Hassbian-config script issues
Hi all
I encountered the following issues when I execute the script “sudo hassbian-config upgrade homeassistant”:
Home Assistant install script for Hassbian.
Copyright© 2017 Fredrik Lindqvist https://github.com/Landrash.
Checking current version
Setting correct premissions
Changing to the homeassistant user
Changing to Home Assistant venv
Upgrading Home Assistant
Requirement already up-to-date: setuptools in /srv/homeassistant/lib/python3.5/site-packages
Collecting wheel
Downloading https://files.pythonhosted.org/packages/96/ba/a4702cbb6a3a485239fbe9525443446203f00771af9ac000fa3ef2788201/wheel-0.33.1-py2.py3-none-any.whl
Installing collected packages: wheel
Found existing installation: wheel 0.33.0
Uninstalling wheel-0.33.0:
Successfully uninstalled wheel-0.33.0
Successfully installed wheel-0.33.1
Collecting homeassistant==0.88.1
Downloading https://files.pythonhosted.org/packages/b3/13/6119a98dc730c58118a8b8cb3a873e6a1202302bbec425823a3558ec38c4/homeassistant-0.88.1-py3-none-any.whl (3.8MB)
Requirement already up-to-date: pytz>=2018.07 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.88.1)
Requirement already up-to-date: pyyaml<4,>=3.13 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.88.1)
Requirement already up-to-date: attrs==18.2.0 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.88.1)
Requirement already up-to-date: async-timeout==3.0.1 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.88.1)
Requirement already up-to-date: jinja2>=2.10 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.88.1)
Requirement already up-to-date: aiohttp==3.5.4 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant==0.88.1)
Collecting cryptography==2.5 (from homeassistant==0.88.1)
Downloading https://www.piwheels.org/simple/cryptography/cryptography-2.5-cp35-cp35m-linux_armv7l.whl (865kB)
Exception:
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 594, in urlopen
chunked=chunked)
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 391, in _make_request
six.raise_from(e, None)
File “”, line 2, in raise_from
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 387, in _make_request
httplib_response = conn.getresponse()
File “/usr/lib/python3.5/http/client.py”, line 1198, in getresponse
response.begin()
File “/usr/lib/python3.5/http/client.py”, line 297, in begin
version, status, reason = self._read_status()
File “/usr/lib/python3.5/http/client.py”, line 266, in _read_status
raise RemoteDisconnected(“Remote end closed connection without”
http.client.RemoteDisconnected: Remote end closed connection without response
File “/srv/homeassistant/lib/python3.5/site-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/commands/install.py”, line 353, in run
wb.build(autobuilding=True)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/wheel.py”, line 749, in build
self.requirement_set.prepare_files(self.finder)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py”, line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File “/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py”, line 487, in _prepare_file
req_to_install, finder)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py”, line 428, in _check_skip_installed
req_to_install, upgrade_allowed)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 568, in _get_pages
page = self._get_page(location)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 792, in get_page
“Cache-Control”: “max-age=600”,
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 501, in get
return self.request(‘GET’, url, **kwargs)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/download.py”, line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 488, in request
resp = self.send(prep, **send_kwargs)
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 609, in send
r = adapter.send(request, **kwargs)
File “/srv/homeassistant/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py”, line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py”, line 423, in send
timeout=timeout
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py”, line 315, in increment
total -= 1
TypeError: unsupported operand type(s) for -=: ‘Retry’ and ‘int’
Deactivating virtualenv
Restarting Home Assistant
Checking the installation…
Upgrade script completed…
Note that it may take some time to start up after an upgrade.
Did you end up fixing this? I’m also trying to get around this issue from a brand new clean install of HASSBIAN but Home Assistant just refuses to install.
Are you guy’s stopping the HA service prior to running the script?
sudo systemctl stop [email protected]
sudo -u homeassistant -H /bin/bash
source /srv/homeassistant/bin/activate
wget -O /tmp/get-pypi.py https://bootstrap.pypa.io/get-pip.py
python /tmp/get-pypi.py
deactivate
exit
Hi, Did you end up fixing your issue? I am also experiencing the same i errors while trying to install fresh…
Replying back to myself for others who are having the same issue…
Thank you to @ludeeus… that fixed my issue…
For others:
deactivate
exit
sudo -u homeassistant -H -s
cd /srv/homeassistant
python3 -m venv .
source bin/activate
python3 -m pip install wheel
pip3 install homeassistant
