutes with an input slider for the timer value
Check the state of my rain gauge (wet/dry) as a condition to prevent firing if wet
Have the timer fire based on the state change of the valve so that the timer always works, even if the valves are manually turned on. This is how it is set up with PLEG in my Vera which I’m trying to replicate in HA.
I’m learning YAML but it is a steep learning curve for a hardware guy, especially when the formatting in all of the examples on the main webpage bare no reference to the required formatting when you split your config up (which is kind of mandatory if you have more that a half-dozen devices).
This is where I’ve got to which I’m happy with (about 6hrs latter!) but is a way from where I need to be.
Please see also the group documentation on how to use view: yes together with the default_view to create your own layout in the front end. If you got that than the trick is easy as the above basically creates an entry for the Sprinkler in the top menu of the frontend that shows the view for the group valve_1_status. Now the last line in the view valve_1_status is another group group.valve_1_settings.
The effect is that the group.valve_1_settings is only shown if you click on the Settings in the view of valve_1_status.
Basically you need to create an automation rule that triggers on turning a valve on. This should include a condition based on “Use Timer for Sprinklers” if that is ON/TRUE than turn_on script that turns them off after a set delay.
